Wiring requirements **change in policy** - Chicagoland Sportbikes
Sportbiketracktime.com This forum is the Midwestern home for STT and their riders. Sportbiketracktime.com
post #1 of 47 (permalink) Old 03-04-2011, 11:35 AM Thread Starter
Defender of the Innocent
Supergirl's Avatar
Years Riding: over a decade
How you found us: YZFRob
Cool Wiring requirements **change in policy**
Fyi:
there are new wiring requirements per stt policy.
#10 under requirements reads
advanced riders only must safety wire oil drain plugs, oil filter and oil fill caps.
intermediate must have a minimum of rtv or silicone dab on the oil drain plugs and oil filter.
** please note that if you spill oil on the track your day is over.
This change in policy will decrease the likelihood of an oil related issue on the track which can ruin everyones day in attendance.
Tea Palella
Midwest Instructor
IMMIGracing
ChicagoLand Bikers.com
Supergirl is offline
post #2 of 47 (permalink) Old 03-04-2011, 11:50 AM
This should be the policy for anyone on the track. Sucks that it isn't
post #3 of 47 (permalink) Old 03-04-2011, 11:57 AM Thread Starter
Supergirl's Avatar
i agree!
Tea Palella
Midwest Instructor
IMMIGracing
post #4 of 47 (permalink) Old 03-04-2011, 12:26 PM
I don't know...
Germany's Avatar
And I always thought that you are fast when you slide ...
j/k this makes a lot of sense to me, althought it needs to be done right, the wire needs to prevent the bolt from rotating...
#19
Germany is offline
post #5 of 47 (permalink) Old 03-04-2011, 12:40 PM
The apex was where?
Power House's Avatar
Sportbike: '07 GSX-R 600
How you found us: A vision.
I am going to assume safety wiring them will supersede the rtv requirement.
Corey aka: phkz24
NESBA "I" #24
Godspeed Ashwin.
Power House is offline
post #6 of 47 (permalink) Old 03-04-2011, 12:41 PM
yes
post #7 of 47 (permalink) Old 03-04-2011, 01:08 PM
Slower Traffic Keep Right
stkr's Avatar
Years Riding: 30+ yrs total
Good revision!
disclaimer: I think ALL groups should have this. The Novice/Beginner groups spill oil also, the only difference is how far off the track they go once they slide.
Midwest Track Day CR #130
STT "A" 130
Track: 2006 GSXR-750
stkr is offline
post #8 of 47 (permalink) Old 03-04-2011, 01:20 PM
Potentially ignorant question but how hard is it to scrape off the old RTV/Silicon when changing the oil?
post #9 of 47 (permalink) Old 03-04-2011, 01:36 PM
Not hard at all, almost peels off.
post #10 of 47 (permalink) Old 03-04-2011, 01:39 PM
Shhhhhh.....
chadadams's Avatar
Sportbike: K6 GSXR600, 2012 Harley-Davidson XL1200N
Years Riding: I'm old. It's been a long time.
I haven't had time to drill my drain plug yet and I leave for Barber this Friday. What do the rules mean by "dab"? A little dab of RTV silicone on one spot to keep it from rotating or do I have to go all the way around it with RTV?
CCS Amateur #133
K6 GSXR600
chadadams is offline
post #11 of 47 (permalink) Old 03-04-2011, 01:40 PM
I don't know...
Germany's Avatar
I did my 1098 plug like that a while back and cleand the surrounding very well and a year later I still try to get the RVT off every time I cange the oil...
I'd safety wire that shit and be done with it...
#19
Germany is offline
post #12 of 47 (permalink) Old 03-04-2011, 01:40 PM
Shhhhhh.....
chadadams's Avatar
by the way....thanks for bringing this up!
CCS Amateur #133
K6 GSXR600
post #13 of 47 (permalink) Old 03-04-2011, 01:41 PM
I don't know...
Germany's Avatar
All the way around, to make sure it stays...
#19
Germany is offline
post #14 of 47 (permalink) Old 03-04-2011, 01:44 PM
Jeebus, how much did you put on, a whole tube?
post #15 of 47 (permalink) Old 03-04-2011, 01:46 PM
Shhhhhh.....
chadadams's Avatar
Crap. I just changed my oil. So, does this mean that I have to take out the drain plug and put RTV around the inside to create a seal, or can I put the RTV on the outside of the plug, sealing it to the case?
CCS Amateur #133
K6 GSXR600
post #16 of 47 (permalink) Old 03-04-2011, 01:52 PM
You should for sure put it all up on the inside, just push half a tube of the stuff up your drain plug hole.
seriously bro, it goes on the outside. better yet, drill the plug for wire and do it right.
post #17 of 47 (permalink) Old 03-04-2011, 01:55 PM
Wisconsin FIB
TripleZ's Avatar
Years Riding: Since June 2002
How you found us: Pilotx1
Easy. You'll want to clean with a contact cleaner before applying the RTV though.
Its easy enough to safety wire the drain bolt when you do a oil change.
TripleZ is offline
post #18 of 47 (permalink) Old 03-04-2011, 01:56 PM
Shhhhhh.....
chadadams's Avatar
Ha.
If I have time before then, I'll just drill it but, if I don't have time, i'm just making sure I'm keeping within the rules.
Thanks
CCS Amateur #133
K6 GSXR600
post #19 of 47 (permalink) Old 03-04-2011, 02:07 PM
drilling the bolt can be done on the bike but its a bitch and a half, also dont just blindly drill the bolt, think about where you are going to tie to inorder to have the wire pulling the bolt tight once its in place, then drill the bolt
post #20 of 47 (permalink) Old 03-04-2011, 02:09 PM Thread Starter
Supergirl's Avatar
Ha.
Thanks
like they said, it's just so much easier to safety wire it.
if you have enough drills, just do it on the bike. yes, that's how i did it when i took out my street bike. one bit might not be enough
for the filter, buy a big hose clamp at auto zone. $.99 or so.
the oil cap is made of plastic and you can drill thru it with a tooth pick
Tea Palella
Midwest Instructor
IMMIGracing
post #21 of 47 (permalink) Old 03-04-2011, 02:11 PM
Shhhhhh.....
chadadams's Avatar
Thanks. I've got the filler cap and the filter done, but I didn't drill the plug. I just moved and I don't know where my drill is...
I know it's the best choice to just SW it. I'm just not sure I'll have it done in time for Barber on Saturday....
CCS Amateur #133
K6 GSXR600
post #22 of 47 (permalink) Old 03-04-2011, 02:26 PM
I thought it was already a rule to have it safety wired in "I", I did that as soon as I got bumped to I.
Shelly
post #23 of 47 (permalink) Old 03-04-2011, 02:36 PM
A bitch. and it looks like sh!t also. Buy a bike form an old racer and try to peel that crap off. Its not to easy.
post #24 of 47 (permalink) Old 03-04-2011, 02:39 PM
Chad jsut silicone it. Next time you change the oil drill it out. Its a bitch to do it on the bike. Yes it can be done as i just did Marrs and I have done my KTM at the track but you will go through a couple of bits
post #25 of 47 (permalink) Old 03-04-2011, 02:44 PM
Shhhhhh.....
chadadams's Avatar
Thanks, Steve. That's the way I'm leaning. I'll have to change my oil after barber and jennings anyway....I can drill it then
CCS Amateur #133
K6 GSXR600
post #26 of 47 (permalink) Old 03-04-2011, 02:51 PM
This.
My bike came safety wired to the hilt. From the bolts on the brake calipers, drain plug, coolant cap, grips, pinch bolts on the front axle, to the fuckin bolt on the rear axle.
post #27 of 47 (permalink) Old 03-04-2011, 03:56 PM
I used a 3m silicone before I safety wired all my shit, and I was able to peel it off nicely - I guess using a high quality, high heat silicone makes a difference.
post #28 of 47 (permalink) Old 03-04-2011, 03:56 PM
nope it was recommended and urged but not required
mine was done while i was still in N and i keep adding more when im bored
post #29 of 47 (permalink) Old 03-04-2011, 03:57 PM
or... your bike was all greasy and dirty and the silicone didnt stick worth a shit
post #30 of 47 (permalink) Old 03-04-2011, 03:57 PM
I don't know...
Germany's Avatar
That must be it... mine still sticks all over the bike...
#19
Germany is offline
