Wheel swap on harbor freight trailer? - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 04-10-2012, 04:33 PM Thread Starter
Automotive Afficianado
Julian@MotoCARR's Avatar
Sportbike: Trek
Years Riding: 3285 days and counting
How you found us: CLSB found me...
Send a message via AIM to Julian@MotoCARR
Over the weekend I grabbed the HF 40x48 trailer. Reading the manual it states that the top speed with the equipped wheels is 60mph. Anyone ever change the wheels to ones that may have a larger overall diameter? Google search/reviews has people upgrading but for what reason? Reduce empty trailer bounce, higher cruising speeds, reduced bearing wear?
post #2 of 9 (permalink) Old 04-10-2012, 04:43 PM
750
750's Avatar
Sportbike: Hayabusa
Years Riding: Six years
How you found us: Other website
Mine with 12" wheels cruises all day at 75mph, loaded or not. Grease the bearings.
Ross
750 is offline
post #3 of 9 (permalink) Old 04-10-2012, 04:46 PM
larger diameter wheens gets you an increase in tire load rating generally. it wont increase the frame or spring capacity but the tires will fare better also spin slower to generate less wear/heat in the bearings, proper lube will go a very long long way as well
post #4 of 9 (permalink) Old 04-10-2012, 05:56 PM
I had the 8" wheels on mine for 3-4 years with no problem at all and I cruised at 80mph all day. just keep them lubed.
post #5 of 9 (permalink) Old 04-10-2012, 05:57 PM
Lube FTW!
Shelly
post #6 of 9 (permalink) Old 04-10-2012, 09:53 PM Thread Starter
Sportbike: Trek
Thanks for the replies. Bearings are packed and hubs are filled with grease! Is there a typical mileage you repack/check the bearings at?
post #7 of 9 (permalink) Old 04-10-2012, 09:58 PM
shelly, he's asking how often you get lubed and repacked?
post #8 of 9 (permalink) Old 04-10-2012, 10:08 PM
i check/repack mine at the start of every track season which is approx every 3k miles
I refill my bearing buddies before each trip
I check the whole trailer over at the beginning of the track season and anything showing wear gets replaced, i also carry 2 sets of bearings 1 seal adn a bearing cap and cotter pin in the truck just in case, and the spare bearings are prepacked in a sealed container. and i have extra grease in the truck as well.
post #9 of 9 (permalink) Old 04-10-2012, 10:16 PM
This and 13 years here, never had to replace a bearing
