sometimes you dont need to scope it - Chicagoland Sportbikes
post #1 of 10 (permalink) Old 07-14-2011, 03:43 PM Thread Starter
post #2 of 10 (permalink) Old 07-14-2011, 04:16 PM
beac83's Avatar
Sportbike: A couple
Oooh, you let the smoke out. Now it'll never work!
________________
beac83 is offline
post #3 of 10 (permalink) Old 07-14-2011, 04:56 PM
true dat.
But you did scope it to find out that was the problem right, or how would you have known to start with coil pack.... Let me guess you had no spark
post #4 of 10 (permalink) Old 07-14-2011, 05:19 PM Thread Starter
Originally Posted by JRSMAIL View Post
true dat.
Misfire code
it lacked power. And someone already changed the plugs and wires on it. changing the coil pack gave it power again. But it still had a misfire code.
believe the EGR passenges were clogged for some of the cylinders and that confused the computer and said one of the cylinders was running at a different speed than the other cylinders. Cleaned out the EGR ports and that fixed the misfire code.
post #5 of 10 (permalink) Old 07-14-2011, 05:24 PM
Ride Naked
mac11's Avatar
Sportbike: z1000
what sensor was telling the computer about the speed of the individual pistons?
mac11 is offline
post #6 of 10 (permalink) Old 07-14-2011, 05:27 PM Thread Starter
combination of the crank and cam sensors
post #7 of 10 (permalink) Old 07-14-2011, 05:29 PM
Ride Naked
mac11's Avatar
Sportbike: z1000
i'll play.
even if those were telling the computer different things, how does it tell the computer which cylinder is spinning slower/faster?
mac11 is offline
post #8 of 10 (permalink) Old 07-14-2011, 05:37 PM Thread Starter
i'll play.
using the computers clock, processor. it uses that for time. And a cylinders rotation speed from cylinder 1 to cylinder 2(assumption) it will measure how long it takes.
a misfire shows a weak cylinder with a rpm drop, something that OBDII detects for.
post #9 of 10 (permalink) Old 07-14-2011, 05:38 PM
^lol
post #10 of 10 (permalink) Old 07-14-2011, 05:53 PM Thread Starter
i'll play.
didn't really read your thing
the crankshaft has "teeth" on them, and usually there would be one that is missing one, so the computer knows which one is Number 1 cylinder. Each cylinder creates a voltage. And the computer already is programed to know the firing order. And it counts how many voltage was created in the amount of time. If it doesn't add up to the number of voltage created, it will set a crankshaft sensor error, and set a check engine light.
