"Basic" Oil Change How To *With Photos* - Chicagoland Sportbikes
post #1 of 31 (permalink) Old 03-18-2011, 04:24 PM Thread Starter
1shadyninja's Avatar
Sportbike: ZX9R
Years Riding: 10+ years
How you found us: Gixxer Tony
Garage
After reading crazy stories pertaining to oil changes , I was prompted to post a simple generic how to. feel free to add anything I may have left out.
Most of you may already know how to do this basic task, but for the new biker this might be somewhat helpful
1. under your bike, locate the drain plug, ( some are in the open some are hidden by the plastics)
2. get your wrench and drain pan ready
3. loosen & remove drain plug, catch oil , could be very hot , don't say I did not warn you!
4. locate and remove filter, ( modern 4cyl usually have them located in the front , some times between the header pipe.( more oil will come out of here!)Another tip I picked up a long time ago, is to put a piece of aluminum foil on top of the header, just below the oil filter. Doing this keeps the oil off of them, so it doesn't burn off and make smoke when you start the bike back up.
5. if you are handy you can drill a hole in the drain plug to put in a magnet, I used a "earth magnet" its mega powerful.
6 Replace drain plug after its done dripping,(and washer if you choose to do so.)
7 grab your
and just like doing a oil change on a car you need to put a thin film of oil on the gasket.
8. install filter and drain plug.I put my filters on by hand, and I can remove them by hand.
9.Fill ( make sure you wear gloves don't want to get oil on your camera)
Kawi was nice they put this little tag to remind me how much oil to put in
and after you refill make sure there is oil in the site-glass
then you are ready to....
every bike is different , but this is just a example to show you how easy it is.
First Place Oils
1shadyninja is offline
post #2 of 31 (permalink) Old 03-18-2011, 04:37 PM
For the new peoples:
- warm the bike up to normal operating temp or close to it before the oil change.
- take the key out of the bike while you're doing the oil change and double/triple check you've finished completely before starting it up! (sounds stupid but it's worth the precaution)
- UNDER-fill the oil slightly before checking the oil level and fine tune it from there...much easier to add a little than try to get some out if you go overboard.
post #3 of 31 (permalink) Old 03-18-2011, 04:45 PM
Beaver maintenance crew!!
RoadRuNNa's Avatar
Sportbike: 08 R6
What's the purpose for the magnet (step 5.)?
-Sonny
RoadRuNNa is offline
post #4 of 31 (permalink) Old 03-18-2011, 04:48 PM
lots of metal floating around in there.
post #5 of 31 (permalink) Old 03-18-2011, 04:55 PM Thread Starter
Sportbike: ZX9R
Garage
The magnet ?
it keeps those tiny metal pieces out of the engine.
First Place Oils
post #6 of 31 (permalink) Old 03-18-2011, 05:01 PM
RoadRuNNa's Avatar
Sportbike: 08 R6
Originally Posted by 1shadyninja View Post
The magnet ?
Good to know.... I've never done that but might start doing it..
When you change your oil, have you noticed significant deposit of metal around the magnet? Just want to know about it's efficiency.
-Sonny
post #7 of 31 (permalink) Old 03-18-2011, 05:07 PM
Also make sure the filter you took off still has the gasket attached. Every once in a while the gasket will stick to the engine, and if you don't catch it, it's a big mess upon start up.
post #8 of 31 (permalink) Old 03-18-2011, 05:54 PM Thread Starter
Sportbike: ZX9R
Garage
it has a little "Fuzz" on it, and that little bit is no longer in the oil.
Yeah the gasket is very important, you end up putting a new filter on there with a old gasket still stuck to the base .... you will have a bad day!
First Place Oils
post #9 of 31 (permalink) Old 03-18-2011, 05:57 PM
Make sure you put a bead of oil on the rubber o-ring/gasket on that new filter before you install it! Just put some on your finger and run it around the o-ring/gasket.
post #10 of 31 (permalink) Old 03-18-2011, 08:40 PM
Formerly RwS Films
PaulieRedCoat's Avatar
How you found us: Other
Also make sure you point out that Jody's pow-pow wheelie is weak and Lewi's rocking a nice stand up.
Namaste
PaulieRedCoat is offline
post #11 of 31 (permalink) Old 03-18-2011, 11:56 PM Thread Starter
Sportbike: ZX9R
Garage
I only posted that to see how long it would take Lew to visit this thread...
First Place Oils
post #12 of 31 (permalink) Old 03-19-2011, 08:35 AM
Sportbike: 01 GSXR 1k
Years Riding: 20+ years
Did you make this thread in response to the thread I started yesterday? If so, you're a fk-ing prick!
01 Gixxer 1k
94 Camaro Z28
97 Blazer 4x4
Aron is offline
post #13 of 31 (permalink) Old 03-19-2011, 11:56 AM Thread Starter
Sportbike: ZX9R
Garage
First Place Oils
post #14 of 31 (permalink) Old 03-19-2011, 12:46 PM
only partially, I was meaning to last year (thats when I took these photos)
your thread reminded me...
I'm just playing man. They need Kudos here
01 Gixxer 1k
94 Camaro Z28
97 Blazer 4x4
Aron is offline
post #15 of 31 (permalink) Old 03-19-2011, 01:52 PM
black magic
bio-nuke's Avatar
Sportbike: gxr600k8
Years Riding: 4yrs
so if you didn't warm up the oil a bit before draining then what haps
bio-nuke is offline
post #16 of 31 (permalink) Old 03-19-2011, 02:07 PM
It's thicker, won't come out as fast and can leave a little more residual oil inside.
01 Gixxer 1k
94 Camaro Z28
97 Blazer 4x4
Aron is offline
post #17 of 31 (permalink) Old 03-19-2011, 03:13 PM Thread Starter
Sportbike: ZX9R
Garage
hmmm you from CSVT?
First Place Oils
post #18 of 31 (permalink) Old 03-19-2011, 04:01 PM
You don't recognize the user name? We've met before, at RT 66
01 Gixxer 1k
94 Camaro Z28
97 Blazer 4x4
Aron is offline
post #19 of 31 (permalink) Old 03-19-2011, 05:02 PM
let the expert handle dis
warming up(running the engine) the oil will capture particulates(dirt) that are in the engine. Helps prevent sludge and metal deposits later on.
post #20 of 31 (permalink) Old 03-25-2011, 12:14 PM
black magic
bio-nuke's Avatar
Sportbike: gxr600k8
Years Riding: 4yrs
well i have done a few oil changes and that was my 2nd change on this bike. for the first time i didn't warm it up, did all the stuff and started it up and it was smoking for a bit took it out for a test ride and smoke went away.
i rode it the week before first ride of the season (old oil, gas) added gas no problems. kinda of a vib from what i thought was the front tire maybe from sitting
now i kinda notice a something from the engine when i was at light.
what about adding some seafoam you think that will clear it up
bio-nuke is offline
post #21 of 31 (permalink) Old 05-30-2011, 11:11 AM Thread Starter
Sportbike: ZX9R
Garage
Also when tightening the drain plug remember the oil pan is ALUMINUM !!!
and will strip out the drain plug very easily.
Just had a friend find that out, the hard way
was covered briefly in step #7
First Place Oils
post #22 of 31 (permalink) Old 05-30-2011, 12:25 PM
WEEE
DiamondBenz's Avatar
Years Riding: O.o
How you found us: was my cracker jack prize :(
Send a message via AIM to DiamondBenz Send a message via Yahoo to DiamondBenz Send a message via Skype™ to DiamondBenz
Thank you for this thread. Love photos!!! Very helpful for me to grasp this simple task. Well looks simple enough... I, however, may still mess something up somehow Fingers cross...
DiamondBenz is offline
post #23 of 31 (permalink) Old 05-30-2011, 07:37 PM
Sportbike: vkmbt7
Years Riding: vkmbt7
How you found us: vkmbt7
A basic oil change is a basic oil change. The dealerships are not going to do a better job than me changing it myself.............But I'm lazy and I like convenience.
After completing paperwork, I was out of here in 20 minutes, tops. My filthy carpets were vacuumed and they didn't try to sell me any unncessary maintenance such as a transmission or radiator fluid flush like other places would.
An extra $10 for tire rotations though - not so hot. But thats not why I come here. When I have the time, the best part about Speedee is that its located right next to gamestop. =)
vkmbt7 is offline
post #24 of 31 (permalink) Old 05-30-2011, 08:01 PM Thread Starter
Sportbike: ZX9R
Garage
Well if you were a real forum member not a spammer you would understand this was a thread about MOTORCYCLE oil change.
Carpets vacuumed hmm...
Tires rotated? it would be interesting with the skinny tire on the rear.
First Place Oils
post #25 of 31 (permalink) Old 05-30-2011, 09:01 PM
Good to see a basic maintenance thread.
For reference How tight is tight enough for a spin on oil filter?
post #26 of 31 (permalink) Old 05-30-2011, 09:10 PM
I use snug then add .5 turn. Then it is safety wired.
post #27 of 31 (permalink) Old 05-30-2011, 10:51 PM Thread Starter
Sportbike: ZX9R
Garage
I put mine on by hand,
I remove them by hand.
First Place Oils
post #28 of 31 (permalink) Old 06-02-2011, 02:37 PM
rx7
Sportbike: r6
Years Riding: 2yrs.
How you found us: stt
what is the ball park figure/how many quarts for an 06 r6?
rx7 is offline
post #29 of 31 (permalink) Old 06-02-2011, 02:43 PM
Dug2's Avatar
Years Riding: yes
u can wheelie?
418
Dug2 is offline
post #30 of 31 (permalink) Old 06-02-2011, 02:49 PM
3.5
