Car Tech ?-Honda Pilot A/C Dead - In friggin Nashville! - Chicagoland Sportbikes
post #1 of 4 (permalink) Old 07-02-2011, 05:52 PM Thread Starter
Pringles can user
tnat's Avatar
Sportbike: 2005 YZ250
Years Riding: 1977
How you found us: Geo
If there's any A/C or car techs out there, 4 hrs into our trip to Nashville to see the In laws our 03' Honda Pilot A/c starts blowing hot air. I turned it off for a little and turned it back on and it worked for about 3 mins and then went hot again. Stopped got some freon, hooked up tank and the low side read 175 psi. I let stuff out to pump in new stuff and it went to the moon again reading 175psi - with air on or off. I'm thinking there's something clogged somewhere in the low side lines. Is there some type of valve that can stick shut to cause the High PSI as its supposed to be around 55psi. I here the clutch on the compressor click on when i turn on the ac. THis sucks its like 100deg down here!
CLICK THE LINK!
http://www.club57mx.com/
Doug Stanhope
tnat is offline
post #2 of 4 (permalink) Old 07-02-2011, 06:03 PM
ac is my weakness
what is the low side reading when the compressor is kicked on?
you can have a stuck(clogged) orifice tube its like a little filter or screen
you can have moisture in the system and it froze in the line.
i had no sleep, so hopefully it makes sense. worse things is metal broke off from compressor and clogging one of the lines. accumulator bad
post #3 of 4 (permalink) Old 07-02-2011, 07:18 PM
Take it to am AC, have them vacuum the system negative to see if holds. If so refill and go again.
Ps it 100 up here too...
post #4 of 4 (permalink) Old 07-02-2011, 11:20 PM
Richfiero's Avatar
Sportbike: 06 Ninja zx636
Years Riding: 6 years
How you found us: no
Is your cabin air filter dirty? Could be icing the evaporator. How is the condenser it’s in front of the radiator, check if the fins are bent or dirty? This would not let heat leave the system. Home AC guys might know more about it too.
Richfiero is offline
