Rough Idle 98 buick lesabre 3800 motor - Chicagoland Sportbikes
post #1 of 30 (permalink) Old 05-07-2012, 02:06 PM Thread Starter
Pringles can user
tnat's Avatar
Sportbike: 2005 YZ250
Years Riding: 1977
How you found us: Geo
Anyone have any ideas on a rough idle on a 98 buick lesabre 3800, changed plugs, wires, air filter, PCV i run shell premium. ive got 125,000 on it and its well maintained.
Should i change the egr valve, fuel filter? Its not that rough but not smooth? any ideas on what to check?
CLICK THE LINK!
http://www.club57mx.com/
Doug Stanhope
tnat is offline
post #2 of 30 (permalink) Old 05-07-2012, 02:08 PM
1shadyninja's Avatar
Sportbike: ZX9R
Years Riding: 10+ years
How you found us: Gixxer Tony
Garage
When was the last time the fuel filter was changed?
First Place Oils
1shadyninja is offline
post #3 of 30 (permalink) Old 05-07-2012, 02:13 PM Thread Starter
Pringles can user
tnat's Avatar
Years Riding: 1977
A couple years ago.
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #4 of 30 (permalink) Old 05-07-2012, 02:26 PM
dirty injectors
vacuum leak
TPS sensor
coil pack
ign module
dirty intake,throttle body, and or egr valve
post #5 of 30 (permalink) Old 05-07-2012, 02:29 PM
Ryan's Avatar
Years Riding: Since 2001
Does it smooth out when you open the throttle a little? Is the check engine light on?
Ryan is offline
post #6 of 30 (permalink) Old 05-07-2012, 02:37 PM Thread Starter
Pringles can user
tnat's Avatar
Years Riding: 1977
smooths out a little - no check engine light, ive got that Bluetooth OBD2 connector comming and downloaded the "torque App for droid" tommorow so i can get more detail on the engine when i scan it, ive got a basic obd2 reader but nothing comes up.
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #7 of 30 (permalink) Old 05-07-2012, 02:46 PM
Ryan's Avatar
How rough is it? Are you sure it an issue with the way it's running and not just clapped out motor mounts transmitting vibration into the car?
Ryan is offline
post #8 of 30 (permalink) Old 05-07-2012, 02:48 PM
Maybe its just a POS ?
Vacuum leak ? Check the intake boots for cracks and loose clamps.
But maybe it's just a POS.
MOTO AND MOTOR
1906 TECHNY RD.
NORTHBROOK IL 60062
SALES*SERVICE*PARTS
847-790-4848
post #9 of 30 (permalink) Old 05-07-2012, 02:54 PM
Originally Posted by Ryan View Post
clapped out motor mounts ?
motor mount with an STD?
post #10 of 30 (permalink) Old 05-07-2012, 02:57 PM
Aren't the coil pack known to be a problem on the 3800?
post #11 of 30 (permalink) Old 05-07-2012, 03:08 PM
Maybe someone mistakened ur ass for the exhaust pipe while you were at the Forest Preseve and stuck a pringels can up it.
post #12 of 30 (permalink) Old 05-07-2012, 03:31 PM
Ryan's Avatar
Yes but if a coil died it would have a severe miss, the check engine light would be on, and it the engine would be running more than a little rough.
If it has just a slight misfire at only at idle I would suspect a vacuum leak but it's hard to see what it's actually doing through the internets .
Ryan is offline
post #13 of 30 (permalink) Old 05-07-2012, 03:37 PM Thread Starter
Pringles can user
tnat's Avatar
Years Riding: 1977
WOuld a dying altenator also cause weak idle? is there any way to turn up the idle on that thing?! its almost a pos!
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #14 of 30 (permalink) Old 05-07-2012, 03:41 PM Thread Starter
Pringles can user
tnat's Avatar
Years Riding: 1977
How do i check a vacum leak?
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #15 of 30 (permalink) Old 05-07-2012, 03:41 PM
Ryan's Avatar
Originally Posted by tnat View Post
ok, thanx for the info guys! its almost a pos!
It's a 98 Buick LeSabre. It was a POS when it rolled off the assembly line .
Ryan is offline
post #16 of 30 (permalink) Old 05-07-2012, 03:48 PM
Richfiero's Avatar
Sportbike: 06 Ninja zx636
Years Riding: 6 years
How you found us: no
Clean the throttle body!!
Richfiero is offline
post #17 of 30 (permalink) Old 05-07-2012, 04:09 PM Thread Starter
Pringles can user
tnat's Avatar
Years Riding: 1977
With standard Carb cleaner?
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #18 of 30 (permalink) Old 05-07-2012, 04:10 PM Thread Starter
Pringles can user
tnat's Avatar
Years Riding: 1977
Yeah Yeah Yeah - I got that thing 10 years ago used from a old lady in my dads condo building - 4 yrs old - 7000 miles on it and garage kept for $9000
awesome deal!
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #19 of 30 (permalink) Old 05-07-2012, 05:11 PM
make sure it says safe for O2 sensors and Catalytic converters
remove the iac sensor, and clean the inside. Pull the EGR valve off and clean that tube, with a brush and spray it
post #20 of 30 (permalink) Old 05-07-2012, 06:13 PM
Did you disconnect the power commander?
post #21 of 30 (permalink) Old 05-07-2012, 06:22 PM
yo quiero su taco
whiteSeatEnvy's Avatar
I had a rough idle, rough running engine (different make) and it turned out to be a cam sensor.
whiteSeatEnvy is offline
post #22 of 30 (permalink) Old 05-07-2012, 06:48 PM
Dirtbiker's Avatar
I can see from here that it needs intake gaskets.
Dirtbiker is offline
post #23 of 30 (permalink) Old 05-07-2012, 07:08 PM
Did you try dousing it in gasoline and setting it on fire?
post #24 of 30 (permalink) Old 05-07-2012, 07:35 PM
Ryan's Avatar
Open the hood and listen for a hissing sound while it's running. Spray carb cleaner around vacuum lines and where the intake manifold meets the cylinder heads and listen for a change in RPM or the way it's running. Try not to set anything on fire while doing this . If it had a bad enough vacuum leak to cause a driveability issue it would probably have lean codes in it though.
Is it running rough or just idling too slow? The idle isn't adjustable on that car as it is controlled by the computer. If you adjust the throttle stop screw the computer will just open the idle air control valve less. Try cleaning the throttle body if it's just idling too slow. Don't go spraying a bunch of shit into the throttle body. Spray carb cleaner or brake cleaner on a rag and use that to wipe all the carbon out of the inside of the throttle body and off of the throttle plate. There is probably a very small hole on the throttle plate, make sure that is open too. Take the idle air control valve off and wipe the pintle on that clean and the hole it goes into. If the EGR valve is stuck open a little it will cause it to idle rough but this would most likely also set a code because it has an electronic EGR valve with a built in EGR position sensor. The EGR valve is easy to remove and see if there's a chunk of carbon holding the pintle open.
This is all just a guess. It's difficult to diagnose something over the intronets with just a vague description of what it's doing.
Ryan is offline
post #25 of 30 (permalink) Old 05-07-2012, 07:36 PM
Ryan's Avatar
Ryan is offline
post #26 of 30 (permalink) Old 05-07-2012, 07:45 PM
Best bet it will fix the rough idle.
MOTO AND MOTOR
1906 TECHNY RD.
NORTHBROOK IL 60062
SALES*SERVICE*PARTS
847-790-4848
post #27 of 30 (permalink) Old 05-07-2012, 10:25 PM
Other common problem on those engines are the fuel injectors or was it the 3100 series?
May need to scope it to be sure..
post #28 of 30 (permalink) Old 05-08-2012, 02:30 AM
wat, theres no "no start when hot"
still can't believe they havn't fix that crap
post #29 of 30 (permalink) Old 05-08-2012, 09:30 AM Thread Starter
Pringles can user
tnat's Avatar
Years Riding: 1977
Ive been running the cheap gas so yeasterday i got some FI cleaner, dumped a bottle of that in it, 4 gals of sunoco 100 octane race fuel and 5 gals of 93 octane. Wife has to drive down to Lagrange on the hwy today so maybe it just needs to be cleaned out as had my new scanner on it last nite and everything tests out fine - if you ahve a droid you must get the new "torque obd2 app & bluetooth OBD2 adapter - it came in the mail yesterday so i was fuckin around with it till midnight really trick little program for $5 and the BT adapter was around $20.
This thing is the Shiznit!
http://torque-bhp.com/software/torqu...obd2-adapters/
http://www.appbrain.com/app/torque-l...owl.torquefree
http://www.amazon.com/BAFX-Products-...6483787&sr=8-4
CLICK THE LINK!
Doug Stanhope
tnat is offline
post #30 of 30 (permalink) Old 05-08-2012, 11:51 PM
Pathological Thrill Seekr
Deuces's Avatar
Sportbike: Trek Marlin
Years Riding: Noob
You can also make sure the wires are fully attached to the plugs... The back ones are a pain to get fully seated.
Ride smart... stupid hurts.
Godspeed 788!!! We miss you!
Deuces is offline
