Water Wetter VS Amsoil Coolant Boost... - Chicagoland Sportbikes
post #1 of 34 (permalink) Old 04-06-2011, 10:24 PM Thread Starter
1shadyninja's Avatar
Sportbike: ZX9R
Years Riding: 10+ years
How you found us: Gixxer Tony
Garage
A lot of track riders on here,
so I'm sure there are a bunch of water wetter users .
Here is a good read.
Tested both for corrosion protection
https://www.amsoil.com/news/2011_Apr...pdf?zo=1667299
more info on the "coolant boost" can be found here
https://www.amsoil.com/storefront/rdcb.aspx?zo=1667299
First Place Oils
1shadyninja is offline
post #2 of 34 (permalink) Old 04-06-2011, 10:50 PM
Meh Id want to see the results done by a outside company.
post #3 of 34 (permalink) Old 04-06-2011, 11:05 PM Thread Starter
Sportbike: ZX9R
Garage
I think thats where the " was conducted in a independent laboratory " part comes in.
First Place Oils
post #4 of 34 (permalink) Old 04-06-2011, 11:06 PM
...only for the seriously
aptech77's Avatar
Sportbike: Triumph Speed Triple....and more
Years Riding: <100
How you found us: web
Engine Ice....ftw.
...only for the seriously quick!!!
aptech77 is offline
post #5 of 34 (permalink) Old 04-06-2011, 11:09 PM Thread Starter
Sportbike: ZX9R
Garage
Originally Posted by aptech77 View Post
Engine Ice....ftw.
Engine Ice is a "Propylene Glycol Base Engine Coolant"
Water wetter and Coolant Boost are products that can be added to straight water , or water /anti freeze mix to protect against corrosion and help lower tems with better heat transfer.
First Place Oils
post #6 of 34 (permalink) Old 04-06-2011, 11:39 PM
Registered Abuser
v2neal's Avatar
Sportbike: ATK605,CR250,VTX
Race org legal?
v2neal is offline
post #7 of 34 (permalink) Old 04-06-2011, 11:46 PM Thread Starter
Sportbike: ZX9R
Garage
Originally Posted by v2neal View Post
Race org legal?
It is a additive just like watter wetter,
here is the paragraph from the NESBA rules
"Anti-freeze is very slippery and decreases
available traction to the equivalent of ice. It is also very difficult
to clean up and has to be flushed with large amounts of water, which is
usually not available at the track. Engine Ice and Evans-type coolants
are NO longer permitted! Water Wetter is permitted."
I do know it is legal at our race track,( Grundy County Speedway)
First Place Oils
post #8 of 34 (permalink) Old 04-06-2011, 11:46 PM
Engine Ice....ftw.
not entirely track legal...
whats the cost difference between the 2 products?
post #9 of 34 (permalink) Old 04-06-2011, 11:55 PM Thread Starter
Sportbike: ZX9R
Garage
their 12ounce bottle sells for 9.95 on Amazon
our 16 ounce bottle retails for $11.10 but the CLSB discount brings it down below the watter wetter price
not sure of the mixing ratio of the WW
but our stuff you mix it like this,
For straight water applications, add 2 fl. oz. of Coolant Boost per quart of tap or softened water. For 50/50 coolant/water applications, add 1 fl . oz. of Coolant Boost per quart of 50/50 mix.
First Place Oils
post #10 of 34 (permalink) Old 04-07-2011, 09:16 AM
Dug2's Avatar
Years Riding: yes
keep sum on hand shady, i'll get some in a few weeks. i would like to try it.
i've always used ww in my bike.
418
Dug2 is offline
post #11 of 34 (permalink) Old 04-07-2011, 09:27 AM Thread Starter
Sportbike: ZX9R
Garage
I am picking up a case or 2 tonight when I go to the distribution center.
First Place Oils
post #12 of 34 (permalink) Old 04-07-2011, 09:57 AM
he who is absent foreskin
Loki047's Avatar
Sportbike: Z1000
Ill take some. Really just tap water?
Jordan
Loki047 is offline
post #13 of 34 (permalink) Old 04-07-2011, 11:32 AM
squiddish
16gkid's Avatar
Sportbike: K8 Gsxr-750
^ what he said. I am lookin to change my coolant before my trackday and this would be perfect. Are you ever in the nw burbs or the city or do you stay down in joliet?
16gkid is offline
post #14 of 34 (permalink) Old 04-07-2011, 11:36 AM
i wouldnt use tap water, a gallon of distilled is only like a dollar
post #15 of 34 (permalink) Old 04-07-2011, 11:41 AM
I'm sure someone can bring it to Winks tech day in Barrignton on the 16th if you plan on going
Shelly
post #16 of 34 (permalink) Old 04-07-2011, 11:48 AM Thread Starter
Sportbike: ZX9R
Garage
I live out south of Joliet, But I make a weekly trip to Wood Dale on Thursday evenings.
First Place Oils
post #17 of 34 (permalink) Old 04-07-2011, 12:13 PM
squiddish
16gkid's Avatar
You think i would be able to do my coolant and rearset install there?
16gkid is offline
post #18 of 34 (permalink) Old 04-07-2011, 12:17 PM
yes, basically pretty easy
rear sets are liek 30mins tops
post #19 of 34 (permalink) Old 04-07-2011, 12:43 PM
Loki047's Avatar
Sportbike: Z1000
Their directions are to use Tap
Recommendations
Dominator Coolant Boost is recommended with both racing applications using straight water coolant and automotive applications using 50/50 coolant/water mixtures.
Directions: With engine off and cool, make sure cooling system is filled with selected coolant. Shake bottle and pour calculated amount of Coolant Boost into radiator. Start engine, turn heat on high and run for 15 minutes. Do NOT use distilled water unless mixed with 50% antifreeze.
Dosage: For straight water applications, add 2 fl. oz. of Coolant Boost per quart of tap or softened water. For 50/50 coolant/water applications, add 1 fl . oz. of Coolant Boost per quart of 50/50 mix.
Jordan
Loki047 is offline
post #20 of 34 (permalink) Old 04-07-2011, 01:13 PM Thread Starter
Sportbike: ZX9R
Garage
see post #29
First Place Oils
post #21 of 34 (permalink) Old 04-07-2011, 01:44 PM
alocker's Avatar
Sportbike: 2007 GSXR 1000
Years Riding: .05 Years
How you found us: RAT
I would really like to know why the specifically say not to use distilled water in a straight water application. Seems odd.
alocker is offline
post #22 of 34 (permalink) Old 04-07-2011, 02:55 PM
i do know that distilled water is a more "agressive" solvent than tap water would be simply because it isnt already partially saturated with minerals
if that is the case and is the difference in the testing between the water wetter and coolant boost, it could go towards explaining how they got the corrosion numbers down
post #23 of 34 (permalink) Old 04-07-2011, 03:23 PM
Just to be specific WATER WETTER is allowed, or water only on the track for NESBA. NOTHING else at this point.
I just read both the PDF and the website, I don't see where it says what the Amsoil solution is made of. Please provide the info related to what it is made out of if you could please.
post #24 of 34 (permalink) Old 04-07-2011, 05:23 PM Thread Starter
Sportbike: ZX9R
Garage
here is the MSDS
http://www.amsoil.com/msds/rdcb.pdf
First Place Oils
post #25 of 34 (permalink) Old 04-07-2011, 05:39 PM
Dug2's Avatar
Years Riding: yes
does it pass inspection wink?
418
Dug2 is offline
post #26 of 34 (permalink) Old 04-07-2011, 06:01 PM Thread Starter
Sportbike: ZX9R
Garage
It has to do with the aluminum parts of in your cooling system,I will compose a nice reply later tonight or tomorrow, I am leaving here right now,
First Place Oils
post #27 of 34 (permalink) Old 04-07-2011, 06:34 PM
I sure am doing a lot of reading to find out the ingredients. Still no luck.
So NO, it does not pass inspection at this point for NESBA.
I'd be happy to review the ingredients if provided, and if it does compare with Water Wetter, I'll suggest approval to NESBA. Not reading any more documents at this point, please provide the ingredients directly and the reference document for confirmation.
Trying to help you out here.
post #28 of 34 (permalink) Old 04-07-2011, 08:55 PM
Dug2's Avatar
Years Riding: yes
post up the info wink requested shady, i am a nesbian as well and need this to
pass any/all tech inspections. after goin through that amsoil info/product booklet
u gave me i am curious on many of the products, good stuff for sure
418
Dug2 is offline
post #29 of 34 (permalink) Old 04-07-2011, 11:03 PM Thread Starter
Sportbike: ZX9R
Garage
here is what I have to offer as far as type of water,
Distilled water is very much like ionized water. Since it has a polar charge, not neutral like tap or softened water, it will attempt to steal minerals from the surrounding metals in a cooling system to balance the positive/negative charges. A 50/50 mix of anti-freeze is safe to use with distilled water, and doesn’t apply to this rule. This is why Amsoil recommends using ONLY tap or softened water when not using anti-freeze. The additives in Dominator Coolant Boost will not allow any additional corrosion to occur, as it would when using straight water only.
I will search for a answer to Wink's question
First Place Oils
post #30 of 34 (permalink) Old 04-08-2011, 10:05 AM Thread Starter
Sportbike: ZX9R
Garage
I sent a Email off to NESBA last night pertaining to this topic...
here was the reply I received just now.
Thank you for contacting us.
The Beginner and Intermediate groups are not required to change out coolant. I am not sure of the other companies additives. I will check and find out more.
Please feel free to contact us if you have any additional questions.
Please use this link to rate the response you received in this email.
Sincerely,
Bob O
First Place Oils
