2005 Malaguti Ciak 50 idles at redline. Help? - Chicagoland Sportbikes
post #1 of 13 (permalink) Old 04-07-2012, 04:26 PM Thread Starter
I picked this little beastie from a fella at work. It starts first kick (battery is dead) and reves to redline. I tried disconnecting the electric choke (it sits on top of the carb), backing out the air mixture screw, and even disconnected the throttle cable. All with the same results. The Internet points to an air leak? Any help would be appreciated!
post #2 of 13 (permalink) Old 04-07-2012, 04:36 PM Thread Starter
Okay, I stuck my finger in this thing (looks like a PVC filter should go there but right now it's wide open), and the idle came down.
** edit I'm pointing at it with the screwdriver.
Double edit, looked at some online manuals, I don't think anything goes there.
post #3 of 13 (permalink) Old 04-07-2012, 05:52 PM
clean the carb and re-adjust your idle stop
and that not a pcv port its an air snorkle for the airbox
post #4 of 13 (permalink) Old 04-07-2012, 05:54 PM Thread Starter
The fella that owned it cleaned it recently. Not saying he did it right, just sayin'.
post #5 of 13 (permalink) Old 04-07-2012, 06:01 PM
mmm hmmm
first think i did was change all the fluids when i bought my 600, and the PO said he just did it all
post #6 of 13 (permalink) Old 04-07-2012, 07:01 PM
Did you try dousing it with gas and lighting it on fire ?
MOTO AND MOTOR
1906 TECHNY RD.
NORTHBROOK IL 60062
SALES*SERVICE*PARTS
847-790-4848
post #7 of 13 (permalink) Old 04-07-2012, 11:14 PM
hahaha, best post of the night.
post #8 of 13 (permalink) Old 04-08-2012, 12:32 AM
post #9 of 13 (permalink) Old 04-08-2012, 08:53 AM Thread Starter
Shut it Stan! I'm going to go through the carb, it seems to be the problem. Also the slide may be backwards, so I'll check that out too.
post #10 of 13 (permalink) Old 04-08-2012, 02:59 PM
Is the slide stuck ?
MOTO AND MOTOR
1906 TECHNY RD.
NORTHBROOK IL 60062
SALES*SERVICE*PARTS
847-790-4848
post #11 of 13 (permalink) Old 04-08-2012, 04:09 PM
dave did dousing it help any?
been my experience that the slides wont go in backwards but where theres a will theres a way i guess.
did you turn the idle screw back out?
post #12 of 13 (permalink) Old 04-08-2012, 04:16 PM
lust for bikes!
nouseforaname's Avatar
Sportbike: a prostitute
Years Riding: a prostitute
first have a fat girl pee on the handle bars. then bounce thirteen large un pitted black olives off the seat and into a whipped cream pie of your choosing. i found chocolate or bananna to work the best. eat the pie and swallow the pits. guaranteeing this will work.
nouseforaname is offline
post #13 of 13 (permalink) Old 04-08-2012, 07:52 PM Thread Starter
Seems like a throttle cable problem? I can take apart the throttle tube, and it idles really well. Button it back up, and randomly it will throttle up. It's almost like the cable isn't long enough. The slide moves okay, it's oily when I pull it out. The curved side of the slide goes toward the air filter, flat side towards the engine, right? I have adjusted the idle screws, not much happening there because the cable seems tight.
