I think my bike has a major wiring problem - Chicagoland Sportbikes
post #1 of 25 (permalink) Old 02-14-2011, 10:57 AM Thread Starter
Sportbike: 01 GSXR 1k
Years Riding: 20+ years
I just bought an 01 GSXR 1000 from a private party seller a couple weeks ago. I only took it for a short test ride before I bought it. I went out riding yesterday for a little bit, and I noticed several electrical issues.
1. No low beams, but headlights come on on high beams. Not sure if they are really the high beams or low
2. Anytime the brakes are applied (front or rear) the green turn signal lamp on the dash lights up.
3. Left turn signal blinks normal speed, but right signal blinks fast.
4. If the brakes are applied while a turn signal is on, the signals stop blinking (right signal for sure, I can't remember if this is also the case with the left)
The rear tail light is clear, but not LED. It appears it has two large red bulbs inside, but there are no turn signals on the back, they are integrated into the tail lights.
Anybody have a clue if this is all related, or any idea what I can check?
Aron is offline
post #2 of 25 (permalink) Old 02-14-2011, 11:01 AM
he who is absent foreskin
Loki047's Avatar
Sportbike: Z1000
Its trashed, I will give you $1 for it.
It actually sounds relatively simple to fix. Re-wires the lights. And clean all the grounds.
And remember for next time you buy a bike.
Jordan
Loki047 is offline
post #3 of 25 (permalink) Old 02-14-2011, 11:02 AM
something is botched with the integrator.
01 had 2 headlight bulbs, one on for low beam, both on for high beam. This was changed to dual filament bulbs in later years. probably just have the low bulb burnt out.
post #4 of 25 (permalink) Old 02-14-2011, 11:04 AM
Ride Naked
mac11's Avatar
Sportbike: z1000
I'd say whomever did those integrated tails didn't know WTF they were doing with electric and tesla should come back and haunt their every waking moment.
The wiring is probably hacked up but I bet if you cleaned it up it would probably fix your issues.
mac11 is offline
post #5 of 25 (permalink) Old 02-14-2011, 11:15 AM
dude the rectifier bearing blew and at this point your ruining the engine as well.
and eletronic issues are close to impossible to figure out if you have no clue how to attack it so that usually means you have to rewire the whole bike.
tell you what i need a track bike, ill give you 2000.00 for it since i am gonna gut all that anyway.
deal?
post #6 of 25 (permalink) Old 02-14-2011, 11:30 AM
deal?
Too much $$ for an 01 with electrical problems
post #7 of 25 (permalink) Old 02-14-2011, 11:31 AM
Dude, I live right by you - I could help you out if you want.
post #8 of 25 (permalink) Old 02-14-2011, 11:59 AM
This. Check the internet on how to wire it correctly.
post #9 of 25 (permalink) Old 02-14-2011, 12:56 PM Thread Starter
deal?
Thanks for the offers guys, but I think I'm going to hold on to it haha
I didn't know that, I thought they were both dual filament bulbs. However, when the highs were on, both bulbs were lit, so wouldn't that mean that the low beam works, it's just not getting juice when the switch is on low?
If you have any idea what you're doing, that would be cool. I'm extremely mechanically inclined, but when it comes to electrical stuff I try to stay away from it, especially big complicated circuits like this.
I'm storing the bike in Sandwich for now, but I'll be getting a storage unit in Oswego as soon as the weather gets nicer.
Aron is offline
post #10 of 25 (permalink) Old 02-14-2011, 01:25 PM
beac83's Avatar
Sportbike: A couple
Right turn signal blinking fast means that there is not enough load (i.e. burned out bulb). However, since someone has put an integrated tail on, it's likely the wiring for the tail is messed up and just not done right. Get your hands on the instructions for installing whatever tail is on there, and re-check all the wiring. I bet you find one mistake that will correct all the brake/turn issues.
________________
beac83 is offline
post #11 of 25 (permalink) Old 02-14-2011, 01:41 PM Thread Starter
Yeah, I was thinking of just getting an LED tail light for it, and starting fresh since I don't know what tail light is on it.
Aron is offline
post #12 of 25 (permalink) Old 03-19-2011, 06:11 PM Thread Starter
Just an FYI, I believe the opposite is true after doing some research. My 01 has H4 dual filaments (2 low, 2 high). I downloaded the service manual, which reflects that also
01 Gixxer 1k
94 Camaro Z28
97 Blazer 4x4
Aron is offline
post #13 of 25 (permalink) Old 03-19-2011, 06:58 PM
project15's Avatar
Sportbike: 1998 GSX-R600
Years Riding: 4th season
Re: I think my bike has a major wiring problem
Right turn signal blinking fast means that there is not enough load (i.e. burn...
The after market kit might already be led which is what causes the fast blink. When you install those you can wire in a resistor to fox the problem. Sounds like you just need to get your hands on a resistor and wire it to the one that blinks fast.
-Chris
project15 is offline
post #14 of 25 (permalink) Old 03-19-2011, 07:05 PM
ask G2G he can fix it all under an hour.
post #15 of 25 (permalink) Old 03-19-2011, 07:09 PM
I got a idea!
Bring it to the dealer that did your oil change
post #16 of 25 (permalink) Old 03-19-2011, 08:17 PM
PolishPete's Avatar
Sportbike: 600rr
Some of you guys are ruthless.
Don't take them seriously Aron.
I would take Kegger up on his offer. Throw him some $ for his time/knowledge, and get it fixed right the first time. Otherwise you'll be messing with it all summer, dealing with it, etc. Fix it, enjoy the bike, ride safe. My .
Peter Katowicz
State Farm® - Agent
108 E Lake St. Unit 2
Bloomingdale, IL 60108
Office: (630) 980-9809
Fax: (630) 980-9858
[email protected]
www.PeterIsMyAgent.com
PolishPete is offline
post #17 of 25 (permalink) Old 03-19-2011, 08:48 PM
Mmmmmm....
Pinkrider's Avatar
Sportbike: RIP Rsux
PM Resurrection (Gus) on here. He is down in Park Forest but knows his electrical stuff.
Pinkrider is offline
post #18 of 25 (permalink) Old 03-19-2011, 08:56 PM
That just sounds so naughty he knows his electrical stuff
post #19 of 25 (permalink) Old 03-19-2011, 10:18 PM Thread Starter
Thanks guys. I know better than to take anything on the interweb personally.
I started having a charging problem the other day, so I popped the seat off to pull the battery to charge it. I found a corroded and broken wire going to the rectifier, so I have to pull the tail off to fix that. I'll take a look at the tail light then and if I can't figure it out I'll look for help here.
01 Gixxer 1k
94 Camaro Z28
97 Blazer 4x4
Aron is offline
post #20 of 25 (permalink) Old 03-19-2011, 10:23 PM
this!
post #21 of 25 (permalink) Old 03-19-2011, 11:56 PM
shouldnt be. I think the 600/750/1000s were the same for headlights on those years and I had both an '01 and '02 600.
post #22 of 25 (permalink) Old 03-20-2011, 12:37 AM
Sportbike: R6, SV1000s, rm250
DUH, that means it's time to change the blinker fluid.
post #23 of 25 (permalink) Old 03-20-2011, 02:21 AM
deal?
you need a scope, and those things are effing expensive.
maybe $1500 and Odysseys will buy it
post #24 of 25 (permalink) Old 03-20-2011, 03:32 AM
Did someone say gixxers suck yet?
post #25 of 25 (permalink) Old 03-20-2011, 05:41 PM
Bro, Vcook is a stupid wealth of gixxer knowledge as is Kegger - If Kegger is offering to fix it, take him up on it - I took my 999s to him and Cook for some exhaust issue and they got 18 more HP at the wheel for me but adjusting the grips - AMAZING
Let Kegger fucks with it - He has clapped his "Mladin Rep" out more times then I have had penicillin shots
