heated grips on a scooter - Chicagoland Sportbikes
Scooterific! The place for all your scooter talk.
post #1 of 27 (permalink) Old 09-30-2008, 03:44 PM Thread Starter
interested in putting heated grips on my zuma. how much power they pull? will the tiny electrical system handle it?
post #2 of 27 (permalink) Old 09-30-2008, 03:47 PM
http://www.dual-star.com/index2/Ride...d_grip_kit.htm
theres what I have on the Strada.
post #3 of 27 (permalink) Old 09-30-2008, 03:50 PM Thread Starter
36 watt pull? mmm interesting, and pretty cheap too. the zuma has tiny grips on it.. hopefully these fit.
post #4 of 27 (permalink) Old 09-30-2008, 03:54 PM
ya they are not as wide as normal grips. they should fit perfect. I also got the water proof toggle switch with mine.
post #5 of 27 (permalink) Old 09-30-2008, 04:51 PM
36w=3amps at 12v... mine has trouble charging the battery sometimes... youll be running off the battery primarily when at or close to idle.
post #6 of 27 (permalink) Old 09-30-2008, 05:28 PM
Audiofyl's Avatar
Sportbike: 600rr & Zuma125
Years Riding: since 2002
you crying about cold hands already? it's not even in the 40s.
2003 CBR600RR
2009 Zuma 125
2005 VW Golf TDI
1994 Honda Civic Turbo
My Fuelly
Flickr
posterous
Originally Posted by shadrach
Audiofyl is offline
post #7 of 27 (permalink) Old 09-30-2008, 05:29 PM Thread Starter
mine doesn't have wind protection like yours!
post #8 of 27 (permalink) Old 09-30-2008, 05:31 PM
Is this just rough on the scooter battery or would it put some stress on a regular bike too?
post #9 of 27 (permalink) Old 09-30-2008, 05:31 PM
Audiofyl's Avatar
I bet you could buy those parts for cheap.
and a 3a draw is pretty minimal, even considering the small charging system on the bike. most times a cell phone charger for your cigarette lighter has a 2 or 3 amp fuse in it to give you some type of comparison.
2003 CBR600RR
2009 Zuma 125
2005 VW Golf TDI
My Fuelly
Flickr
posterous
Audiofyl is offline
post #10 of 27 (permalink) Old 09-30-2008, 05:32 PM
depends on how the MFG spec'd out the electrical system specifically the generator/alternator adn how much head room it has for generation above what the vehicle draws in stock form.
post #11 of 27 (permalink) Old 09-30-2008, 05:33 PM
theyve got that fuse cause a short in that product will blow the fuse, the chargers dont draw nearly that much, they pull .5a approx
post #12 of 27 (permalink) Old 09-30-2008, 05:35 PM Thread Starter
i hooked up an extra high beam headlamp on the scooter, with no issues, i'm sure that pulls just as much as the heated grips, i could disconnect that when i'm using the heated grips and it should be ok.
post #13 of 27 (permalink) Old 09-30-2008, 05:38 PM
then were good, go for it, the buld is probably a 45 or 55w right?
putting it at 4-5 amps for the extra lanmp
post #14 of 27 (permalink) Old 09-30-2008, 08:29 PM
plotts's Avatar
Sportbike: KTM 690 SM
Years Riding: A little bit.
Buy some heated gloves instead maybe.
plotts is offline
post #15 of 27 (permalink) Old 09-30-2008, 08:32 PM
good thought, cause the grips only heat the inside of the hand, where the outside takes the cold breeze. Any links?
post #16 of 27 (permalink) Old 09-30-2008, 09:43 PM
Don't stare for too long
GPz1100's Avatar
Just installed a pair of symtec grip heaters today. Look very similar to the ones linked above.
I didn't take any measurements, but another cog member measured his out at 1.9A @ 14.2V on low and 3.37 @ 14.2V on high - this is with the bike running, so 27W and 48W respectively.
Riding around tonight with the same gloves as I've used last fall, my hands were relatively toasty. Finger tips is what usually got cold and numb. Still got cool, but not numb. We'll see what it's like when it gets into the 40's. Had I had full gear on, I'm sure tonight would of been very comfortable. Without the helmet and a recent hair cut, it did get a bit chilly.
I found running them on low was not enough, and kept it on high the whole ride.
I mounted mine similarly as here - http://www.pbase.com/fredharmon/heatedgrips .
GPz1100 is offline
post #17 of 27 (permalink) Old 09-30-2008, 11:28 PM
Unregister User
smurph's Avatar
How you found us: Dumb luck!
If you ride your Zuma like I ride mine to work it is usually WFO most of the way to work just so I don't run over. Should charge just fine. Though with my stock wired headlight when I rev it it gets quite a bit brighter.
Nesba #74 I
smurph is offline
post #18 of 27 (permalink) Old 09-30-2008, 11:32 PM
is there any other mode of operation
post #19 of 27 (permalink) Old 10-01-2008, 07:05 AM
Alex....pictures of the switch location please....I have to install the dual stars on a Vespa, looking for ideas.
post #20 of 27 (permalink) Old 10-01-2008, 07:09 AM
Tony do the dual stars come with the water proof toggle switch now I have had mine on since 2005, standard toggle, and have floated thru build an ark type storms zero problems....in fact everyone I ride with have the standard toggle.
post #21 of 27 (permalink) Old 10-01-2008, 09:23 AM Thread Starter
pretty much WOT is my commute
post #22 of 27 (permalink) Old 10-01-2008, 04:19 PM Thread Starter
found these;
http://cozywinters.com/shop/wg-mhlg.html
or they make just liners too;
http://cozywinters.com/shop/wg-phgl.html
post #23 of 27 (permalink) Old 10-02-2008, 12:22 AM
GPz1100's Avatar
Small update on the grips I mentioned earlier. Got a chance to try 'em out good tonight from bike night.
According to the weather sites, it's ~50F outside. The heat provided by the grips was adequate. Not super warm (probably due to my thick grips), but enough to make a difference in comfort. My fingers did not go numb at all, and just the top of the hands were a bit cold. For $35, it was a worthwhile upgrade.
The bike/windshield took care of keeping the rest of me warm. Had I remembered to close the vents in the helmet, that would of been even better.
GPz1100 is offline
post #24 of 27 (permalink) Old 10-02-2008, 12:49 AM
Audiofyl's Avatar
check it.
http://www.scooterwest.com/item_deta...ed-Grips/1408/
2003 CBR600RR
2009 Zuma 125
2005 VW Golf TDI
My Fuelly
Flickr
posterous
Audiofyl is offline
post #25 of 27 (permalink) Old 10-02-2008, 09:01 AM Thread Starter
Eric, nice! i bet those are better than sticking an element under the grip too, prolly better heat transfer! nice, i might have to look into those.
post #26 of 27 (permalink) Old 10-02-2008, 09:19 AM
more espensive too
post #27 of 27 (permalink) Old 10-02-2008, 10:10 AM
Audiofyl's Avatar
I'm still disappointed that their zuma125 section is "coming soon"
We have a ton of Zuma 125 items on the way, just in time for it's USA debut next month.
yea, well it's past that time, because i've had mine for a month!
2003 CBR600RR
2009 Zuma 125
2005 VW Golf TDI
My Fuelly
Flickr
posterous
Audiofyl is offline
