Anyone know if these rims will fit? - Chicagoland Sportbikes
post #1 of 11 (permalink) Old 04-21-2009, 09:23 AM Thread Starter
Wannabe racer
lovebothkats's Avatar
How you found us: Duh!
I might have a chance to buy some SM rims for my 06' YZ250F but they are from a 03' WR450 anyone know if they will bolt up to my bike?
lovebothkats is offline
post #2 of 11 (permalink) Old 04-21-2009, 12:25 PM
Pringles can user
tnat's Avatar
Sportbike: 2005 YZ250
Years Riding: 1977
How you found us: Geo
Here ya go dave, from TT - so your getting the bug huh? Very Cool.
Wheel Interchange: What fits what?
This is a question that gets asked often but there's never really been a comprehensive reference for the info. The info here applies to hubs from any YZ model used in a YZ400/426/450. Thanks to Bob Russell at RTR Precision Wheel Lacing for helping collect this.
Here's how it works out:
Front Wheels:
The front hub is the same from 1997 to 2001. Uses 20mm bearings. It can be identified by the four cast reinforcement ribs running across the hub.
2002 and up use the same hub. This hub also uses 20mm bearings. It is smooth across the center, with no ribs, and has a larger diameter at that point.
Early Front hubs can be used on 2002 and up by using the 2001 spacers . 2002 hub can be used on earlier bikes by using 2002 and up spacers.
This information applies to all YZ models from 125-450F.
Rear Wheels:
1998 and earlier use the same rear hub, casting number 2VN00 on the hub. Uses 20mm bearings. These will not fit 1999 and later bikes because the axle is too small.
1999 and up use the same rear hub, casting number 5ET. Use 22mm bearings. Any of these can be used in any '99-'08 model by using the spacers from the year model bike the wheel will be used in. There are four different sets of these, each matching up with a change in the swing arm. You need two for each wheel. They're the same on both sides:
1999-2001 (5ET-25383-00-00)
2002 (5NY-25383-00-00)
2003-2005 (5UN-25383-00-00)
2006-2008 (5TJ-2530S-80-00)
Rear wheels from 125's and 250F's have a 1.85" wide rim. All others have a 2.15" wide rims.
Use the spacers that match the year of the bike the wheel will be fit to, and any '99 or later rear wheel will work on any '99 or later YZF.
Some have asked about the fact that the drive side bearing and seal on the '06 up hubs are different than the brake side, or than the bearings on earlier hubs. The bearings are the same dimensions as the earlier hubs, however, and have no bearing (pun unintentional) on their interchangeability with other YZ rear wheels.
Bearing info for '97-up front wheels, and '99-'08 rear wheels:
Front - 6904-2RS - 20mm ID x 37mm OD x 9mm
Right Rear - 60/22-2RS - 22mm ID x 44mm OD x 12mm
Left Rear - 62/22-2RS - 22mm ID x 50mm OD x 14mm
This information applies to rear wheels from YZ and WR models. YZ fronts will fit WR's, but will not drive the odometer, and YZ spacers must be used.
CLICK THE LINK!
http://www.club57mx.com/
Doug Stanhope
tnat is offline
post #3 of 11 (permalink) Old 04-21-2009, 02:26 PM Thread Starter
Wannabe racer
Good info thanks! However that still leaves me in question about the front whee. Sounds like the rear will fit with the correct spacers but front seems to be 450-450 only did I read that correct?
post #4 of 11 (permalink) Old 04-21-2009, 02:27 PM Thread Starter
Wannabe racer
I can't determine if this line "This information applies to all YZ models from 125-450F" is referring to both wheels or just the rear. It's place just above the section for the rear wheel but maybe it wasn't placed there for any reason.
post #5 of 11 (permalink) Old 04-21-2009, 02:55 PM
Dirtbiker's Avatar
I read it that it would work 125-450
Dirtbiker is offline
post #6 of 11 (permalink) Old 04-21-2009, 03:04 PM
Anyone by chance know if some 98 rm125 wheels will fit on a 02 yz250f? ya long shot, but just wondering before i throw them on ebay
post #7 of 11 (permalink) Old 04-21-2009, 03:24 PM Thread Starter
Wannabe racer
Ok in that case I have to find out how much the guy I work with is looking to get for them. We'll see, although if I'm stuck swapping rims I wouldn't expect to see me out there more than 1 or 2 times. I need to follow Jacks example and just buy a second bike but not there just yet. Not sure the rims will even be doable, but they were offered so I owe to myself to investigate.
post #8 of 11 (permalink) Old 04-21-2009, 03:45 PM
Pringles can user
tnat's Avatar
Years Riding: 1977
Swapping wheels from dirt to sumo takes me about 20-30 mins and im in business. No big deal! I beleive you will have no problem with the wr frt wheel just use the YZ spacer. ON thumpertalk Grayracer is the shit when it comes to YZ-WR questions, look in the YZ forum
http://www.thumpertalk.com/forum/sho...+wheels+fit+yz
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #9 of 11 (permalink) Old 04-21-2009, 03:50 PM
Any wheel on any bike any time!!
The true issue is the rear sprocket and wheel width.
post #10 of 11 (permalink) Old 04-21-2009, 04:04 PM
Dirtbiker's Avatar
Just buy one of mine. I have three of them now.
post #11 of 11 (permalink) Old 04-22-2009, 08:45 AM Thread Starter
Wannabe racer
You just keep collecting them don't you
I'm not really in a position to buy another bike at the moment, otherwise I'd already have that 450 that Ofugit sent me as a supermoto twin to my current bike.
