Battery issue. - Chicagoland Sportbikes
post #1 of 13 (permalink) Old 07-25-2011, 10:00 PM Thread Starter
Slava
spetsnaz56's Avatar
Years Riding: Since '98
Battery issue.
After the winter break my battery died on me due to my laziness of not getting a battery tender. I tried to recharge it, but it was a no go. So I decided to get a new one. I've always used YUASA batteries and never had any issues. I decided to save some money and get a cheaper dry cell battery. I got my battery and it lasted me exactly 150 miles. While I was riding before it quit on me, the bike would smell like sulfur. I took the battery out and it was swollen. I shipped it back and got it replaced. The new battery lasted me exactly the same amount of miles. I contacted the seller and he told me that it's my bike overcharging the battery and swelling the batteries. I'm confused because I never had issues like this with a standard battery and only experienced this with the dry cell. Can I please get some advise on what might the problem be? Thank you.
spetsnaz56 is offline
post #2 of 13 (permalink) Old 07-25-2011, 11:14 PM
First of all you get what you pay for when it comes to batteries.Spend the extra money and get a Yuasa like you should have. Batteries Plus sells a quality product but get the more expensive one because you get what you pay for.
Now, as far as the charging system goes... Once you get a good battery in the bike check the DC voltage at about a steady 4000 rpms. It should be around 13.5 to 14 volts. If it as significantly more or less than that you have a problem. Then pull the plug that goes from the stator to the voltage regulator. It's typically a 3 wire plug. On each of the 3 wire combos (with your meter on AC) you should read roughly between 50 and 80 volts AC coming out at a steady 4000 RPM. Yes the bike needs to be running to do the test on both the AC and DC measurements. Remeber there are 3 seperate measurements that need to be made coming out of the stator typically. You don't need to rev the piss out of it to get the mearsurements either.
Follow me? Are you with me? Comprende?
post #3 of 13 (permalink) Old 07-26-2011, 12:07 AM
What Nick said or just a new bike.
post #4 of 13 (permalink) Old 07-26-2011, 12:32 AM
Jewrassic Park Runaway
samal's Avatar
150 miles is what you ride a year, so just splurge on a new battery once a year, no big deal!
samal is offline
post #5 of 13 (permalink) Old 07-26-2011, 01:47 AM
There is no way that he rides that many miles a year.
post #6 of 13 (permalink) Old 07-26-2011, 01:50 AM
try
not
to
laugh
post #7 of 13 (permalink) Old 07-26-2011, 04:17 AM
suggest you slow charge the new battery first. 2nd, check how much voltage is being put out.
3rd. the "cheap" batteries, are really fawking cheap. and they don't last long
post #8 of 13 (permalink) Old 07-26-2011, 05:40 AM Thread Starter
Slava
spetsnaz56's Avatar
Hey Stan can you do that check? I don't have a voltage meter. BTW I ride about 200 miles a week.
post #9 of 13 (permalink) Old 07-26-2011, 04:27 PM
You're welcome for the explanation...
post #10 of 13 (permalink) Old 07-26-2011, 04:29 PM
Sure , call me .
post #11 of 13 (permalink) Old 07-26-2011, 04:35 PM
To help understand what Nick said, follow this chart:
https://www.chicagolandsportbikes.com...ad.php?t=87865
post #12 of 13 (permalink) Old 07-27-2011, 06:43 AM Thread Starter
Slava
spetsnaz56's Avatar
Thank you for the explanation.
post #13 of 13 (permalink) Old 07-27-2011, 09:48 AM
Ciao Marco
Daryl's Avatar
Sportbike: 50 cc Chinese POS
Years Riding: best years of my life..
Same Circus, Different Clown
Daryl is offline
