Pressing out/in steering stem - Chicagoland Sportbikes
post #1 of 17 (permalink) Old 06-21-2011, 07:14 PM Thread Starter
Automotive Afficianado
Julian@MotoCARR's Avatar
Sportbike: Trek
Years Riding: 3285 days and counting
How you found us: CLSB found me...
Send a message via AIM to Julian@MotoCARR
I think I am going to have to seek out a shop or someone who can press out a steering stem from a KZ750 lower triple and then press it into most likely a '04-'05 GSXR lower triple. I'm sure I could remove it but I think it would involve alot of hammering and I don't think thats how they were inserted in the first place from the factory . Suggestions?
post #2 of 17 (permalink) Old 06-21-2011, 08:20 PM
resurection
post #3 of 17 (permalink) Old 06-21-2011, 09:42 PM
Oh boy.
ya know they don't just swap.Sure sounds like fun though,
Your right. There maybe some hammering.
post #4 of 17 (permalink) Old 06-21-2011, 09:47 PM
Oh boy.
each one of these statements is true.
post #5 of 17 (permalink) Old 06-21-2011, 10:07 PM
BanditCPA's Avatar
Years Riding: since 1998
Get a micrometer and take several measurements of the stem where it fits in the triple. I did this on my bandit when swapping out the forks, and noticed it is tapered from the bottom of the stem to the top ( wider at the bottom) find someone with an arbor press and press the stem out of the triple from the top down and the opposite side when pressing in the new stem. Also watch for any retaining clips at the bottom of the stem (Suzuki used them on the bandit as well as the hayabusa)
Hope this helps
BanditCPA is offline
post #6 of 17 (permalink) Old 06-21-2011, 10:25 PM
That means Gus has to dig the press out of the corner. It's burried in a sea of motorcycles right now.
post #7 of 17 (permalink) Old 06-21-2011, 10:38 PM
ceptor's Avatar
Sportbike: Honda Interceptor
I am in Stone Park and have a press. I have pressed bearings, bushings, ball joints, gears, etc. This sounds like we can do it. Give me a call.
Micron Engine. 708 343 6007
ceptor is offline
post #8 of 17 (permalink) Old 06-21-2011, 10:45 PM
Silly goose at the least you'll have to mix bearings or modify a race DIA.
Chance of it being a straight swap.Go by a lottery ticket.
post #9 of 17 (permalink) Old 06-21-2011, 10:48 PM
Buried is the word for it.
Hope you travels are going well?
post #10 of 17 (permalink) Old 06-22-2011, 09:46 AM
You can measure it all you want, but if you don't have it out, it won't matter. You have to pull them apart and measure them. I swapped stems once. They were .002 different. One pressed in tight. The other fell through.
I have a press, but don't know when I'll be around the next few days.
post #11 of 17 (permalink) Old 06-22-2011, 10:07 AM
.002 makes no sense Greg.The top stem dia is just undersize so the bottom race can fit over it.Is this what you mean??
1 mm .039 would be the next dia. up or down.
post #12 of 17 (permalink) Old 06-22-2011, 11:53 AM Thread Starter
Sportbike: Trek
I probably should have put this additional info up in the first post lol. I'm not trying to undertake this swap blind. After searching and reading build threads on other forums, the general consensus when it comes to swapping front ends is to swap the KZ stem into the new triple. The other option of finding a stem from another bike to swap onto the KZ is stem length(mind out the gutter ). From what I have seen others attempt, the sportbike stem is too short for the KZ neck, and I can use regular KZ bearings which I need to replace anyway.(I make it sound like a piece of cake huh lol).
post #13 of 17 (permalink) Old 06-22-2011, 12:52 PM
What are the chances that the KZ stem will fit correctly into either the top or the bottom gsxr triple? I'd say 0%. You'll probably need to either have spacers made or drill out the triples, probably the former.
post #14 of 17 (permalink) Old 06-22-2011, 01:15 PM
BanditCPA's Avatar
you might try the lower triple from a zx instead of a gsxr (the fit may be similar for in-house brands)
post #15 of 17 (permalink) Old 06-22-2011, 01:42 PM
Registered Abuser
v2neal's Avatar
Sportbike: ATK605,CR250,VTX
Why not have a machinist make a new stem for the triple and the proper diameter for the bearings?
This is the route I went when I put Mille forks on my SuperHawk. I used the 'Priller triples and had a guy make me a new stem. Cost $100 or less and turned out very nice and bolt on with no jabogey spacers or anything.
Good Luck.
v2neal is offline
post #16 of 17 (permalink) Old 06-22-2011, 01:47 PM
Nope.
Sorry. It made sense in my head
Doesn't really matter.
It's never as easy as it seems it should be.
post #17 of 17 (permalink) Old 06-22-2011, 03:44 PM
The troubles I've faced are the stem Dia. and frame Dia. might not come as a set standard.
A bushing to fit between the stem Dia. and the larger bearing I.D. Will offer more options.
I do like the kaw front end idea though as you might get luck as said above.
