any aluminum welders on here? - Chicagoland Sportbikes
post #1 of 15 (permalink) Old 03-31-2012, 10:58 AM Thread Starter
1 piece at a time
hexraptor's Avatar
Years Riding: Since I joined!
So the right rearset is cracked, and apparently not manufactured anymore
I would imagine an experienced guy/gal wouldn't have an issue, cracked cleanly at 2 points, ~1" long each, I'd guess near 1/2" thick. I can get pics later tonight if they'd help. TIA
If I can get it done soonish, that would be awesome! I was planning on $45 for the new one, hopefully thats enough.. No idea what to expect on pricing for welds tbh. I'm in mchenry county, closer the better! lol
- Steve
hexraptor is offline
post #2 of 15 (permalink) Old 03-31-2012, 11:53 AM Thread Starter
1 piece at a time
hexraptor's Avatar
Best I can do for a pic for now, taken off a microfiche. Part seen from left side (seeing inside edge)
- Steve
post #3 of 15 (permalink) Old 03-31-2012, 02:34 PM
PM ceptor. He has a shop in Melrose Park, and is a really nice guy.
post #4 of 15 (permalink) Old 03-31-2012, 06:09 PM Thread Starter
1 piece at a time
hexraptor's Avatar
Danke! Hi Dave! In Florida for the easy access to disneyworld I take it?
- Steve
post #5 of 15 (permalink) Old 03-31-2012, 06:22 PM
Pierced & tattooed freak!
GixxerDave's Avatar
Sportbike: 1999 GSX-R750
Heya Steve, besides your clean crack (giggity), how's your bike coming along?
GixxerDave is offline
post #6 of 15 (permalink) Old 04-02-2012, 12:57 PM
Try Stuart at SMR Components in Mundelein.
post #7 of 15 (permalink) Old 04-02-2012, 01:27 PM Thread Starter
1 piece at a time
hexraptor's Avatar
lol almost done
had to rebuild carbs, new oil cooler, forks, clutch cover, had wills rim repair do the front rim (spectacular job btw).. now just waiting til a warm weekend to throw another $25 primer paint job, its too ugly for pics yet
Just the rearset and a 'real' carbtune and it's done, wooot. Still have to find someone that is good at carbs yet though, not sure if woodstock harley does carb tuning; have to get over my social anxiety and actually call them up sometime I guess, lol.
- Steve
post #8 of 15 (permalink) Old 04-03-2012, 11:34 AM
GixxerDave's Avatar
lol almost done
Would a Harley dealer give you crap for bringing a crotchrocket in for carb work?
post #9 of 15 (permalink) Old 04-03-2012, 11:40 AM
yes they will
post #10 of 15 (permalink) Old 04-05-2012, 01:29 PM Thread Starter
1 piece at a time
hexraptor's Avatar
oh clsb how I <3 thee
job well done by BandM, can't thank him enough! Next on the list is a carb sync and see how she runs from there
So I've decided that harley is a last resort, now that you guys mention that..my gangly ass looks out of place around harleys as it is, added to the jap-crap I'd be bringin in
- Steve
post #11 of 15 (permalink) Old 04-05-2012, 02:01 PM
The Victim Newbie
clearwaterms's Avatar
Sportbike: 2007 mountain bike
Years Riding: just started
How you found us: svrider.com
what about Gus - its a little bit of a drive, but i have heard good thigns. If the bike runs at all you could probably ride it down to him.
<-- Chris
clearwaterms is offline
post #12 of 15 (permalink) Old 04-05-2012, 02:28 PM Thread Starter
1 piece at a time
hexraptor's Avatar
Ressurection Gus? I'll see how it runs after the sync, has bog at WOT that goes away 1/8th turn off full throttle, assuming jet size is wrong (clips settings are 3/4 throttle if i'm not mistaken?) It's no where near as bad now that i've gotten the pilot screws set closer to where they should be (or at least better than they were)
But then again, reading up on it if my pilot circuit is jacked up (I still have it set slightly rich to keep it from running lean and burning shtuff up) it affects everything else. Still in the air as of yet..
- Steve
post #13 of 15 (permalink) Old 04-05-2012, 02:42 PM
Gus does not have an aluminum welder. We do however have a resource that can weld aluminum.
With that being said you cannot weld the cheep pot metal crap the stock footpeg bracket is made out of. Gus could make you one out of aluminum or steel though that would work exactly the same but it would be several hours of work if I had to make a bet.
post #14 of 15 (permalink) Old 04-06-2012, 06:32 PM
BandM's Avatar
Sportbike: X-1, XR-1000
How you found us: Badweb
Thanks Steve, glad I could help out.
Not so, it welded just like any other aluminum casting repair I've done in the past 30 years, like butter.
BandM is offline
post #15 of 15 (permalink) Old 04-06-2012, 08:38 PM
The Victim Newbie
if it runs at all now have Gus sync the carbs. That was what I meant.
<-- Chris
