Xbox 360 issues... seeking help - Chicagoland Sportbikes
Video game forum For discussion about games and strategy's Please keep console specific content in the appropiate subforum.
post #1 of 17 (permalink) Old 02-21-2011, 04:22 PM Thread Starter
batterytenderismyfriend!!
Sportbike: 2009 Yamaha R6s
Send a message via AIM to ivopivo
My Xbox 360 started making "scratching" noises over the past couple months and it got progressively worse. When it first started, I would get a disc-read error message every couple weeks, but it worked just fine, with some noise. Presently, I can't play more than 10 minutes without the error popping up and the noise is worse.
I opened up the box and drive and didn't see anything wrong... everything seems to be in the right place. After I took it apart and cleaned it, I tried playing with everything open, and it worked fine for a bit without ANY noise. So I figured I might have cleaned something important off, or done something similar to fix it. Fast forward 5 minutes... everything's put together, working fine with no noise for 5-10 mins, then back to normal and error pops up again.
Any ideas on how to best fix this, or what "this" is actually?
I wanted to see if anyone here had experience with this before shopping around for disc drives and/or parts.
Thanks.
-Ivan
ivopivo is offline
post #2 of 17 (permalink) Old 02-21-2011, 04:24 PM
you need a new drive.
post #3 of 17 (permalink) Old 02-21-2011, 04:33 PM Thread Starter
From the little research I did, I found if replacing a hard drive you need to re-flash something? What exactly is that whole process and can anyone do it or is it something to leave for an expert? I also heard it might be easier to just replace the part of the drive so you don't have to do the whole re-flashing, but I'm an electronics newb so no clue which direction to take.
-Ivan
ivopivo is offline
post #4 of 17 (permalink) Old 02-21-2011, 04:35 PM
no, the dvd-drive. search around. there's 3 different types i think, and you can tell by the tray which type you have.
if you are a noob to this stuff, you might consider buying a new one, or sending that one off for repair.
post #5 of 17 (permalink) Old 02-21-2011, 04:40 PM Thread Starter
MY mistake! I meant to say the dvd-drive... I heard it might be easier to replace the part that's defective instead of the whole drive. What exactly is required to replace the whole drive? The re-flashing I read about?
Oh and I have the Benq one.
-Ivan
ivopivo is offline
post #6 of 17 (permalink) Old 02-21-2011, 04:42 PM
once you get the casing open(not so easy) replacing the actual cd drive is easy, you shouldnt need to reflash anything as long as the cd drive is replaced with a like model
post #7 of 17 (permalink) Old 02-21-2011, 04:48 PM
Sportbike: R6, SV1000s, rm250
yeah, the drives themselves are cheap like $35 online, breaking the case open is a pita, but mine's been running great since I swapped the dvd drive out.
post #8 of 17 (permalink) Old 02-21-2011, 04:48 PM Thread Starter
See post #6 here... http://forums.xbox-scene.com/index.php?showtopic=565113
This is the type of info I have come across. People saying that if the drive is replaced, something will need to be reflashed. I'm fine with taking apart the hardware, as I have already taken apart everything to clean up the laser and check for the magnets, but the software stuff is all new to me and I have no clue what's necessary to properly replace the drive.
EDIT: A friend of a friend did the whole "flash/hack" so I can play burned games... even though I only play COD and Fifa11 which were both purchased at the store!
-Ivan
ivopivo is offline
post #9 of 17 (permalink) Old 02-21-2011, 04:52 PM
you don't have to "flash it"
There's a little part that is the drive id and that's attached via a ribbon. There's a youtube vid on how to do this but you take that drive ID out of your old drive and put it in the new drive and the xbox won't know the difference. Least that's what I did for a flashless install.
post #10 of 17 (permalink) Old 02-21-2011, 04:53 PM
i think you have to flash if you go to a different brand of drive. if you replace your benq with a benq, shouldnt be a problem.
post #11 of 17 (permalink) Old 02-21-2011, 04:55 PM Thread Starter
I see. I'll look around for the vid but if you could link me to the one you're talking about that would be great. I'm just going to order the drive online. Any recommendations where to order from?
-Ivan
ivopivo is offline
post #12 of 17 (permalink) Old 02-21-2011, 05:00 PM
im gonna be resoldering my xbox this week to hopefully fix the rrod i got a few weeks back, if it doesnt work ill just eventually send it in for repairs, its not like im gonna break it, as its already broken hahahah fuckin msoft
post #13 of 17 (permalink) Old 02-21-2011, 05:04 PM
quick google product search...
http://www.google.com/#sclient=psy&h...a69e3db245d910
post #14 of 17 (permalink) Old 02-21-2011, 05:15 PM Thread Starter
^^ Thanks. I came across this video which I think is pretty good... http://www.youtube.com/watch?v=5XiYSV9ztVU
So basically you just swap the circuit boards (or whatever the proper term is for it) and it should be fine...
-Ivan
ivopivo is offline
post #15 of 17 (permalink) Old 02-21-2011, 05:18 PM
that's all I had to do.
post #16 of 17 (permalink) Old 02-21-2011, 05:32 PM Thread Starter
Just ordered with 2 day shipping. Thanks.
-Ivan
ivopivo is offline
post #17 of 17 (permalink) Old 02-25-2011, 02:14 PM Thread Starter
Well it's fixed and I'm back to 2hrs of FIFA 11 per night!
Ordered a drive from here... http://www.gaingame.com/dvd-replacem...benq%20vad6038
It says new but the drive seemed like it's been worked on for whatever reason... seals were broken and there was "smudge" on the case.
Either way, a straight swap didn't work so instead of messing with all the soldered connections to swap the circuit boards, I just swapped out the "spinning thing" by cutting the three wires and taping them up to the old unit. Used the new case as well and everything works perfectly.
So in case anyone needs a laser from the benq drive or other parts, let me know as I only took out the one part from the drive I ordered.
-Ivan
ivopivo is offline
