Dim lit neutral light while in gear - Chicagoland Sportbikes
post #1 of 5 (permalink) Old 05-10-2012, 06:11 PM Thread Starter
Sportbike: a little blue one
2004 gsx-r 1000
Rode her for a while today and then mid ride the light for neutral (green) was all of the sudden dimly lit while I was in gear (any gear).
If I clutched in - the light disappears, and if I put it in neutral the light is fully lit (as normal).
I turned off the bike and let her sit for a minute and started her back up. The issue was gone, however, it came back 10 minutes later after I rode again.
--- What is going on?
--- According to Google Mechanic (TM) - this is a faulty gear switch? does that sound right?
Dredd is offline
post #2 of 5 (permalink) Old 05-10-2012, 06:24 PM
sure, test it with an ohmmeter
post #3 of 5 (permalink) Old 05-10-2012, 06:31 PM
Check the flux capacitor.
post #4 of 5 (permalink) Old 05-10-2012, 07:18 PM
Pierced & tattooed freak!
GixxerDave's Avatar
Sportbike: 1999 GSX-R750
I had similar problems with my dash, lights going on and off for apparently no reason, especially the light behind the tachometer. Turned out it was 1 exposed wire coming out of the junction where you plug all that stuff into the dash. Water probably shorted something intermittently, so I just wrapped up the exposed wire with electrical tape and it was fixed. Strangely enough DGY couldn't find the problem when I dropped the bike off there once a couple of years back when I had the annual service done on it. I ended up finding the cause when Ken (Odysseys) had the bike apart and we started puting it back together again after painting.
Ken
GixxerDave is offline
post #5 of 5 (permalink) Old 05-10-2012, 07:26 PM
I noticed too the flux capacitor was loose.
