A cunt hair - Chicagoland Sportbikes
post #1 of 29 (permalink) Old 06-17-2011, 12:07 PM Thread Starter
A cunt hair
When checking valve clearances and adjusting them I don't think people really realize how small of an adjustment they are making or fretting over. An average cunt hair measures about 0.004 of an inch (4 thousandths).
These are the clearance numbers on the Superhawk
clearances (cold engine)
Intake: 0.16 +/- 0.03mm
exhaust: 0.31 +/- 0.03mm
If my calculations are correct you could fit 40 cunt hairs stacked on top of each other between the cam and valve shim bucket on the intake side of the superhawk.
On the SV the clearance numbres are a little more precise:
Intake: 0.10mm - 0.20mm (0.004" - 0.008")
Exhaust: 0.20mm - 0.30mm (0.008" - 0.012")
So you could fit 1 to 3 cunt hairs in there.
My point is don't fret over a cunt hair adjustment one way or the other.
post #2 of 29 (permalink) Old 06-17-2011, 12:12 PM
I'm always learning......
SloRoll's Avatar
How you found us: GPS
How many are there between the intake and the exhaust?
SloRoll is offline
post #3 of 29 (permalink) Old 06-17-2011, 12:13 PM
rimshot!
/hopefully none
post #4 of 29 (permalink) Old 06-17-2011, 01:47 PM
Since when did cunt hairs become units of measure ?
post #5 of 29 (permalink) Old 06-17-2011, 01:54 PM
The Victim Newbie
clearwaterms's Avatar
Sportbike: 2007 mountain bike
Years Riding: just started
How you found us: svrider.com
since when did the SV become a monetary symbol?
do you know how many SV's I could buy with that?
<-- Chris
clearwaterms is offline
post #6 of 29 (permalink) Old 06-17-2011, 01:58 PM
post #7 of 29 (permalink) Old 06-17-2011, 02:02 PM
BH
BH's Avatar
Sportbike: KTM
How you found us: find who?
you're mixing units
more like 1 1/2 +/- 19/64ths of a cunt hair.
BH is offline
post #8 of 29 (permalink) Old 06-17-2011, 02:47 PM
butchf's Avatar
Sportbike: none...all gone
How you found us: ken
actually Nick, those small changes relative to the condition of the valve and seat can change your timing slightly....robbing you of HP.....
Most high performance tuners would agree.
Just because the actual spec # is big doesn't mean a small change will not effect the overall performance. Most of the engines I deal with daily only have a valve clearance of .004". That is way it is so hard to use a compression gage to check. The duration is so short that most gages will not react in time.
Equally as important are the angles of the seat and valve.
..........of course, just an old mans view of the world.......
CCS race official
sold the track bike
too slow to ride
Butch @ 630-777-0273
Arch, this Bud is for you..
butchf is offline
post #9 of 29 (permalink) Old 06-17-2011, 03:32 PM Thread Starter
Since like 8 years ago. Try to keep up buddy.
Cunt Hair - A unit of Measure that means small, but actual Value depends on Application
presion machinist says "I need to shave a cunt hair off this part" .0001 inch
Carpenter Says "I need to bang that stud a cunt hair to the left" .25 inch
Astronmer says That Astroid missed the planet by a cunt hair" 60,000 miles
Originally Posted by BH View Post
you're mixing units
My bad, but you are getting my point correct?
Understood Butch. But I think you are missing my point. People seem to get all funny about 1 or 2 cunt hairs when they really don't matter too much. If I go in and find one valve a cunt hair too tight I am not going to take out the cams and put new shims in. Not over that small of a measurement
post #10 of 29 (permalink) Old 06-17-2011, 03:45 PM
Take the cams out and fix the tight one then check all valves again and you'll find one of the others a cunt hair tight.
Proper clearance assures closure and also smoothly sets the valve back on the seat which helps preserve the valve face.
The cam grind also controls valve closure.
post #11 of 29 (permalink) Old 06-17-2011, 04:34 PM
BH
BH's Avatar
Sportbike: KTM
yep, I hear you.
tolerance on the feeler gauge thickness is probably half a mil (.0005").
the tolerance between how two different people use a feeler gauge is probably 10x that amount.
BH is offline
post #12 of 29 (permalink) Old 06-17-2011, 04:37 PM Thread Starter
yep, I hear you.
So are you saying the little bit of rust or grease on the feeler gauge might make it not be as accurate? How far off? A cunt hair?
post #13 of 29 (permalink) Old 06-17-2011, 04:40 PM
A cunt hair is the .004 that most bikes want.Two cunt hairs would be out of spec.
post #14 of 29 (permalink) Old 06-17-2011, 04:42 PM
I did a google image search for "cunt hair" and I must say that I'd like to use my feeler gauge on most of the results.
post #15 of 29 (permalink) Old 06-17-2011, 04:53 PM
I haven't seen a cunt hair in 20 years. And yes, they were of age. Sickos.
post #16 of 29 (permalink) Old 06-17-2011, 04:54 PM
I did the same search and must say, I prefer to use my feeler gauge on valves that are clean and smooth.
post #17 of 29 (permalink) Old 06-17-2011, 04:58 PM Thread Starter
If you're looking for one I haven't vacuumed the van in a while.
post #18 of 29 (permalink) Old 06-17-2011, 06:47 PM
butchf's Avatar
and I miked a cunt hair the other day......... .009
CCS race official
sold the track bike
too slow to ride
butchf is offline
post #19 of 29 (permalink) Old 06-17-2011, 07:43 PM
Dug2's Avatar
Years Riding: yes
nick, allow me to help here if you would. first...you have a cunt hair, and you're
correct on the sizing. BUT!!!! you're forgetting the "blond cunt hair".....which, my good
man is exactly half the size of the normal "cunt hair". there is still a grey(misunderstood)
area on the "red cunt hair". that one will be for another time perhaps.
418
Dug2 is offline
post #20 of 29 (permalink) Old 06-17-2011, 08:11 PM
Dear Nick ,
post #21 of 29 (permalink) Old 06-17-2011, 09:23 PM
Wisconsin FIB
TripleZ's Avatar
Years Riding: Since June 2002
How you found us: Pilotx1
A "red" cunt hair is 0.005mm or a 1/5 of a thousandths. This is the standard size we use at work.
The valve lash spec, is also just the "set" area of lash that the engine is supposed to go out of the factory with, or when its checked it should be adjusted back to.
What this guarantees, is that when you check the lash at the next 10,000mile interval, the average wear will have not caused an issue. Valves just barely out of spec, will more than likely be just fine at the next check. (especially if they're on the large size).
TripleZ is offline
post #22 of 29 (permalink) Old 06-17-2011, 09:35 PM
The Plumber
Matoo's Avatar
Sportbike: 05 SV650S
Years Riding: enough
Wait, I thought a red cunt hair was the smallest measurement known to man?
Matoo is offline
post #23 of 29 (permalink) Old 06-17-2011, 09:37 PM
Wisconsin FIB
TripleZ's Avatar
Nope... i thought that was the elusive bald bearded clam hair.
TripleZ is offline
post #24 of 29 (permalink) Old 06-17-2011, 10:38 PM
Is that like a gorilla cunthair?
post #25 of 29 (permalink) Old 06-17-2011, 10:57 PM
Nexus's Avatar
Sportbike: nada
Years Riding: 18
How you found us: No idea
When I Google searched "Cunt SV" I think Google translated that to "Custom SV" and I found this...
DAAYUM!
Nexus is offline
post #26 of 29 (permalink) Old 06-17-2011, 11:12 PM
One RCH is a standard unit of measurement......the BCH being slightly thicker.
The perfect backyard measurement device.
post #27 of 29 (permalink) Old 06-18-2011, 12:01 AM
this thread delivers.....cunt hair! YUK!!!!
post #28 of 29 (permalink) Old 06-18-2011, 08:19 AM
Sarcasm in every post.
scout67's Avatar
Years Riding: 20+yrs.
PSA to all the ladies of the forum:
1) Do Not dye those hairs! It completely alters our precise measurements.
2) Don't freak out when we request a few hairs for later. We're not sickos, we are just running low on hair gauges.
3) Consider helping us, by allowing us access to your friends hairs, especially if theirs are a different color than you own. It is very important to have a wide range of accurate measuring devices.
Thank you for your help in this matter.
Ken.
My Garage.
scout67 is offline
post #29 of 29 (permalink) Old 06-18-2011, 08:37 AM
Dug2's Avatar
Years Riding: yes
Talking
nice scout!
418
Dug2 is offline
