I need a mechanic! - Chicagoland Sportbikes
post #1 of 75 (permalink) Old 10-03-2011, 06:20 PM Thread Starter
tcmalker's Avatar
Sportbike: FZ6
How you found us: fz6 forum
I need a mechanic!
Ok, so I tried a little DIY project over the last three days: installing a backup camera on my wife new CRV. Yes brand new, 2011. I also bought a Gentex mirror so she can view the backup video on it.
It's a little tougher than I thought, but I'm like 90% done. Until I decided to 'test' if the cable had juice. All of a sudden the car's making noise and I knew I have shorted something. I can't start the car, or if it does start it shut off right away. I can't get out of Park. I can't roll up my windows.
So I started checking the fuses and found a blown one. It was a 7.5amp fuse labeled "Meter". I did not check all the fuses but about 75% of them. I replaced said blown fuse and car starts, but now it has a check engine signal. So what's the deal, is it all fixed or is there other problem I don't know about.
Another thing I notice is the anti-theft light on the radio is constantly on, whether the car is alarmed or not. Is this normal?
tcmalker is offline
post #2 of 75 (permalink) Old 10-03-2011, 06:34 PM
get the code checked
lulz on the situation
post #3 of 75 (permalink) Old 10-03-2011, 07:05 PM
Gone In 3's Avatar
Sportbike: CBR1000RR
How you found us: Folks
Gone In 3 is offline
post #4 of 75 (permalink) Old 10-03-2011, 07:46 PM
very likely it will have to go to a dealer... youve shorted something and it triggered the security in the ecm basically disabling the vehicle
post #5 of 75 (permalink) Old 10-03-2011, 07:58 PM
This is why there are certifications for car audio, video, and navigation.
Called me before, I would have helped. Now, get the code pulled and expect a trip to the dealer.
post #6 of 75 (permalink) Old 10-04-2011, 01:42 AM Thread Starter
tcmalker's Avatar
Sportbike: FZ6
I wanted to do this myself, I actually learned a lot from it. I am very proud. I think once I disconnect the battery and reset the ecu, the engine check light will go away. The only damage is the fuse!!!
I've been trying to do things myself. For example, I changed my own oil in motorcycle. I installed Leo Vince myself, very proud of that!
Frankly, I just don't trust other people around my vehicles.
tcmalker is offline
post #7 of 75 (permalink) Old 10-04-2011, 02:12 AM
Problem is new vehicles have everything integrated to the ECM now. Unless you are real familiar with automotive electronics, its best to just have someone who has done it before. And have a wiring schematic for the vehicle also.
Be glad you didnt mess with the yellow wires under the dash. Those are SRS wires (air bags).
Dave, I've seen some of these people who are "certified" for audio/video/nav do more damage than someone who has never touched a wire stripper in their life. Like one retread who screwed an amp in the trunk of a car and put the mounting screw into the gas tank. That one got me a good laugh.
post #8 of 75 (permalink) Old 10-04-2011, 02:20 AM
Speaking of being certified, he could have damaged the BCM, not ECM.
Wow. You are proud that you fucked up your brand new vehicle. CP's wife must be proud as a peacock. This had what, three wires to connect?
How did you "test this wire to see if it had juice"?
OBD2 does not clear codes by pulling the battery cables.
This thread has to be a joke. Please tell me it is.
post #9 of 75 (permalink) Old 10-04-2011, 02:28 AM
When you got the camera system, this thread should have started. You should have never opened the box without adult supervision.
post #10 of 75 (permalink) Old 10-04-2011, 02:31 AM
Yeah 3 or 4 wires at the most. Pos, neg, trigger and maybe a switch wire. Only thing in the fuse block it should had been hooked up to was a power accessory tap. Unless he was trying to tap into a wire for the reverse under the dash (if there is one under the dash in a CRV. Dunno, never worked on one).
post #11 of 75 (permalink) Old 10-04-2011, 05:08 AM
ThirdgenTa's Avatar
Sportbike: 2001 zx6
How you found us: Search
I am sure we have all tried to tackle projects on our own. Sometimes it doesn't work out and should have been taken care of by a professional. Lessons learned.
No need to keep pointing it out and insulting him to make yourself feel better.
ThirdgenTa is offline
post #12 of 75 (permalink) Old 10-04-2011, 07:44 AM Thread Starter
tcmalker's Avatar
Sportbike: FZ6
Please don't think that this was an easy project, because it was definitely not. It's not JUST connect 3 or 4 wires. Don't forget, the camera is in the back and that has to be connected to the taillight. Why, you might ask? Because you don't want the camera on all the time, just when you reverse.
Since the CRV has a liftgate, it was tricky to connect the camera power to the backup light wire. Fitting (used fish tape) an RCA cable and power wire through that little rubber boot was not easy. Also, all the panels in the back has to be removed, as well as the driver's side rear panels.
Then I had to route the cable somehow to the front where the mirror is. It took geniousity. I routed above the headliner, just under the weatherstrips. Then I had to take the A-Pillar off.
Here's some pictures of the install. And the dreaded fuse.
P.S. Anybody who has a CRV and would like to install a backup camera, pm me and I will guide you in the right direction.
tcmalker is offline
post #13 of 75 (permalink) Old 10-04-2011, 07:59 AM
my concern wouldnt be the check engine light , it would be the security light that is on wether you have it armed or not... the car thinks someone tried to steal it opening up a world og imobilizer possibilities
post #14 of 75 (permalink) Old 10-04-2011, 08:10 AM
Good luck.
Note any time working on electric in cars they tell you to always disconnect the battery. That is the first rule...
post #15 of 75 (permalink) Old 10-04-2011, 09:13 AM
I am not going to give you shit for trying this project on your own. You did so at your own risk.
However... I am going to give you a metric fuckton of shit for this:
Originally Posted by tcmalker View Post
It took geniousity.
It... took... what???
WTF, I'm revoking your Asian card... you're making us look bad!!!
post #16 of 75 (permalink) Old 10-04-2011, 09:19 AM
Helpful.
post #17 of 75 (permalink) Old 10-04-2011, 09:38 AM
Originally Posted by Cerk View Post
Helpful.
+1.
Geez Dave, you're being really harsh on the guy. How many times have you asked for help on this board because you made a mistake? Weak, dude.
To the OP: I agree with Pilot and trklg, you should pop it into the dealer to get the code checked. Hopefully its something minor that can just be reset.
I give you props for trying to install this yourself. I put in an in-dash nav system, ipod connector, BT connector and backup camera in my Porsche. I was pretty nervous about it all and ended up making a couple of mistakes. I got some good advice on the proper forums and fixed everything. It's a great feeling to do stuff yourself. Best of luck to you.
post #18 of 75 (permalink) Old 10-04-2011, 12:31 PM
dave has always had some sore spot issues when it comes to car audio/video being done by DIYers...probably from some deep rooted prechildhood abandonment issues
post #19 of 75 (permalink) Old 10-04-2011, 12:34 PM
On a Dodge, you can turn the ignition on and off 3 times and on the 3rd time you turn it on, you get the code where your mileage is normally displayed. Is there a technique like this for your CRV?
post #20 of 75 (permalink) Old 10-04-2011, 01:05 PM
Yeah, i'm harsh. But being proud of screwing up your wifes car?
Ok seriously, what did you test power with, and where at? I will honestly try and help.
Jason yes, my OCD goes into overdrive when it comes to car and bike wiring. Being in the field for a while will do that. It's like you making something and you ask out of what and their reply is "metal".
post #21 of 75 (permalink) Old 10-04-2011, 01:10 PM
Again...
I see plenty of criticism and aspersions being cast, but I see very little in the way of actual information...which of course is why the thread was started.
post #22 of 75 (permalink) Old 10-04-2011, 01:56 PM
Well if we know what he used to check for power, we would have an idea if anything was damaged. Multimeter, should be good. Test light, not so much. If we knew where he probed, we would have an idea on what may have been damaged. If someone here has more ASC and MECP certifications than myself in this matter, let them speak up. I admitted I was harsh, now I'm trying to help. If the op doesn't want it, tell me and I'll delete all my posts in this thread and stay out of it.
post #23 of 75 (permalink) Old 10-04-2011, 02:32 PM
The Violator
Troy's Avatar
I'm not in the city, but have an ODB2 reader. If you want to skip a trip to the dealer, you're more than welcome to pull your codes.
Troy is offline
post #24 of 75 (permalink) Old 10-04-2011, 02:40 PM
most all auto parts stores will loan this out free of charge
post #25 of 75 (permalink) Old 10-04-2011, 02:46 PM
^^^yeppers, but in my experience won't clear it. Company policy is what I was told last time.
post #26 of 75 (permalink) Old 10-04-2011, 03:15 PM
The only reset tool I ever needed was a strategically placed paperclip! Just gotta find the info for your vehicle.
post #27 of 75 (permalink) Old 10-04-2011, 03:18 PM
meh. I have to reset so many, I just bought the little pocket obd computer that erases the codes
post #28 of 75 (permalink) Old 10-04-2011, 03:27 PM
all of the code readers ive used have been able to clear codes
as for the paperclip, i know that applied for the OBD1 cars(95 adn older) not sure on the OBD2 cars...
post #29 of 75 (permalink) Old 10-04-2011, 03:31 PM
Jason, what I meant was. Last time I went to vatozone, they checked the code for me and told me they wouldn't clear it. Not that the device itself was incapable.
post #30 of 75 (permalink) Old 10-04-2011, 04:31 PM
Depends on the vehicle, for the newer ones, if you can find the correct pins to bridge, it will reset the light, but not erase the history if that makes sense.
