How do I - Chicagoland Sportbikes
post #1 of 11 (permalink) Old 05-23-2011, 03:38 PM Thread Starter
How do I
Get the inner clip-on insert out of the clip-on? You know where the bar end screws into...
post #2 of 11 (permalink) Old 05-23-2011, 03:40 PM
^^^Bad for your hearing
streetracin1820's Avatar
Sportbike: 2007 gsxr 600
I dont have your answer.....but it might help to know what type of bike, and OEM or Aftermarket clipons and if aftermarket what type
streetracin1820 is offline
post #3 of 11 (permalink) Old 05-23-2011, 03:44 PM
post #4 of 11 (permalink) Old 05-23-2011, 03:50 PM
Addicted
eE jeremy's Avatar
most aftermarket clipon's just have a fixed cap, so I'll assume this is a stock clipon, that "insert" is probably pressed and or welded in. I don't think you'll be getting it out.
Shitty Pass Racing #513
eE jeremy is offline
post #5 of 11 (permalink) Old 05-23-2011, 04:20 PM
BandM's Avatar
Sportbike: X-1, XR-1000
How you found us: Badweb
If it's like the one in this diagram you take the weight off (bar end) thread the screw back in a few turns and tap the screw with a hammer to release the nut from the expander and then pull it out.
http://www.ronayers.com/Fiche/TypeID...oup/HANDLEBAR_
BandM is offline
post #6 of 11 (permalink) Old 05-23-2011, 04:27 PM
my 1000 has an expanding rubber plug that grips the inside of the bar loosen the screw let the plug relax a minute then wiggle it out
post #7 of 11 (permalink) Old 05-23-2011, 04:29 PM
soap and water
post #8 of 11 (permalink) Old 05-23-2011, 04:32 PM
Those things are a pain in the ass sometimes
post #9 of 11 (permalink) Old 05-23-2011, 04:33 PM
The Hondas are different than all other manufacturers and suck huge to get out undamaged.
post #10 of 11 (permalink) Old 05-23-2011, 05:23 PM Thread Starter
03 rc51, stock clip on
I have the replacement parts. Comes with the "insert inner thingy" and two rubber o-rings for each side of inner piece. Maybe I can get some pics...or if you are bored, look at the diagram on bike bandit.
Steve you should know. What's this soap and water bs?
post #11 of 11 (permalink) Old 05-23-2011, 05:28 PM
That's either his lube of choice or he is telling you that you need a bath.
