my first oil change - Chicagoland Sportbikes
post #1 of 50 (permalink) Old 09-25-2012, 08:01 PM Thread Starter
tcmalker's Avatar
Sportbike: FZ6
How you found us: fz6 forum
my first oil change
so decided I would change the oil on my Accord. Been changing oil on my FZ6 so I didn't think it was much different. Got my supplies: oil filter, bolt washer, oil filter wrench, torque wrench, floor jack, jack stand, 5w-20 oil (5 qts), funnel, oil pan.
First problem I encountered was the floor jack. I bought the absolutely cheapest one I could find at Autozone for $39.99. Figure I don't need a higher end model. Turns out, it only jack up the car so that the wheel is barely half an inch off the ground. Couldn't go under the car, so back to Autozone.
Bought a higher end model $79.99. It's a SUV model, so I figure I could change my CRV too. Got back home and worked like a charm.
Next problem was taking the engine bolt off. I don't know the right technique, but when it came off, oil shot off and missed the oil pan, making a big mess. If anybody can tell me the right way to take the engine bolt off I would appreciate it a lot.
The rest of easy. Cleaning up was a little messy. I tried to pour the oil into the used oil container, but it spilled. Should have got the more expensive oil pan that can be capped. Pisssed off, I threw the used oil in the garbage. You all know how I feel about the environment. Tried to do the right thing and my garage gets messed up.
Afterthought. I really didn't need to go under the car to change the oil. It could have been done on the side. But since I already bought the expensive jack, I figure I could use it to rotate tires too.
Which now I have several questions regarding rotating tires. How often should I do it? I'm thinking every 5000 miles so it will be easy to remember. And should I criss cross? I know what my manual said, but I once asked a guy at Jiffy Lube why he didn't criss cross he said because that's the best way. I think he was just lazy to move the tires from one side to another. How do you guys do it?
Thanks in advance.
tcmalker is offline
post #2 of 50 (permalink) Old 09-25-2012, 08:06 PM
post #3 of 50 (permalink) Old 09-25-2012, 08:07 PM
lust for bikes!
nouseforaname's Avatar
Sportbike: a prostitute
Years Riding: a prostitute
nouseforaname is offline
post #4 of 50 (permalink) Old 09-25-2012, 08:11 PM
post #5 of 50 (permalink) Old 09-25-2012, 08:14 PM
post #6 of 50 (permalink) Old 09-25-2012, 08:15 PM
Tires rotate while you drive
Daddy mac. Mack daddy
post #7 of 50 (permalink) Old 09-25-2012, 08:22 PM
I guess you do need to be a rocket scientist to change your oil.
MOTO AND MOTOR
1906 TECHNY RD.
NORTHBROOK IL 60062
SALES*SERVICE*PARTS
847-790-4848
post #8 of 50 (permalink) Old 09-25-2012, 08:25 PM Thread Starter
tcmalker's Avatar
Sportbike: FZ6
no serious responses. I bet 98% of you don't change your own oil, even on a motorcycle. PATHETIC! Be a man.
tcmalker is offline
post #9 of 50 (permalink) Old 09-25-2012, 08:26 PM
lust for bikes!
karma for being a fucking homophobe. just deal
post #10 of 50 (permalink) Old 09-25-2012, 08:28 PM
Real men don't ask stupid fucking questions. Or buy a jack, that you probably have laying next to your spare tire in your Accord (which you don't even need)
post #11 of 50 (permalink) Old 09-25-2012, 08:31 PM Thread Starter
tcmalker's Avatar
Sportbike: FZ6
it's a FLOOR JACK, so it raise the entire half of the car So you DO need it. How else are you going to rotate the tires einstein?
DOH!
tcmalker is offline
post #12 of 50 (permalink) Old 09-25-2012, 08:37 PM
DOH!
You bought it for oil change, just to later realize it was pointless for it, and use the tire rotation as excuse for it's use.
And lifting "entire half" of the car is really gonna help you rotate the tires using any of the 3 most common tire rotations:
post #13 of 50 (permalink) Old 09-25-2012, 08:38 PM
You're right , non of us have changed oil in our cars and bikes.
MOTO AND MOTOR
1906 TECHNY RD.
NORTHBROOK IL 60062
SALES*SERVICE*PARTS
847-790-4848
post #14 of 50 (permalink) Old 09-25-2012, 08:46 PM
fuk rotating tires, I only buy two at a time.
post #15 of 50 (permalink) Old 09-25-2012, 08:51 PM
Who the hell rotates tires anyways? I got 335s on back and my fronts are toed in like a mofo plus they are matched perfect and staggered special so they WILL HOLD.
post #16 of 50 (permalink) Old 09-25-2012, 08:56 PM
Turn 4 on the outside
post #17 of 50 (permalink) Old 09-25-2012, 09:18 PM Thread Starter
tcmalker's Avatar
Sportbike: FZ6
of course it will, I lift up the front end, put the jack stands on, move to rear and lift that up. Voila! All four tires off the ground. All in under a minute. Imagine using the stock jack that comes with the car. LOL.
tcmalker is offline
post #18 of 50 (permalink) Old 09-25-2012, 10:12 PM
Guess you're lacking imagination. Scissor jack with a electric or air drill, and it lifts it in a matter of seconds.
post #19 of 50 (permalink) Old 09-25-2012, 11:08 PM
You shouldn't be changing oil let alone rotating tires...
post #20 of 50 (permalink) Old 09-25-2012, 11:36 PM
So much fucking fail, where to begin...
The jack. What are you using to support the vehicle while you are underneath it? I didn't see any mention of jack stands. Nice way for your family to find you if the jack slips or fails.
Throwing out used oil. Recycle the shit. You went to the store twice to get a jack, but won't go once to recycle your oil? Lame.
Not buying an expensive oil collector. I use containers from the hospital (think dollar store quality), that hold enough used oil to do an oil change. Then dump that into a 5 gallon bucket and put the lid on. When the 5 gallon bucket gets full, bring it in to be recycled while buying new oil and a filter. To keep your car clean while transporting the bucket, put it in a trash bag, and put it in the passengers site floorboard.
Only a handful of Jiffy Lube shops rotate tires due to insurance reasons. And if you are changing your own oil, why are you at a jiffy lube?
My daughter learned at 8 years old how to do an oil change without making a mess. You are simply "special".
How should you rotate your tires? Check your owners manual, or contact the dealer.
Please, troll somewhere else.
post #21 of 50 (permalink) Old 09-25-2012, 11:56 PM
1shadyninja's Avatar
Sportbike: ZX9R
Years Riding: 10+ years
How you found us: Gixxer Tony
Garage
I help/teach my customers how to do oil changes all the time . I even wrote a basic how to thread for bikes.as for used oil , I put it in milk /washer fluid jugs and give it to a buddy at napa where they are able to sell it to a oil recycling company.
For future reference. Drive on ramps are way safer for a beginner than using a jack with out stands.
First Place Oils
1shadyninja is offline
post #22 of 50 (permalink) Old 09-26-2012, 12:13 AM
LockDownMike's Avatar
Sportbike: 2012 Ducati M696
How you found us: Scout 67
I thought you were going to throw in a personal plug like...
When you want to do an oil change do it right, do it with AMS OIL. Proven to be the #1 leading motor oil in Serbia for 3 years in a row. Lasts up to 600 miles long, 600 miles strong. Your car will smoke more, misfire more, and lose serious MPG like a boss! Use Ams oil contact number is
555-BLO-HARD
LOL!
Just kidding. AMS OIL is legit.
LockDownMike is offline
post #23 of 50 (permalink) Old 09-26-2012, 01:35 AM
ThirdgenTa's Avatar
Sportbike: 2001 zx6
How you found us: Search
The place I recycle my oil at told me not to use milk jugs. They said the oil breaks down the plastic, especially by the handle. They ended up giving me a thicker jug to use.
Also, did you make sure to oil the gasket on the oil filter?
ThirdgenTa is offline
post #24 of 50 (permalink) Old 09-26-2012, 08:11 AM
Sportbike: ZX9R
Garage
He has a 275 gallon tote that he pours it in .doesn't stay in the jug that long.
Wiper fluid jugs are thicker.I also have some "chemical proof"2.5 gallon jugs I got when I worked for ExxonMobil. I recycle about 10 gallons of oil a week.
First Place Oils
post #25 of 50 (permalink) Old 09-26-2012, 08:37 AM
Isn't an oil change at Jiffy lube like $20? Has the world come to not enjoying simple luxuries like watching a grease monkey do dirty shit to your car while you watch? This is pathetic.
post #26 of 50 (permalink) Old 09-26-2012, 09:20 AM
Sportbike: ZX9R
Garage
Here is food for thought
I prefer to do my own, That way I know the drain plug will not fall out.
I only change my oil one time a year, so dedicating 10 min a year to a oil change is not that big of deal
and Jiffy lube uses a very inexpensive conventional oil.
First Place Oils
post #27 of 50 (permalink) Old 09-26-2012, 09:25 AM
For every report of issues at professional service shops, there are at least 4000 cases of people screwing their own shit up. I change at least 3 oil pans per year from people "saving money" doing their own oil changes.
post #28 of 50 (permalink) Old 09-26-2012, 10:07 AM
You trust a 18 year old doing work on your 30K car..
Common sense isn't so common.
post #29 of 50 (permalink) Old 09-26-2012, 10:43 AM
If you are using a floor jack, you better be using jack stands along with it.
post #30 of 50 (permalink) Old 09-26-2012, 10:49 AM
Slower Traffic Keep Right
stkr's Avatar
Years Riding: 30+ yrs total
This is all I've got for this...
Midwest Track Day CR #130
STT "A" 130
Track: 2006 GSXR-750
stkr is offline
