Driving with low tire pressure - Chicagoland Sportbikes
post #1 of 41 (permalink) Old 02-04-2011, 02:14 AM Thread Starter
yo quiero su taco
whiteSeatEnvy's Avatar
I put about 75 miles on a brand new low profile all-season tire that only had 22 lbs of pressure in it. Is the tire shot?
whiteSeatEnvy is offline
post #2 of 41 (permalink) Old 02-04-2011, 02:18 AM
no. if it had 10psi it might be. the sidewall isnt jacked up, is it?
post #3 of 41 (permalink) Old 02-04-2011, 02:20 AM Thread Starter
yo quiero su taco
To tell you the truth I am not sure which tire it was. I thought the low tire pressure warning light was the traction control light. After about 75 miles I noticed that it was in fact not the traction control. Took it to the dealer and they filled it up, but I didn't ask which tire it was. I did a visual on all the tires and the side walls all look fine.
post #4 of 41 (permalink) Old 02-04-2011, 02:35 AM
Pathological Thrill Seekr
Deuces's Avatar
Sportbike: Trek Marlin
Years Riding: Noob
Sidewalls good = Tires good. May notice some excessive wear in the future, but are good for now.
Ride smart... stupid hurts.
Godspeed 788!!! We miss you!
Deuces is offline
post #5 of 41 (permalink) Old 02-04-2011, 02:47 AM
Thee original azzhole!
Thunderstruck's Avatar
How you found us: i see all
Not with today's tires. They r made to run on a lower pressure because all rims leak. Period. What I do, and others will say I'm nuts for doing it, is this.
I NEVER go off what the recommended pressure from the factory of the car manufacturer. I go by what's actually the max PSI on the tire. Then I drop down 5 PSI. It does 2 things. It improves fuel economy, and handling aspects. So say your car comes with Goodyear tires (which I think all of them are the biggest pieces or shit tires ever made from a manufacturer)...so your car is set to these specs from the manufacturer.
But I now drive on bf goodrich on my ride. Set the psi to what the car man specs were at 35psi. Saw my mpg drop by 5%-10% at least. I then looked at the max psi on the tire, and it was 43psi max. So I bumped it back to 38psi and my fuel economy went right back to where it was. And my handling increased also. At 5 less psi from max psi, it allows movement when the tires warm up. Also, nitrogen filled tires really do seem to hold pressure better with less leaking. But others may disagree. But that's what I do. And I'll stick by it for life
mmmm pussy
Thunderstruck is offline
post #6 of 41 (permalink) Old 02-04-2011, 03:20 AM
Deuces's Avatar
Years Riding: Noob
75 miles won't show. Do it repetedly and you might have some issues. Drive it like ya stole it!
Deuces is offline
post #7 of 41 (permalink) Old 02-04-2011, 04:05 AM
you know that pressure is set by engineers that dedicate their whole lives to designing and building these cars? they factor vehicle weight, suspension stiffness and a bunch of other variables to get to that optimal pressure. running higher than recommended pressure wears your tires and suspension out faster, not to mention rides like shit. i find it hard to believe that you are gaining 5%-10% at least by jacking your tires up 3psi
post #8 of 41 (permalink) Old 02-04-2011, 04:08 AM
also, not all rims leak. i believe the pressure lost over time is actually thru the tire itself.=
post #9 of 41 (permalink) Old 02-04-2011, 04:08 AM
Deuces's Avatar
Years Riding: Noob
This is for OEM tires. Pressures for different tires varies.
Deuces is offline
post #10 of 41 (permalink) Old 02-04-2011, 04:08 AM
Deuces's Avatar
Years Riding: Noob
Although the pic is correct for the tire wear. :-)
Deuces is offline
post #11 of 41 (permalink) Old 02-04-2011, 04:13 AM
Actually, it doesn't. The sticker is for the recommended size on that vehicle. Tire company doesnt really matter.
post #12 of 41 (permalink) Old 02-04-2011, 04:30 AM
majority of the leaks are from the bead. But you have the tire people remoun the tire with some sealer.
but i agree with you that thunderstruck doesn't know what hes talking about.
you can't really inspect the inside, but if the sidewalls look fine on both sides, i wouldn't worry too much. but you can have tread seperationlike those suvs back in the day.
post #13 of 41 (permalink) Old 02-04-2011, 08:23 AM
he who is absent foreskin
Loki047's Avatar
Sportbike: Z1000
I would not run the max psi for a tire. Especially if you set that pressure with the tire being cold.
Jordan
Loki047 is offline
post #14 of 41 (permalink) Old 02-04-2011, 08:33 AM
black magic
bio-nuke's Avatar
Sportbike: gxr600k8
Years Riding: 4yrs
at my work (not retail) we do 5 under max psi
we also use soap not bead sealer
i have low profile tires and a bubble on the sidewall since last winter. i drove it to atlanta and all around. i'm sure my tires are also low and i drive over a few train tracks everyday.
my point is relax
yes yes i know one day the tire will blow or go flat
bio-nuke is offline
post #15 of 41 (permalink) Old 02-04-2011, 09:07 AM
no.. they are not made to run at lower pressures. they are just built better that tires 20 years ago.
post #16 of 41 (permalink) Old 02-04-2011, 09:24 AM
Seriously Mike??? Do you also hypermill? I've went through many a set of tires and run them at mfg spec and have never had any issues with uneven tire wear or driveablity. If you inflate your tires to 5 below tire max then you're probably running at max after they warm up. That's just a recipe for blowout disaster an unnecessarily harsh ride. Improved gas mileage is not a worthy compromise for impending disaster.
post #17 of 41 (permalink) Old 02-04-2011, 09:27 AM
Put a scope on each of them. It's the only way to be sure. Also, since there's a leak - it failed.
post #18 of 41 (permalink) Old 02-04-2011, 09:34 AM
your running low profile tires with the fattys you pick up?
post #19 of 41 (permalink) Old 02-04-2011, 09:35 AM
I always thought proper pressure is related to load. The max psi is based on the load of the tire. You only run the number on the sidewall when you are carrying near the max load.
post #20 of 41 (permalink) Old 02-04-2011, 09:49 AM
id agree with the above saying not to go so high mike, 5under max cold will be over max when warmed up
I have a habit of running my cars tires at 5 psi over the mfg plate, I also NEVER use the gas station filler gauge, those things get the living hell beat out of them
running the tires at well above recommended pressure give negligible increases in milage but running low really kills milage
when i did a few autocross events i ran the tires at the max pressure but that was simple to reduce sidewall squirm, the runs were about a minute long and there was probably 30 mins between runs, at the end of the day i let air out to put the pressure back to normal
post #21 of 41 (permalink) Old 02-04-2011, 10:09 AM
What temperature range is it really when they say 'cold tire pressure' ?
post #22 of 41 (permalink) Old 02-04-2011, 10:56 AM
Loki047's Avatar
Sportbike: Z1000
Originally Posted by arch View Post
what temperature range is it really when they say 'cold tire pressure' ?
-273 c
Jordan
Loki047 is offline
post #23 of 41 (permalink) Old 02-04-2011, 11:14 AM
beac83's Avatar
Sportbike: A couple
^ fail.
At -273C you couldn't measure tire pressure with a gauge, as the atoms of the air wouldn't move at all. Of course, there would be no leaking from the rim, either. And the vehicle wouldn't move anyway.
________________
beac83 is offline
post #24 of 41 (permalink) Old 02-04-2011, 11:16 AM
Loki047's Avatar
Sportbike: Z1000
Originally Posted by beac83 View Post
^ fail.
haha technically its -273.15C for absolute zero.
That 0.15C makes it a balmy almost absotlute zero... Although it would probably take some time for the gauge to read.
Jordan
Loki047 is offline
post #25 of 41 (permalink) Old 02-04-2011, 12:51 PM Thread Starter
yo quiero su taco
The issue is I am trying to decide if I want to press them to replace the tire. Will I have issues down the road?
post #26 of 41 (permalink) Old 02-04-2011, 12:58 PM
if there's no damage to the sidewall, the tire should be fine. if there's not a problem now, one isnt going to develop down the road. all the lettering is there on the sidewall, and no groove worn in, right?
post #27 of 41 (permalink) Old 02-04-2011, 01:02 PM Thread Starter
yo quiero su taco
correct, thx brotha
post #28 of 41 (permalink) Old 02-04-2011, 01:36 PM
IMHO no 75 miles in cold weather at 22psi did nothing adverse to the tire, the chances of overheating damage is low cause its cold out
Overheating is probably the prime cause of tire destruction when run at low pressure outside of impact/ object damage
post #29 of 41 (permalink) Old 02-04-2011, 06:13 PM
Arch would drive his car if all these things leaked and would consider his AWD car not a failure
oil pan
heater hoses
radiator hoses
fuel lines (since leaking fuel is okay in arch's liberal book)
transmission lines (since we know low trans fluid will make the trans not work(auto)
power steerng fluid
Brake lines (arch thinks brake fluid leaking is okay since no hyraulic fluid isn't necessary for a hydraulic braking system)
NWS
post #30 of 41 (permalink) Old 02-04-2011, 09:34 PM
I found that my two tire gauges were 5 psi apart from each other. Which were both 5 psi off of a good calibrated one. So I was running 50 psi instead of 40. So does any of this really matter?
