Engine work for sumo - Chicagoland Sportbikes
post #1 of 59 (permalink) Old 02-29-2012, 12:02 PM Thread Starter
This is what happens when you have unwanted water sitting in ur engine for 4 months.
Already replaced the aftermarket piston and rings along with teh cam chain and teh water fubared the cam chain. Problem started when i realized i had a bad head gasket. Well after the gaskets, piston, rings, cam chain, carb clean,removed valves and cleaned, shimmed, new plug the bike would not start. I just got an email from my engine guy this morning that said this
" Bad news, unable to start YZ. Re-checked valve clearance, spark among other things. I only get a rare pop when trying to start. Tried to do a compression check but this motor has an automatic decompression system. With auto on I get 20 psi with it off I get 90psi. Generally you need 100 psi to run and this would be low performance. Unfortunately this is not that great of a test since the rings are not broke in and valves may seal better after running. Also did a leak down test which shows moderate leakage. I attached a pic showing that the valves where rusted in head and needed to be driven out due to water ingestion in combustion chamber. Also adding salt to the wound is that just from kicking coolant is leaking from the base gasket area and water pump mechanical seal. This might seal up once the engine runs.
At this point unfortunately I would recommend taking engine apart again, install new valves, new guide seals, getting a valve job on head, replacing 2 seals and gasket for water pump leak. Seals and gaskets around $70, Valves will have to check but if Titanium around $100 a piece x5 plus head work around $300. I have not checked prices in awhile so these may be off. This is not the best situation due to the fact that this head has suffered damage from water scoring cam bearing surfaces and possibly warpage to head surface."
I hate when shit like this happens. Ugh. At least its before the season starts and I have time to get it fixed and pay for it.
So the question I have is after bringing in my bike for this work to be done what is the going rate for work like this do be done. Granted these are not stock parts since it needs aftermarket piston rings and gaskets. With all this work done is this considered a full rebuild? LOL
post #2 of 59 (permalink) Old 02-29-2012, 12:08 PM
Pringles can user
tnat's Avatar
Sportbike: 2005 YZ250
Years Riding: 1977
How you found us: Geo
Did you talk to tom zont? send him this post, also you can get a used head on ebay for $500 in great shape. call zont.
tell em i sent you.
http://www.tomzontracing.com/
[email protected]
Phone: 847-977-8971
CLICK THE LINK!
http://www.club57mx.com/
Doug Stanhope
tnat is offline
post #3 of 59 (permalink) Old 02-29-2012, 12:08 PM
Leave it up to Uncle Steve to tear up some shit.
wtf is the point in quoting that big ass post...neg rep tnat!
post #4 of 59 (permalink) Old 02-29-2012, 12:09 PM
I thing a twelve pack and some pizza should be enough.
Sport bikers: cheapest motherfuckers on the planet
post #5 of 59 (permalink) Old 02-29-2012, 12:13 PM
See what his total estimate comes to and see if it's fair. I would rather go with a new rebuild than a used head though.
post #6 of 59 (permalink) Old 02-29-2012, 12:14 PM Thread Starter
tell em i sent you.
[email protected]
Phone: 847-977-8971
No I did not talk to Tom yet. I have a tech who is a mechanic and racer working on my stuff right now. With parts and labor I am into it for $600. But I am guessing with the new valves and stuff it is going to push me over the $1000 mark.
post #7 of 59 (permalink) Old 02-29-2012, 12:18 PM
BH
BH's Avatar
Sportbike: KTM
How you found us: find who?
so what does the bottom end look like? Milkshakey?
BH is offline
post #8 of 59 (permalink) Old 02-29-2012, 12:27 PM
Pringles can user
tnat's Avatar
Years Riding: 1977
Originally Posted by Uncle Steve View Post
No I did not talk to Tom yet. I have a tech who is a mechanic and racer working on my stuff right now. With parts and labor I am into it for $600. But I am guessing with the new valves and stuff it is going to push me over teh $100 mark.
your looking at around $350 for oem valves. Look for a used or like new head on flea bay.
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #9 of 59 (permalink) Old 02-29-2012, 12:35 PM
Might as well get everything handled now and know what you are starting with for the season .
post #10 of 59 (permalink) Old 02-29-2012, 01:06 PM
I'm a non-achiever.
shaugdog's Avatar
How you found us: the cops
Man, what are you going to do with all this newfound time you'll have from not having to kickstart that thing for 10 mins everytime?
#313
shaugdog is offline
post #11 of 59 (permalink) Old 02-29-2012, 01:26 PM
Ryan's Avatar
Years Riding: Since 2001
With all the rust on the top end I would be concerned with the bearings in the bottom end. Ask Gus about Jack's 250F. I think every bearing in that motor was junk.
Ryan is offline
post #12 of 59 (permalink) Old 02-29-2012, 01:33 PM Thread Starter
So are you suggesting I replace all the bearings in the bottom end. What about the crank?
post #13 of 59 (permalink) Old 02-29-2012, 01:34 PM Thread Starter
No sh!t huh
post #14 of 59 (permalink) Old 02-29-2012, 01:35 PM
The whole motor is fukd. Start over
post #15 of 59 (permalink) Old 02-29-2012, 01:36 PM Thread Starter
I would if I didn't have $3000 in engine work done to it. If worst comes to worst I will toss my stock 08 engine in. I am waiting to hear back from my mechanic to see what he says.
post #16 of 59 (permalink) Old 02-29-2012, 01:40 PM
You should check all the bearings , IIRC , they had oiling issues . How can it cost 3k for a motor ? That has to be with some very trick parts.
post #17 of 59 (permalink) Old 02-29-2012, 01:42 PM Thread Starter
I will show you the parts and labor list next time I see you.
post #18 of 59 (permalink) Old 02-29-2012, 01:47 PM
I believe you , just sounds a lot to me .
post #19 of 59 (permalink) Old 02-29-2012, 01:58 PM
Pringles can user
tnat's Avatar
Years Riding: 1977
if your gonna do it then get a new crank too, when i talked to tom zont for a total top and bottom end for my 08 yz450 i was lookin at 1500-2000K parts and labor, new piston, rings, valves, springs, crank and minor head work.
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #20 of 59 (permalink) Old 02-29-2012, 02:01 PM
Pringles can user
tnat's Avatar
Years Riding: 1977
ask Roman what his cr cost him he had it done last season. Stop going out drinking 5x a week and in a month youl have enough for 2 motors! Cheap fuck - its funny how cheap fucks we are we have no problem going out to the bar on a friday night and blowing $ 200 on drinks another $300 on blow another $200 on a by the hour Hoe but gawd forbid how cheap we get when it comes to sumo slicks, goggles, engine work looking to save 15$ Muther fucker!
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #21 of 59 (permalink) Old 02-29-2012, 02:03 PM
That price tag is scary. I don't know how you ballers afford the maintainance on those things
post #22 of 59 (permalink) Old 02-29-2012, 02:05 PM
Its cheaper to fix a KTM .
post #23 of 59 (permalink) Old 02-29-2012, 02:07 PM
BH
BH's Avatar
Sportbike: KTM
plus they never break
BH is offline
post #24 of 59 (permalink) Old 02-29-2012, 02:12 PM
Pringles can user
tnat's Avatar
Years Riding: 1977
thats why i bought a 2 stroke 125! cheap!
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #25 of 59 (permalink) Old 02-29-2012, 02:22 PM
This is why I only ride twice a year.
post #26 of 59 (permalink) Old 02-29-2012, 02:25 PM
Shhhhhh.....
chadadams's Avatar
Sportbike: K6 GSXR600, 2012 Harley-Davidson XL1200N
Years Riding: I'm old. It's been a long time.
It sounds broken Steve. I'll give you $2K for it.
CCS Amateur #133
K6 GSXR600
chadadams is offline
post #27 of 59 (permalink) Old 02-29-2012, 02:39 PM Thread Starter
I just emailed Tom Z.
post #28 of 59 (permalink) Old 02-29-2012, 02:46 PM
Pringles can user
tnat's Avatar
Years Riding: 1977
Lay off the blow and booze man!
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #29 of 59 (permalink) Old 02-29-2012, 02:48 PM Thread Starter
LOL dude I havent drank in over a week. When I do I drink my own stuff not some $12 drink in the city.
post #30 of 59 (permalink) Old 02-29-2012, 03:02 PM
Pringles can user
tnat's Avatar
Years Riding: 1977
relax bro, just bored here and fuckin with ya, i know your the cheap fuck who brings a flask into a bar and is gettin pop and poorin your shit in it! Or better yet climbin on the shitter hittin your flask of some cheap ass MD20/20!
Once a grunt always a grunt mofo!
CLICK THE LINK!
Doug Stanhope
tnat is offline
