strap question - Chicagoland Sportbikes
post #1 of 27 (permalink) Old 01-09-2009, 09:10 PM Thread Starter
redlinedbimmer's Avatar
Sportbike: 2006 yamaha R6
Years Riding: not as many as I got ridin your mom
Send a message via AIM to redlinedbimmer
strap question
I have the kind of tie down straps that do not ratchet. You just pull it tight, and to release you just press a part on the latch so the strap can slide back. Will its strength/holding power be compromised by driving in snowy weather? I use them to haul my dirt bike on a carrier on the back of an suv so they get will get wet for sure from the slush and stuff getting kicked up on them.
redlinedbimmer is offline
post #2 of 27 (permalink) Old 01-09-2009, 09:15 PM
those are garbage anyway, just get some ratcheting ones
post #3 of 27 (permalink) Old 01-09-2009, 09:16 PM
i disagree. my ancra non ratchet straps are awesome. i doubt wetness will be a factor.
post #4 of 27 (permalink) Old 01-09-2009, 09:20 PM
$26/pc? I would hope so...
My experience with some cheaper non ratchet straps was they became loose after 20 miles. I guess the nice ones hold!
post #5 of 27 (permalink) Old 01-09-2009, 09:20 PM
They will be fine.
post #6 of 27 (permalink) Old 01-09-2009, 09:25 PM
ancras ftw.
as soon as they are good and wet, just give them another tug, cuz the strap itself stretches a bit.
post #7 of 27 (permalink) Old 01-09-2009, 09:25 PM
oh yeah and you can strap the bike down solo super easy, just hop on it and pull one strap per hand. boom done, they hold like crazy. the junk ones are junk though.
post #8 of 27 (permalink) Old 01-09-2009, 09:29 PM
There was an '02 black and yellow F4i belonging to an unmentioned member who has sold and replaced it, ehem, on a trailer I was pulling. Those straps came pretty damn loose...
gotta check out the ancra's!
post #9 of 27 (permalink) Old 01-09-2009, 09:29 PM
what they said. Good friction straps are solid.
post #10 of 27 (permalink) Old 01-09-2009, 09:30 PM
b boy on his k3 liter
b boy's Avatar
Sportbike: 03 GSXR 1000
Years Riding: over 6 years
How you found us: friends
Send a message via Yahoo to b boy
+1 with the pull strap going solo.
you cant go solo with the ratchet set
b boy
03 Gsxr 1000
00 TL 1000R
USAF
USAFHG
b boy is offline
post #11 of 27 (permalink) Old 01-09-2009, 09:31 PM
yah cheep ones come loose easy, especially if wet. ancras, well..not so much.
our work trailer moves about 5-8 bikes per day 3 days a week, and we have some heavy duty ratchets with fuzzy soft ties for the cruisers, everything else gets tied down with ancras..
post #12 of 27 (permalink) Old 01-09-2009, 09:32 PM
mmmm fuzzy
post #13 of 27 (permalink) Old 01-09-2009, 09:33 PM
sure you can if you haz kickstand. put on kickstandz, loosely tie down left side, tie down right side to lift the bike off the kickstand and level
post #14 of 27 (permalink) Old 01-09-2009, 09:33 PM
b boy's Avatar
did he seat on the tank to compress the folks down before pulling the straps. am sure he don;t.
i towed one of my ex bike from NC to IL with the pull strap with no problem without it getting loose or bike moving.
b boy
03 Gsxr 1000
00 TL 1000R
USAF
USAFHG
b boy is offline
post #15 of 27 (permalink) Old 01-09-2009, 09:37 PM
b boy's Avatar
but your bike is not compress totally and can still move. can ( that don't mean it will move either if you do it your way)
b boy
03 Gsxr 1000
00 TL 1000R
USAF
USAFHG
b boy is offline
post #16 of 27 (permalink) Old 01-09-2009, 09:42 PM
i tow alot of bikes daily, very far using this method, and can usually get the fork to within 1/2" of full compression with a non-ratcheting tie down. ratcheting ties, well thats no prob getting full compression, but its prolly not good for anything, and you risk pulling the hook out of the floor or breaking the chock off.
just came back from indy with 4 bikes, and 2 quads from auction with no scary sights once i opened the trailer door when i got back.
post #17 of 27 (permalink) Old 01-09-2009, 09:42 PM
BH
BH's Avatar
Sportbike: KTM
How you found us: find who?
why not?
I use ratchet straps and have loaded the bike solo 100's of times
BH is offline
post #18 of 27 (permalink) Old 01-09-2009, 09:50 PM
b boy's Avatar
Originally Posted by BH View Post
why not?
that is totally fine.
sorry but i never did and am not planning to do it solo with ratchet.
b boy
03 Gsxr 1000
00 TL 1000R
USAF
USAFHG
b boy is offline
post #19 of 27 (permalink) Old 01-09-2009, 11:00 PM
Ancras - just do a half-hitch to finish it off and you'll be fine.
Otherwise - get some Gator Straps, the best out there. $30 a set.
post #20 of 27 (permalink) Old 01-09-2009, 11:01 PM
you can load solo with ratchets very easily, just takes longer.
post #21 of 27 (permalink) Old 01-10-2009, 09:57 AM
Dug2's Avatar
Years Riding: yes
one more for ancras!
sup ryan!
Dug2 is offline
post #22 of 27 (permalink) Old 01-10-2009, 11:43 AM
They are fine..... used them a LOT.
One note..... they stretch a little in wet weather.
One stop about 30 mins in, tighten them...... good to go.
post #23 of 27 (permalink) Old 01-11-2009, 03:06 PM
Sure, the ratchet-less straps may do the trick, but for $25 you can get a set of 4 2500lb rated ratchet straps at WM. Why risk it?
But if you do decide to use the ratchet-less, be sure to compress your suspension. I have had straps loosen from the hook end on really rough roads.
ZstyX12R is offline
post #24 of 27 (permalink) Old 01-11-2009, 05:39 PM
that must be hell on fork seals though, no?
post #25 of 27 (permalink) Old 01-11-2009, 07:50 PM
rockymountainatv has the ratchet ones with the carabiners(sp?) on one end and soft straps on the other, for under $20 for the pair. I've been using them solo for a long time, they are my favorite and do not slip.
I picked up another set recently for a 2nd bike.
I've had the others slip when they've gotten wet, but I had so many I couldn't tell you which brand
post #26 of 27 (permalink) Old 01-11-2009, 07:57 PM
i wouldnt think so. springs maybe
post #27 of 27 (permalink) Old 01-12-2009, 09:38 AM
Ratchets in snow and salt wiill start to corrode and will become a PITA to use. I prefer the cam buckle type and tying the extra slack in a knot so it does not loosen.
