hauling 2 bikes in a pickup - Chicagoland Sportbikes
post #1 of 14 (permalink) Old 03-08-2010, 03:03 PM Thread Starter
Addicted
eE jeremy's Avatar
This year i'll be hauling in a '06 silverado 4x4, anything i should be aware of? One bike seems simple enough, but if I have two bikes in the back how do I tie them down, should I add an eye bolt to the center of the bed? Should I run any sort of wheel chock setup or is it ok to just pull the bikes all the way forward and strap them down with canyon dancers?
Shitty Pass Racing #513
eE jeremy is offline
post #2 of 14 (permalink) Old 03-08-2010, 03:26 PM
I have done this in a S10 pick up for about 2 years. It is nice to have wheel chocks if you have them. If not try to get one eye bolt or some type of hook device between the two bikes and it will make for an easier and mark free trip on your bikes. Make sure you wrap the straps with a towel when they crisscross eathother in the front
post #3 of 14 (permalink) Old 03-08-2010, 03:27 PM
I have this same question.
post #4 of 14 (permalink) Old 03-08-2010, 04:47 PM
It's pretty easy. having chocks does make it easier though.
post #5 of 14 (permalink) Old 03-08-2010, 05:08 PM
That picture shows us nothing more than the fact that they fit. Thanks for trying.
post #6 of 14 (permalink) Old 03-08-2010, 05:16 PM
Look closer.
No extra eye thingy needed, using canyon dancers and crossed straps. The Brutale is sitting in a chock, because that make it easier to load the 2nd bike without the straps in the way.
The non-chock method is to load the left bike first and let it sit on its side stand to keep it upright. Load the 2nd bike and strap it in, then strap the first in. Use canyon dancers.
post #7 of 14 (permalink) Old 03-08-2010, 05:17 PM
I just ordered these
http://www.kneedraggers.com/details/...e--611478.html
and this conversion kit for them
http://www.kneedraggers.com/details/...t--611538.html
I would think that + some wheel chocks would make it relatively easy
(i only mention it as I think it'd be easier to tie down from there than from the bars in cramped quarters like that)
post #8 of 14 (permalink) Old 03-08-2010, 06:28 PM
dont forget to lubricate those aluminum threads with some antiseize, AL tenst to gall on itself when threaded adn put under load
post #9 of 14 (permalink) Old 03-08-2010, 09:38 PM
That's all that matter now doooooooooooo it!!!
post #10 of 14 (permalink) Old 03-09-2010, 09:19 AM
I made a guide to locate the front tires of the bikes out of 2x4's. This keeps the front end from moving. Obviously chocks are the best way. The biggest issue without chocks, is lack of tie down points in the middle and lack of angle. Putting the straps from a canyon dancer straight down to the bed, leaves no angle. The bikes rock back and forth a bunch. So strap from the front to pull them forward, and then off of each side of the rears to reduce motion.
post #11 of 14 (permalink) Old 03-09-2010, 09:38 AM
Giant mattress in the middle, one tie down around both, close door. Done.
post #12 of 14 (permalink) Old 03-09-2010, 09:55 AM
Re: hauling 2 bikes in a pickup
Kind of surprised he hasn't gotten the right answer yet.
Get two track bikes. Run first up and lay it in it's side. Run second up and lay it on first. Throw a couple 50lb sand bags on them to make sure they don't bounce. Go to the track
post #13 of 14 (permalink) Old 03-09-2010, 10:09 AM
i have put two dirty bikes in my Dakota, i would not wanna try with two sportbikes that i was worried about scratching. two trackbikes, well hell, i would lean them on each other
post #14 of 14 (permalink) Old 03-24-2010, 11:07 AM Thread Starter
Addicted
eE jeremy's Avatar
Ok think i have it figured out pretty well, what i ended up doing is posted here https://www.chicagolandsportbikes.com...d.php?t=101213
