Stale gas gunk/residue in tank - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 09-09-2011, 01:00 PM Thread Starter
Droopydawg's Avatar
Sportbike: '86 SRX6, '87 SRX250, '85 VF1000R, '67 Ducati 250, '64 Benelli Cobra
Years Riding: 25
How you found us: Member on Georgia Sportbike forum.
Send a message via AIM to Droopydawg
A friend brought me an old GS650 to fix up for him and the fuel tank had fuel in it for so long, that the gas was black when I poured it out, and left a thick tarry black (gas reverted back to oil) mess in tank. Since I cant submerge the entire tank in a vat of Mineral Spirits and wait for it to disolve, what other solutions are there?
Thinking about whacking the outside with a soft rubber mallet (to loosen up) then running garden hose from laundry room sink to outside the house and flush with hot water to help dissolve and loosen it up.
What else can I try? Pour a bottle of Janitor-in-a-drum or Simple Green in there and slosh it a around off and on over the weekend? Fill with Dawn dish liquid (degreaser) and water and let it sit?
The carbs were a mess, and spray carb cleaner, as well as soaking in mineral spirits for a few days cleared them up.
Ill line it (POR15) later, and dont want to line over the mess that is in there now.
Thanks!
Chicks dig guys with hippohands on their sportbikes.
Drew "Droopydawg" Mobley
Certified Motorcycle Technician-Dekalb Technical Institute (Georgia), '07
Droopydawg is offline
post #2 of 8 (permalink) Old 09-09-2011, 01:06 PM
Instigator
bigbaddiesel's Avatar
Sportbike: 2003 Yamaha R6
Years Riding: 8
How you found us: Google!
A few options here IMO:
1) Plug the petcock, fill it up with gas, let it sit for a day, drain, rinse, repeat
2) Same drill, but use something stronger -- spirits, degreaser, etc
3) Off the wall, but a pressure washer would knock it loose i imagine
Can always shake the tank up a bit too
Those are my ideas -- im sure there will be others
2003 Yamaha R6 Raven Limited Edition
Cages:
1999 Ford F250 (Gas Sucker)
2001 VW Golf TDI (Gas Saver)
bigbaddiesel is offline
post #3 of 8 (permalink) Old 09-09-2011, 03:44 PM
NO WATER!!!!!! youll create a rust problem youll regret forever
fill the tank with a petroleum solvent and let it soak, swishing it around a few times a day
post #4 of 8 (permalink) Old 09-09-2011, 03:47 PM
maybe throw some BBs and seafoam in there while you shake it?
post #5 of 8 (permalink) Old 09-09-2011, 03:50 PM
BlackBettyR1's Avatar
Sportbike: 2007 Yamaha R1
Years Riding: Off Road-15; Street-8
^What he said.
You could try this http://store.usavediscountmarine.com...Code=STA-93664. Haven't tried it myself though. I have never let gas get that bad.
BlackBettyR1 is offline
post #6 of 8 (permalink) Old 09-09-2011, 03:51 PM
Addicted
eE jeremy's Avatar
fill it with acid for one hour, drain, then coat with POR15.
Shitty Pass Racing #513
eE jeremy is offline
post #7 of 8 (permalink) Old 09-09-2011, 04:11 PM
phosphoric acid is prefered as it will phosphate coat the steel and give it a little bit of rust resistance
post #8 of 8 (permalink) Old 09-09-2011, 05:26 PM Thread Starter
Droopydawg's Avatar
Years Riding: 25
Originally Posted by BlackBettyR1 View Post
^What he said.
Bike has been sitting under a tarp, under a deck/patio for over 10 years in Charlotte, NC. I think the old gas and muck actually kept the tank from rusting threw the metal of the tank.
