Front brakes dragging - Chicagoland Sportbikes
post #1 of 20 (permalink) Old 07-08-2011, 10:03 AM Thread Starter
Derick's Avatar
Sportbike: R6
is this normal? When I spin the wheel I can hear the pads dragging on the rotors. Is it time to disassemble the calipers and clean?
WERA · CCS · EX #169
Riders Discount · AllBalls Racing · Woodcraft · VinylSaurusRex · Pit Bull · Chicken Hawk Racing
Derick is offline
post #2 of 20 (permalink) Old 07-08-2011, 10:06 AM
Yes it is normal but only to a point. if you can't spin the wheel one revolution when you spin it then yeah thats bad.
post #3 of 20 (permalink) Old 07-08-2011, 10:08 AM Thread Starter
Derick's Avatar
Sportbike: R6
ok then its not that bad
Derick is offline
post #4 of 20 (permalink) Old 07-08-2011, 01:48 PM
What Steve said. You'll always have just a little drag. With EBC pads I used to get 1-2 turns on the 600RR. Vesrah pads seem to drag a little less. Anything less then 1 full turn is to much!
post #5 of 20 (permalink) Old 07-08-2011, 06:24 PM
Safety First's Avatar
clean the brake dust out of your calipers...once it builds up then then the wheel won't spin as much.
That's why you see good AMA teams clean their calipers everyday....attention to detail and reduces that little bit of drag.
Also, spin the wheel and make sure you don't have a really slightly bent rotor dragging i one spot...that happens all the time as well.
Kevin Hanson
Safety First Racing
Louisville, KY
[email protected]
Safety First is offline
post #6 of 20 (permalink) Old 07-08-2011, 09:26 PM
Dug2's Avatar
Years Riding: yes
^ here it is
418
Dug2 is offline
post #7 of 20 (permalink) Old 07-08-2011, 09:35 PM
butchf's Avatar
Sportbike: none...all gone
How you found us: ken
It is always time to clean. When in doubt, clean it out.
CCS race official
sold the track bike
too slow to ride
Butch @ 630-777-0273
Arch, this Bud is for you..
butchf is offline
post #8 of 20 (permalink) Old 07-09-2011, 12:41 AM
You may also want to check wheel bearings for drag or slop.
post #9 of 20 (permalink) Old 07-10-2011, 03:54 PM Thread Starter
Derick's Avatar
Sportbike: R6
how do I clean the dust out?
Derick is offline
post #10 of 20 (permalink) Old 07-10-2011, 05:05 PM
beac83's Avatar
Sportbike: A couple
1). Pull the caliper off the fork (one at a time).
2). Remove the pad pins and pads. Keep track of which pad is which. You will want to re-install them in the same orientation.
3). Use the brake lever to push out the pistons a bit farther than the dust rings showing on the sides of the pistons, but not all the way out.
4). Dip a Q-Tip in new, clean brake fluid and use that to remove dust and clean the pistons. I also clean the parts of the caliper near the pistons.
5). Push pistons all the way back in (watch your reservoir so that it doesn't overflow).
6) Re-install pads and pad pins. This is a good time to check the pins for grooves and other gunk and clean them as well so that the pads slide smoothly across the pins. Torque pin bolts to spec. I usually use a drop of locktite on them as well.
7). re-install caliper on fork and torque to spec, also using a drop of locktite. If your caliper and pin bolts are safety wired, you can forget the locktite.
Now do the other caliper.
When all is back together, REMEMBER TO PUMP UP THE BRAKES! Squeeze the brake lever repeatedly until the brakes are firm and solid. Bleed if necessary at that point.
________________
beac83 is offline
post #11 of 20 (permalink) Old 07-10-2011, 05:17 PM Thread Starter
Derick's Avatar
Sportbike: R6
Thanks craig
Derick is offline
post #12 of 20 (permalink) Old 07-10-2011, 07:39 PM
brake cleaner with a toothbrush, Q-Tips, etc.
Soap and water with the following above as well.
Kevin Hanson
Safety First Racing
Louisville, KY
[email protected]
post #13 of 20 (permalink) Old 07-16-2011, 10:18 PM Thread Starter
Derick's Avatar
Sportbike: R6
So I had a chance to clean them. I noticed that not all the pistons move equally. One of them doesn't seem to move at all until the other 3 are fully extended. Is it time to fully disassemble and clean these? I still get about a turn and a half out of the wheel
Derick is offline
post #14 of 20 (permalink) Old 07-16-2011, 11:22 PM
^^^^ there is no back pressure thats why they are not all coming out at same time
post #15 of 20 (permalink) Old 07-16-2011, 11:37 PM Thread Starter
Derick's Avatar
Sportbike: R6
What's that mean?
Derick is offline
post #16 of 20 (permalink) Old 07-16-2011, 11:44 PM
What's that mean?
Back pressure meaning you have none pressing back on the pistons
post #17 of 20 (permalink) Old 07-16-2011, 11:49 PM Thread Starter
Derick's Avatar
Sportbike: R6
Is this normal?
Derick is offline
post #18 of 20 (permalink) Old 07-17-2011, 09:20 AM
beac83's Avatar
Sportbike: A couple
That's how my calipers are on the track bike. I think it's normal. They even did that after a total rebuild a while back.
On the track I don't experience any symptoms of problems, such as pads wearing unevenly or anything.
Turn and a Half is good for nice, tight brakes.
________________
beac83 is offline
post #19 of 20 (permalink) Old 07-17-2011, 01:17 PM
alocker's Avatar
Sportbike: 2007 GSXR 1000
Years Riding: .05 Years
How you found us: RAT
I have never seen a caliper where all the pistons moved out equally when pumping them up.
Many times my pads seem tight when I put in new pads or re-assemble the front wheel, but as soon as they heat cycle, the wheels spins nice and free.
_________________
CCS AM 454
alocker is offline
post #20 of 20 (permalink) Old 07-17-2011, 04:59 PM
Is this normal?
See above mine even do it
