Wrenching on the Miata, and having a blast. - Chicagoland Sportbikes
post #1 of 13 (permalink) Old 05-12-2012, 07:37 PM Thread Starter
I got the Miata for a great price, and I knew it had some issues. First, it has been sitting for 5 years, and even here in Florida, metal rusts. The wipers were horrably rusted. A little sandpaper, rustoleum paint, and new blades made a huge improvement.
Next, the car doesn't run well, and has trouble starting. After some testing, I figured it was a bad fuel pump and pulled it out.
Ewwwwww!!! This car has sat a long time, and the fuel is less than spectacular. I'll empty the tank, clean it out, and I found a used assembly to drop in. Mine is really rusty, and I question the reliability (thanks Stanimal for the advice). There is a huge following for this car, so parts are readily available. So far, the car has been pretty easy to work on, and I'm having fun working on it.
post #2 of 13 (permalink) Old 05-12-2012, 07:45 PM
did he fill the tank with oil he skimmed from the gulf spill?
post #3 of 13 (permalink) Old 05-12-2012, 07:46 PM
Sportbike: 08 gsx six fiddy F
How you found us: forum link
Yeah no kidding, that's just crazy. Next thing I would do is clean the fuel system out, check out injectors and get some treatment going for that.
2008 Suzuki gsx 650f.
Thomas Jefferson
michowski is offline
post #4 of 13 (permalink) Old 05-12-2012, 08:07 PM Thread Starter
It's pretty gross, the whole car needs a thorough cleaning. Luckily, it's a little car. The fuel filter didn't have any crap in it, so I'm hoping the injectors aren't too bad. I'll use a cleaner with them, then replace the fuel filter and pump assembly. Pumping out the old fuel and cleaning the tank with a scraper and rags should get most of the other crap out.
The power drivers window didn't work. I ordered a used regulator off eBay and it should be here in a few days. Common problem with this car, and it's another easy fix. I might try and tint the windows myself in the near future. The back window is glass, so it should turn out really sharp.
post #5 of 13 (permalink) Old 05-12-2012, 08:10 PM
he paid you how much $$ to take this heap off his hands??
post #6 of 13 (permalink) Old 05-12-2012, 09:21 PM
Dont forget to flush the fuel lines back to the tank.
post #7 of 13 (permalink) Old 05-12-2012, 10:12 PM Thread Starter
Good thinking Tom, thanks. This car is in high demand here, especially being a convertable and having an automatic transmission. This miata was ordered with nearly every option, so that boosts the value as well. I have had offers for it for nearly double what I got it for, and that's with it running like shit. But it will remain in our stable for a while, I'm trying to talk Mandy into participating in an auto crossing event. That's what this little whip was built for, cheap fun and lots of smiles.
post #8 of 13 (permalink) Old 05-13-2012, 10:44 AM
And picking up Twinks...don't forget that.
post #9 of 13 (permalink) Old 05-13-2012, 10:53 AM Thread Starter
Jealous? Build me a AR15 chambered in 9mm and I'll give you my RD350. Deliver it to me, and we can be a sight rolling in the Miata.
post #10 of 13 (permalink) Old 05-19-2012, 07:09 AM Thread Starter
Replaced the drivers window regulator and it's good to go. I scooped a medium cup sized cup from Krystal burger almost to the top with sludge from the tank. Then scraped and cleaned and dropped in the new fuel pump assembly.
http://i118.photobucket.com/albums/o...3/987895cf.mp4
Yay, it runs! Now I can start on the slow throttle response. I'm sure cleaning the injectors, MAF, and intake will make a noticeable difference.
post #11 of 13 (permalink) Old 05-19-2012, 05:31 PM
deefib's Avatar
Now it just needs that Busa motor
deefib is offline
post #12 of 13 (permalink) Old 05-19-2012, 05:36 PM
What is it with you two ? Busa motors are for lawnmowers , you need a 5.0 Ford swap .
MOTO AND MOTOR
1906 TECHNY RD.
NORTHBROOK IL 60062
SALES*SERVICE*PARTS
847-790-4848
post #13 of 13 (permalink) Old 05-19-2012, 06:08 PM
Waiting on the FFL. Give me a little time, I can put it together for you.
