| Open Forum This forum is for all off-topic discussion. |
Thread Tools | Display Modes |
#61 |
+1, thats what i've seen but I havn't been into turbos for years. It just lets the car idle for couple of minutes to cool the turbo and prevent coking of oil.
#62 | |
captain motivation
Sportbike: CRF450SUPERMOTO / 06 636
Years Riding: forever
How you found us: friends of the board
unless now they make cars that only run at %100 throttle ![]() if you couldnt control the amount of cfm a engine flows than i guess all performance parts are usless.... and 90% of engine mods are designed to increase air flow just read my earlier post then do some investigating on how engines work and you will understand
__________________
WWW.TEAMSELECTFEW.COM Last edited by bikefreak600; 04-25-2009 at 04:34 PM.. |
#63 |
But what about diesel where there is no throttle plate. CFM entering the motor is the same.
exhaust, when there is a load is getting a stronger exhaust pulse. |
#64 |
Wisconsin FIB
Sportbike: Speed Triple 06 Blue, 94' GSXR 750 (world of hurt- sold)
Years Riding: Since June 2002
How you found us: Pilotx1
See my previous post about the energy balance. The turbocharger is spinning but not spinning fast enough to create boost. When you tip into the throttle on a diesel, you add fuel, which adds to the energy in the exhaust. The additional energy spools the turbo which then creates boost.
#65 |
Wisconsin FIB
And since were talking turbos........mines bigger than yours.
#66 | |
Every motor needs a turbo
Sportbike: Had a Liquid Silver R1
Years Riding: longer than paved roads were common
http://images.google.com/imgres?imgu...a%3DN%26um%3D1 ![]()
__________________
#67 | |
Wisconsin FIB
But, as you pointed out with the rear mount turbo...... it is possible to do it on just flow alone. Efficiency sucks and there is a large amount of lag..... but it works. The rear mounts are an interesting solution to a tight packaging problem in the engine bay. |
#68 | |
Village Idiot
Sportbike: Z1000
What energy are you extracting from volumetric flow? I would look into pressure and heat as the sources of energy. It's simple to figure out. Last edited by Loki047; 04-25-2009 at 10:32 PM.. |
#69 | |
Village Idiot
Sportbike: Z1000
#70 |
I believe the only place to really learn turbos is taking an engineering class.
all the mechanic books I have don't go into detail about how turbos work. Just, it uses exhaust power to build compression on the other side. The end. And not too many books even state, you need a load to set off a turbo. "rely on the rapid expansion of hot exhaust gases exiting the cylinders. These gases spin the turbine blades of the pump" |
#71 | |
#72 |
Village Idiot
Sportbike: Z1000
Pressure and temp. Hmm sounds like something I was saying earlier
![]() And yes the best way to learn about turbos is to take some ME courses specifically some intrrnal combustion engines and thermo. I actually spent half a year on a design project with turbo design and patent application. I am a little rusty but the basicshavent changed. |
#73 |
Wisconsin FIB
I worked at IHI Turbo for a few years. I am definitely more of a supercharger guy as this one is my design. http://www.motivemag.com/pub/feature..._Genesis.shtml
But turbos are fairly easy to learn once you know what the physics are. I was forced to do turbo matching for the aftermarket my first 6 months there........now THAT'll teach you whats going on. If you really want to learn turbos, here's a couple of books. Turbocharging the Internal Combustion Engine, N. Watson - (Out of print, but best book) Advanced Engine Technologies, Heinz Heisler - (Covers alot of engine technology plus a little turbocharging) Fundamentals of Turbocharging, Nicholas C. Baines - (Haven't read it, but colleges have it) Axial and Radial Turbines, Hany Moustapha - (More focused on Aeronautical) Last edited by TripleZ; 04-26-2009 at 10:45 AM.. |
#74 | |
and he runs in a class where he has to compete against cars that all go by the same rules as far as engine size and turbo size. so how is it that he's kickin ass? Ive seen dudes like you preach about how its so much less efficient since the day ppl started doing rear mount setups. and everyday you get proved wrong cuz there are some guys kickin some major ass with rear mount setups.
__________________
#75 |
Sicko!
Sportbike: Suzuki GSXR 600 K6, 00 SV 650
#76 | |
Wisconsin FIB
#77 | |
Village Idiot
Sportbike: Z1000
#78 | ||
Taken from his page... Team Major Sets The Bar in Extreme Radial 11/25/08 - Arriving on Thursday Paul and the team goes a 7.36 @ 203 right off the trailer in testing. The word was out we had the field covered by a minimum of 2 tenths. The next day we would improve on that with a qualifying pass of 7.25 @ 205 and 7.28 @ 204, setting the track records for both ET and MPH. Ok so he's racing against other cars under the same rules and is just as fast or faster. you must not know that much about these classes. there are multiple cars in each class that compete with the worlds most advanced and quality parts. money is no object for the top guys. so this guy is not alone beating up on guys with junk. there are MANY great racers in these classes and the class he competes in is one of the most popular classes. I am not gonna say his setup is more efficient...or even dead equal with a normally mounted turbo setup. but what he's proving is that even if it is "slighly" more inefficient, its not much. See the car in person (I have). doesnt take any longer to spool it than the normal turbo cars. So this info basically says that you need to update your thinking on how this stuff works. Im done taking about this. believe what you want. I have given an example that is pretty damn valid. this is just one example. If you go to the lsx shootout races...you will see a TON of fbodies with 88, 91, 98, 102mm's hanging off the back. and these cars are FLYING. Good luck with your passenger car knowledge...while theres people making 2000+ hp with inefficient turbo setups. ![]()
__________________
#79 | |
just out of curiosity. How do you do the R&D on a turbo? build a prototype and see if it has the correst boost, lag, spool spin etc... if it fails draw a new one on autocad(etc..) and retry with another prototype? and how do you build a prototype turbo cast then finish it up with a CNC machine? those blades have some tight angles.
__________________
Man lives in the sunlit world of what he believes to be reality. But... there is, unseen by most, an underworld, a place that is just as real, but not as brightly lit.....a DARKSIDE. |
#80 |
Village Idiot
Sportbike: Z1000
There is so much bad information here it's aggravating. A remote mounted turbo is always. Yes always a poor alternative to a direct mounted setup. Also if CFM drove turbos remote mounted turbos would not be less efficient. With remote mounts you also I crease your charge pipe to a volume that is less advantagous.
#81 | |
Wisconsin FIB
New turbocharger design relies heavily on multi-axis CFD analysis for the performance side. They try to build the prototype in cyber-space first and run through several iterations before ever cutting a tool. Beyond that, every company has design guidelines for speed, diameters, material limits, clearances, etc. Once the designer is happy with the wheel and housing, prototypes are made by 5-axis CNC out of billet. This is a really cool process to watch and it takes alot of times since your cutting with a very small bit. The prototypes are tested and tweaks are made by Senior engineers. Repeat and continue. The final performance iteration that's approved is again cut by 5-axis CNC. Then finely polished by hand to a mirror like finish. Negative master molds are made from a silicon type substance, then a positive is made from another type of silicon. Once you have a positive flexible mold, the plaster casting molds are made, which you pour the aluminum into. Now that you have a cast wheel, more limit testing is completed. Burst tests, overspeed, high temperature endurance, low temperature starts, etc. Lots of parts are chucked at this point. For the center section. A center section takes a different approach since its more mechanical than flow oriented. Once the bearing, lube, and cooling designs are finished on the internal components, the outer shell is designed to accept a certain range of compressor and turbine wheels, dictated by the peak bearing loads. Prototypes are made from rapid investment cast dies. The parts are then tested for limit conditions, peak compressor speeds, cold and hot endurance, lack of lubrication, min and max bearing clearances. The cool ones are where proximity probes are installed and on a running turbo you can see the different mode shapes that the turbine shaft vibrates at. Hope this answers your question...... and if you have the time and the will..... a Mechanical engineering degree is definitely worth it. Although, strangely....... I still have to bow down to Pilotx1 once in awhile. |
#82 |
Mommys little monster
Sportbike: '01 SV650 Nekkid
Pilotx1 weighs a buck-O-five. I'm not bowing down to him.
I have to remember to be nice to him, he may be helping me with a project this winter. |
#83 |
Sportbike: '03 Gsxr 1000, '04 Zuma
Years Riding: june 2007, since new
hahahaha nothin like commentary withough the backstory from triple
I used to concern myself being as light as I am, that is, until i found out that our bokes test riders are in the 165lb range ready to ride, right where I am... NO RESPRING NEEDED dave bring the springs tomorrow for milenko
__________________
-Jason |
#84 |
Sportbike: Ninja 500
Years Riding: Few months
I like this thread.
Turbo threads always excite me especially on the honda or mustang forums that show up when googling :-DIn the 3 pages of this thread its pretty clear that many people dont really know how a turbo works (not that there is anything wrong with that). Skim through this as a start since it has pics to show you. (since i cant post links yet since i'm a new member here), type in howstuffworks dot com and then turbo in the search bar.
__________________
The silver arrow '97 EX500, Muzzy full 2-1 exhaust, flush turn signals, "Uni" foam filter. |
#85 | |
![]() Paul+Majors+208+MPH+-+7.41+%40+208.23+MPH+(On+Drag+R
__________________
#86 | |
Village Idiot
Sportbike: Z1000
Debating the effciency loss is a valid debate. |
#87 | |
couple more questions if you have time. When a client wants your company to make something. Do they tell you"hey go make this for this application" or do you setup a team and couple engineers come up with ideas on getting general specs. And for R&D type stuff. Special engineers will work on new theories to turbo development? different bearings, cooling systems, picking different metals (steel with 2% carbon, 5% alumn, 10%copper) I only bowdown to pilot for his fabrication skills.
__________________
#88 |
Taledarkside, i think you're leaning a bit more towards the manufacturing end which is different.
__________________
#89 | |
Wisconsin FIB
New hardware is more complex. There is alot of back and forth. Engine CAD models exhanged, packaging and pierce points have to be nailed down, all while achieving the targeted performance. It boils down to, do new parts need to be invented, or can existing technology be repackaged. For R&D, it really depends on the size of the company. A larger company, and you will be either in application engineering (matching turbos, repackaging existing technology, new castings, etc.) or research, which involves new materials, approaches, patent opportunities. Smaller the company, and the more hats you wear. Few firms still have pure research departments, so even as an application engineer, your going to be inventing new technologies for the customer. For me, the best spot to be is in test and development. A design engineer deals with CAD, customer wants, suppliers, pricing, and timetables. A test engineer deals with customer duty cycles, durability, testing, and problem solving. If you break it, you get to invent something to fix it. Much more satisfying. |
#90 |
![]() Join Date: Apr 2002
Sportbike: m900
Years Riding: 9
where does this badboy factor in?
__________________
Chris |
| Thread Tools | |
| Display Modes | |
