Tire pressure question - Chicagoland Sportbikes
post #1 of 12 (permalink) Old 08-09-2011, 11:13 PM Thread Starter
Nic
Nic's Avatar
Sportbike: '07 FZ6
Years Riding: Since June 2, 2010
How you found us: Neighbor chased me down
So, my Fz6 book calls for 33 psi in front and 36 in the back
My buddy, who has been riding for 15 years, currently on a Concours, daily 80 mile rain or shine commuter…. Says, “I always run way higher than the spec… put’em at 39 and 40”.
Is my buddy an ignorant tool or does he have a point? I thought there would be traction loss so I left them at spec.
Nic is offline
post #2 of 12 (permalink) Old 08-09-2011, 11:15 PM
Guns prevent pollution
spoil9's Avatar
How you found us: smartrider
Leave it at spec. I inflate my car tires and my blow up doll to higher specs but I don't like taking the chance of a blow out on the bike.
- Will
spoil9 is offline
post #3 of 12 (permalink) Old 08-09-2011, 11:16 PM
Is your buddy a Yamaha engineer ?
post #4 of 12 (permalink) Old 08-09-2011, 11:26 PM
I don't know...
Germany's Avatar
higher pressure, less movement in the rubber,
less movement in the tire, less heat generated... less traction
less movement in the tire, smaller contact patch... less traction
higher pressure, less wear however is it worth it to risk a crash?
forgot one thing....
when do you check the tire?
OEM specs are cold, if your buddy checks his tires after riding for a while(hot) he might be RIGHT....
#19
Germany is offline
post #5 of 12 (permalink) Old 08-09-2011, 11:34 PM
Ur buddy is an idiot. Plain and simple.
post #6 of 12 (permalink) Old 08-10-2011, 08:18 AM
Yup, plain and simple
post #7 of 12 (permalink) Old 08-10-2011, 08:56 AM
We ride tomorrow?
jkrueger's Avatar
Sportbike: i like 04's
Years Riding: not enough
How you found us: NESBA.com
check the specs for the tire on the bike, not the majical numbers your bike manual gives you for all tires
jkrueger is offline
post #8 of 12 (permalink) Old 08-10-2011, 09:09 AM
Meh ....
On a bike ridden two-up a big sport touring or touring bike .... where tire wear is more
critical than optimum grip many bikes respond well to slightly higher pressures.
Even on a sport bike used for commuting ..... a little extra pressure reduces
tire wear, reduces the tendancy for the tire to track pavement lines ( crack - steer )
but it also reduces GRIP.
It's all a trade-off.
Tires should always be set cold.
You should never exceed the maximum pressure on the tire sidewall.
You should set your pressures with your ride in mind - street pressures do not work on
the track. Touring / commuting pressures don't work well for crankin it solo ...
IMO 39 + 40 is really hard unless you are riding two-up. 38r +36f is my idea of a
good street pressure .... unless I am planning to push ..... then it's more like 34r, 32f.
post #9 of 12 (permalink) Old 08-10-2011, 09:26 PM Thread Starter
Nic
Nic's Avatar
Sportbike: '07 FZ6
Yea, that's what I thought. I will leave them at spec and shun my buddy.
Nic is offline
post #10 of 12 (permalink) Old 08-10-2011, 09:41 PM
You're more likely to have a blow out from to low a tire pressure rather then to high.
post #11 of 12 (permalink) Old 08-15-2011, 07:20 AM
Moto-Sexual....
SmartBiker's Avatar
Years Riding: one month
How you found us: NickIF
with a lower tire pressure for street riding, you have a higher chance of bending your rim over a pothole.
the air acts as a cushion to withstand the shock of hitting a pothole
by me changing tires ive seen plenty bent rims
i run 40/40 with no problems on the street
when i did track i ran much lower pressures for faster lap times
<-----Mr. Vern
SmartBiker is offline
post #12 of 12 (permalink) Old 08-15-2011, 07:33 AM
Cougar8000's Avatar
Sportbike: 2006 FZ1
Years Riding: I only take walks
Send a message via Yahoo to Cougar8000
Keep it at what ever says on your sticker. You can also check tire mfg as they often have their recommended specs for your bike.
Alex - Certifiable MSF Instructor
2006 Yamaca FZ1
The truly happy person enjoys the scenery on a detour
A man should choose a friend who is better than himself. There are plenty of acquaintances in the world; but very few real friends.
RIDE for Kids Donations
https://www.mishacycles.com
MishaCycles on facebook
Misha Tactical Arms, Inc
Cougar8000 is offline
