bleeding brakes - Chicagoland Sportbikes
post #1 of 10 (permalink) Old 05-09-2012, 08:45 AM Thread Starter
Back on 2 wheels
cruzr180's Avatar
Sportbike: Bikes with pedals
Years Riding: Since 2004
bleeding brakes
After my bike was laying on its side coming back from Sylvan island the brakes are not as strong. Have to pull levers all the way. I know storing bikes upside down will cause issues, but also on its side?
Do you guys pull the brakes off to bleed them or just on the bike?
I have formula brakes. Looks like I need to get the bleeder kit.
Josh
cruzr180 is offline
post #2 of 10 (permalink) Old 05-09-2012, 09:24 AM
Put a rubber band around the lever over night.
post #3 of 10 (permalink) Old 05-09-2012, 09:54 AM
I have never bled mine yet. My Flux needs it, as the front brake doesn't work any more, but my Look is good. It's kind of a pain, and Scott made me do his because he's a train wreck, but not that bad to get back to stock feel. The bleed kit makes it a ton easier.
post #4 of 10 (permalink) Old 05-09-2012, 01:07 PM
beac83's Avatar
Sportbike: A couple
For a minute there I thought a spammer got ahold of Ken's login.
________________
beac83 is offline
post #5 of 10 (permalink) Old 05-09-2012, 03:37 PM
Tony M.
Murcielago's Avatar
Sportbike: Yamaha Tri Zinger
Me too, its a rare occurrence to hear him working on his personal bikes. Sorry josh I have not yet bled my brakes, let me know how it goes.
Murcielago is offline
post #6 of 10 (permalink) Old 05-09-2012, 03:57 PM
Phlip Skwad Crew Member
DaneG320u545's Avatar
Sportbike: '02 Suzie Kan-o-tuna(SOLD), K5
Years Riding: noob status
How you found us: AOL.com
Send a message via Skype™ to DaneG320u545
In order to bleed your brakes. All you do is connect a rubber hose to the bleeder and then the other side to a water bottle to catch the brake fluid. When it comes to bleeding, you have 2 options:
1) completely drain the brake fluid > replace the brake fluid > VACUUM all the air out of your lines or until you feel the pressure build up in your brake lines.
2) I RATHER DO THIS, BTW - drain the brake fluid, as your reservoir starts to empty out, fill it up with clean fluid. The key is to avoid letting the reservoir completely drain out and get air in the lines. So if you keep pouring clean brake fluid over the old one until your the bleeders starts to spit out the clean fluid. You can then close it out because the fluid is clean and there is no remaining old fluid in those lines.
I went ahead and did both actually. Lol. First time I did option 1 on accident. I let the reservoir drain out (that was for back brakes). For the front I keep filling up the reservoir until clean fluid came out, then repeat on other side (front | 2 bleeders). As far as the back brake, it was a BIOTCH! We couldn't get pressure in it for 3 hours. Then figured out we have to vacuum pump the air out of the lines because we let the reservoir completely drain out.
Another thing, pump the brakes as it drain to force fluid out of the lines and into the water bottle or brake fluid catcher
Here are pics from when I did mine:
•This shows the rubber hose and water bottle attached to the bleeder
Here is a pic of the valve to release the fluid ("bleeder" as I've been calling it)
Best of luck!
Dane
"Everybody knows it aint trickin if you got it"
DaneG320u545 is offline
post #7 of 10 (permalink) Old 05-09-2012, 04:15 PM
Bastards! My bikes get washed every year whether they need it or not!
post #8 of 10 (permalink) Old 05-09-2012, 04:37 PM
+3 I've seen him work on bicycles on the trail and he's calling Scott a train wreck? Lol. hahahahahaha
post #9 of 10 (permalink) Old 05-10-2012, 11:22 AM Thread Starter
Back on 2 wheels
cruzr180's Avatar
Attachment 68607
Attachment 68608
Best of luck!
Bicycle section not Motorcycle
Josh
cruzr180 is offline
post #10 of 10 (permalink) Old 05-10-2012, 02:57 PM
Whoops! :-D didn't even see that :-p
Dane
