repacking D&D slip-on- end cap removal tips? - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 06-09-2011, 01:19 PM Thread Starter
rider for life
Sandman's Avatar
Sportbike: CBR1100XX
Years Riding: First let the clutch out in 1972
How you found us: no- you found me
I'm trying to re-pack a 10 year old pair of aluminum D&D slip-ons that likely have much of the sound insulation material burned out. What's the best way to remove the sleeve without damaging anything?
Sandman is offline
post #2 of 8 (permalink) Old 06-09-2011, 01:38 PM
when you drilled the rivets out did you just drill enough to remove the head or did you get the body out of the hole as well? like did the drill punch thru and into the can
post #3 of 8 (permalink) Old 06-10-2011, 08:50 PM
whack it harder is probably stuck form corrosion or d+dput a sealant in there and its glued shut.... just a guess
post #4 of 8 (permalink) Old 06-10-2011, 08:56 PM
Come get some
RideEcono's Avatar
Sportbike: V-Strom DL1000
Years Riding: 13 years
How you found us: Fam
+1. Did this a month or so on a set of 2B's. Whack it good and hard.
1979 Yamaha XS1100
2004 Suzuki V-Strom DL1000
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride! ~Hunter S. Thompson
RideEcono is offline
post #5 of 8 (permalink) Old 06-10-2011, 09:23 PM
Sportbike: 05 SV
Years Riding: ...
How you found us: ...
Make sure you whack em on the side that WONT be seen when on the bike. Chances are its just corrosion, but if you whack em that hard, any marks will be noticeable once mounted. I'm sure you know this, but when frustated when an easy job turns hard, the little details can ruin the end result.
pothiawala786 is offline
post #6 of 8 (permalink) Old 06-10-2011, 10:22 PM
use a rubber mallet for the whacking
post #7 of 8 (permalink) Old 06-22-2011, 12:02 PM
Derick's Avatar
Sportbike: R6
whack it harder
priceless advice
WERA · CCS · EX #169
Riders Discount · AllBalls Racing · Woodcraft · VinylSaurusRex · Pit Bull · Chicken Hawk Racing
Derick is offline
post #8 of 8 (permalink) Old 06-22-2011, 12:51 PM
D&D are suppose to be loud as fack. Repacking won't help.
