Home Forums Race Schedule vBGarage Who's Online Today's Posts Mark Forums Read
Go Back   Chicagoland Sportbikes > Open Topic Discussions > General Sportbikes
CLSB Store Article Section Local Radar Register FAQ Members List Calendar Mark Forums Read
Thread Tools Display Modes
Old 12-26-2007, 12:56 PM   #1
jrock
You got the talkin' done
jrock's Avatar
Sportbike: '00 VFR800Fi & '07 CBR1000RR
jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!jrock Walks on F&?kin water, No shit!!!
Better Then a Battery Tender
I got this for Christmas this year and I was told this was better then a battery tender. I did some reading and I would have to agree. I'll leave the battery tender on the VFR and put this one on the CBR.
http://www.optimate3.com/classic/
__________________
Check out the Flat 4 Tour Subforum
http://www.chicagolandsportbikes.com...play.php?f=125
jrock is offline   Reply With Quote
Old 12-26-2007, 01:16 PM   #2
2weelpilot
2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!2weelpilot Walks on F&?kin water, No shit!!!
can that be used on sealed gel batteries?
__________________
2weelpilot is offline   Reply With Quote
Old 12-26-2007, 01:26 PM   #3
sqrly
Highspeed ditch inspector
sqrly's Avatar
Sportbike: CB-360, GSX-R(RIP), RSVmille(RIP), RST Futura
Years Riding: I crashed on the 1st day, I'll crash on the last.
sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!sqrly Walks on F&?kin water, No shit!!!
I have one for the Aprilia, it is excellent!
Yes, it works for ALL batteries.
__________________
I have accepted death,
I have felt consequences,
nothing you say will change my mind.
I'm still going riding.
-sqrly
sqrly is offline   Reply With Quote
Old 12-26-2007, 01:53 PM   #4
Chills
Years Riding: Since June 2009
Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!Chills Walks on F&?kin water, No shit!!!
So what does it do that's better than a battery tender?
__________________
Chills is offline   Reply With Quote
Old 12-26-2007, 02:30 PM   #5
jrock
jrock's Avatar
For one, it diagnoses and desulfates batteries.
Starter batteries that have been left in a discharged state tend to sulfate and quickly build up resistance to conventional charging. This is more evident during extreme temperature conditions. Most of the electrolyte in the battery turns into water when the battery is completely discharged and this has three effects:
- without acid the build up of sulfate crystals on the battery plates occurs rapidly; as the buildup of crystals increase so does resistance to charging
- water freezes which physically damages the battery plates or casing (water expands by 6 / 5 when freezing)
- in hot conditions water evaporates, impeding the chemical process required to re-energize the plates.
Standard ‘smart’ chargers cannot overcome high resistance caused by sulfation, but OptiMate3’s desulfation program can. (One of the main reasons why our competitors claim that once a battery is sulfated, it is only good for dumping.)
The truth of the matter is, both filler cap and “MF” VRLA starter batteries can be recovered if done right & soon enough, confirmed in the technical report “Service manual for sealed MF Battery” published by Yuasa Battery Co. Ltd. Japan, with similar text included in the latest technical manual of Yuasa Battery Inc. (USA) : In charging an over discharged battery having terminal voltage of 11,5V or lower, its internal resistance may be too high to be charged at normal voltage. Therefore, raise the voltage initially (25V as max.) and charge. Adjust the voltage as often as possible to keep current at standard value.
TecMate took this principal and designed a circuit that does this all automatically. Here’s how, it applies a high voltage at controlled current to breathe life into the battery and does this for a maximum period of two hours. Once it senses recovery OptiMate shifts to two step constant current charging, then checks if the battery can hold power before switching to safe long term storage charge.
For best results the battery must be removed from the vehicle if over-discharged & sulfated. OptiMate will not start the desulfation mode if it senses vehicle circuitry and automatically lowers the maximum charging voltage to 14,3V to protect sensitive electronic circuitry against damage.
One must bear in mind that not all batteries are of the same design nor are they of the same quality, especially the ‘clone’ / pirate part batteries based on OEM product. Such factors all have a bearing on how successful a particular battery’s recovery from sulfation is. Some battery types may not recover at all from sulfation, what-ever you do. Even those that do may not recover to 100% rated capacity and will retain some effect of the sulfation event, such as a higher self discharge characteristic.
The good news is that from our experience almost all batteries used in the power sport industry are recoverable, especially sealed AGM VRLA types such as manufactured by Yuasa, Hawker Batteries, GS and East Penn. And the sooner the battery is recovered the better the result.
Prevention is always better than cure. Leave the OptiMate3 connected when the vehicle is not in use and it will protect against sulfation, excessive self discharge or current draw from connected devices.
__________________
Old 12-26-2007, 02:51 PM   #6
Chills
Good info, thanks Justin.
__________________
Old 12-26-2007, 03:03 PM   #7
Blah Blah Blah
Sportbike: K6 GSX-R 750, 2004 CRF50
Years Riding: Veteran Poser
Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!Blah Blah Blah Walks on F&?kin water, No shit!!!
That's too high tech for me.
__________________
Blah Blah Blah is offline   Reply With Quote
Old 12-26-2007, 05:05 PM   #8
LsilverR1
Every motor needs a turbo
LsilverR1's Avatar
Sportbike: Had a Liquid Silver R1
Years Riding: longer than paved roads were common
LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!LsilverR1 Walks on F&?kin water, No shit!!!
i noticed there is a lot of battery talk on this site.
ive had 5 bikes in the last 2 years and none of the batteries gave me any trouble. even my friggin john deere tractor i leave in my enclosed trailer all winter and charge it in the spring and its all good. i used a battery tender ONCE (on a car) and the battery was cashed when i went to use it in the spring. i dunno.
__________________
LsilverR1 is offline   Reply With Quote
Old 12-26-2007, 05:48 PM   #9
equipt31
equipt31's Avatar
Sportbike: 2 2004 R6's
How you found us: Another forum
equipt31 FNG
i have this and its actually the simplest thing to use. just hook up your battery and read w/e light turns on. charge till battery is good. that simple
equipt31 is offline   Reply With Quote
Old 12-26-2007, 08:31 PM   #10
SilentAlero
Ashwin you will be missed
SilentAlero's Avatar
Sportbike: 01 Giggy 7fidday
SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!SilentAlero Walks on F&?kin water, No shit!!!
pfft high tech nothin.... just recharged your battery for a while u ride ya pussies. Today was a decent day to recharge em.
__________________
Silent Edition
Custom car audio/video
26 E Lincoln Highway
Frankfort, IL 60423
Silentedition.com - 773-519-5181
Mark Anthony ~
Watching the Cubs lose is the opposite of appreciating a fine wine — it’s like watching a car accident in progress. It’s horrifying, yet gruesomely riveting, and you can’t help but watch and sympathize with the poor souls inside.
SilentAlero is offline   Reply With Quote
Old 03-04-2008, 11:32 AM   #11
Troy
Time to play in the snow!
Troy's Avatar
Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!Troy Walks on F&?kin water, No shit!!!
Anybody use an Optimate on a sulfated battery yet?
I suspect the battery in one of my sleds and the battery in my Deuce need desulfating. Both have some age on 'em and don't take much of a charge from the tender.
Troy is offline   Reply With Quote
Old 03-04-2008, 11:47 AM   #12
Grasshopper
Where & when r we ridin?
Sportbike: Ugly fast ones. Can you keep up?
Years Riding: Long enough to crash a lot
How you found us: Stumbled through a parking lot of an invisible 7-11
Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!Grasshopper Walks on F&?kin water, No shit!!!
Basically, in lammens terms, that device is putting a load on the battery. It's exercising the battery. A battery that just sits on a trickle charger is not exercised. The more a battery is used the longer it lasts.
That's what that thing is doing.
You could buy a 25 dollar battery load tester at Pep Boys and go out in the garage once a week and apply a load to it and get the same results that expensive device is doing.
It's not like the fucking thing is magic or something... LOL!!!!
__________________
Nickbobarooski
Grasshopper is offline   Reply With Quote
Old 03-04-2008, 11:53 AM   #13
Grasshopper
It also hits the battery with an over charge. I'll bet its hitting it with about 14.8 volts DC to burn the sulfur off the plates. It's kinda like a spike of voltage for brief short periods of time. I'm betting it hits the battery with a sign wave. It goes high voltage then low voltage over and over exercising the battery.
__________________
Nickbobarooski
Old 03-04-2008, 12:03 PM   #14
Troy
Troy's Avatar
I can certainly try applying a load to each battery, then a charge.
It does look like the Optimate uses high voltage with low current to desulfate (up to 25V). I'm curious to see if it works.
Old 03-04-2008, 12:12 PM   #15
Grasshopper
LOL!!!! Do not apply 25 volts to a 12 volt battery Troy. I wouldn't apply more than 15 volts to it. Just a load tester would be good enough.
I had a Yusa that lasted 6 years with just a battery tender in the winter.
I think that device is a little over kill anyway. Even if a battery is still good after 5 or 6 years I'd change the damn thing anyway for piece of mind.
__________________
Nickbobarooski
Old 03-04-2008, 12:29 PM   #16
Troy
Troy's Avatar
Both batteries are between 4 & 5 yrs old. I'll probably wind up replacing them soon anyway, but figured now would be a good time to experiment with an Optimate.
Heck, they're only 50 bones. That's less than a new battery and I can probably use an extra charger even if it doesn't work as advertised.
Should I expect some fireworks if this thing applies 25V DC?
Old 03-04-2008, 12:55 PM   #17
A.B.A.T.E.
Registered lunatic
A.B.A.T.E.'s Avatar
Sportbike: 1984 FXE, 1966 Triumph, 2000 FLHTC
Years Riding: Bought new 1984, Riding 32yrs
How you found us: ABATE of Illinois, Chicago
A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!A.B.A.T.E. Walks on F&?kin water, No shit!!!
Anyone got a cost on them??
A.B.A.T.E. is offline   Reply With Quote
Old 03-04-2008, 03:40 PM   #18
AgentofDarkness
AgentofDarkness's Avatar
Sportbike: 05 CBR600RR
How you found us: CBR Forum
AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!AgentofDarkness Walks on F&?kin water, No shit!!!
Quick search on Google shows prices from $50 to $80.
__________________
<---- Irfan
In motorcycle terms, that's like taking your Ducati to a dealer for service, and they hand you back a 1979 backfiring Honda 400 Hawk.. because after all, a bike is a bike.
AgentofDarkness is offline   Reply With Quote
Old 03-04-2008, 03:45 PM   #19
Pete The Greek
im the greek guy
Pete The Greek's Avatar
Sportbike: 2009 Ducati 848, 2007 GSX-R 600
Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!Pete The Greek Walks on F&?kin water, No shit!!!
i used a battery tender all winter, and the bike started up perfectly for me on sunday no problems
battery tenders and fuel stabil FTW
__________________
Pete The Greek is offline   Reply With Quote
Old 03-06-2008, 01:46 PM   #20
PatFitz9
Sportbike: 03 Giggy 1k, 2000 SV
PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!PatFitz9 Walks on F&?kin water, No shit!!!
I used a cover for my bike and a full tank of gas. started right up for me too I do have a heated garage though.
__________________
aka Fat Pat
PatFitz9 is offline   Reply With Quote
Old 03-06-2008, 01:48 PM   #21
Blah Blah Blah
I say a prayer before putting my bike away and another prayer when I fire it up in the spring. It always fires right up. God must ride a Gixxer.
__________________
Old 03-06-2008, 01:50 PM   #22
MM Racing
ReBorn Asshole
MM Racing's Avatar
Sportbike: '05 YZ 250 F
Years Riding: 5 seasons
How you found us: Your Mother
MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!MM Racing Walks on F&?kin water, No shit!!!
I have NEVER winterized shit. Fired up the RC last Sunday no issues, especially with the RC where normal weather starting is occasionally a hassle. I would not use either one of these chargers unless I was leaving for more then 6 months.
__________________
Ian
Not everyone likes RC51's.....only those who like twins messing around between their knees.
MM Racing is offline   Reply With Quote
Old 03-19-2008, 08:09 PM   #23
SENGVIN
Pronto PLEASE !!!
SENGVIN's Avatar
Sportbike: cbr-rr
Years Riding: some
How you found us: Brad Boehmer
SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!SENGVIN Walks on F&?kin water, No shit!!!
can i keep my batteri on this tender all the time???
__________________
The difference is 100mph
SENGVIN is offline   Reply With Quote
Old 03-20-2008, 11:22 AM   #24
LsilverR1
LsilverR1's Avatar
__________________
Old 03-20-2008, 11:42 AM   #25
OldSkoolMC
-= OuterSpace =-
OldSkoolMC's Avatar
Sportbike: Yamaha YZ450
How you found us: Shizzle
OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!OldSkoolMC Walks on F&?kin water, No shit!!!
Yep. I have the same model. It does the job.
__________________
06 Kawasaki BruteForce 750i
09 Yamaha Raptor 700r
- Mike - OldSkool - MC -
OldSkoolMC is offline   Reply With Quote
Old 04-05-2008, 08:08 PM   #26
whitedawg
Ex-Ninja
whitedawg's Avatar
Sportbike: 04 Yamaha R1
whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!whitedawg Walks on F&?kin water, No shit!!!
Well I bought the OptiMate3 today, hopefully it works good! BTW, $55 at Willy World in Joliet
whitedawg is offline   Reply With Quote
Old 04-08-2008, 02:42 PM   #27
whitedawg
Ex-Ninja
whitedawg's Avatar
FYI: Works great! Helped both my roommate and I
Old 04-08-2008, 02:45 PM   #28
Troy
Troy's Avatar
Did either of you have batteries that weren't taking a charge from a Battery Tender??
Old 04-08-2008, 02:47 PM   #29
jrock
jrock's Avatar
You can borrow my Optimate if you want. It has a mode that desulfates the battery. And it will test it and tell you if it is holding a charge or not.
__________________
Old 04-08-2008, 04:32 PM   #30
Rated R
Mr.President-FTMFW!!!
Rated R's Avatar
Sportbike: 2006 750 GSXR Black & Yellow
Years Riding: 1 season (and then some)
How you found us: Wink
Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!Rated R Walks on F&?kin water, No shit!!!
Are these in any stores closer to the city? Or in what's considered the chicagoland area...
__________________
Rhasheeda
2006 GSXR 750
"I never asked for nothing I don't demand of myself
Honesty, loyalty, friends and then wealth"
Jay-Z, Justify My Thug
Originally Posted by Slowass View Post
...I know it's trashy. Hense, the Slowass Experience.
Rated R is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Chicagolandsportbikes.com
All Rights reserved
2000-2009
