Assist on shock install in Chicago? - Chicagoland Sportbikes
post #1 of 26 (permalink) Old 05-15-2012, 10:05 AM Thread Starter
Sportbike: '06 SV650N
Just got my new shock in today, hoping to get it installed this week before a track day memorial weekend.
I have a rear stand, but don't have jackstands to unload the swingarm, and could use an extra set of hands. Anyone in the Lakeview area that can assist tomorrow or sometime next week?
nicotine is offline
post #2 of 26 (permalink) Old 05-15-2012, 10:15 AM
Derick's Avatar
Sportbike: R6
I''m in wicker park, I can help out this weekend
WERA · CCS · EX #169
Riders Discount · AllBalls Racing · Woodcraft · VinylSaurusRex · Pit Bull · Chicken Hawk Racing
Derick is offline
post #3 of 26 (permalink) Old 05-15-2012, 10:19 AM Thread Starter
Unfortunately, I'm out this weekend in Michigan -- my only real possible dates are Thursday, and Monday/Tuesday. Wednesday-Friday I'm traveling, and Saturday is my track day.
Took much much longer than anticipated to actually receive the shock. :/
nicotine is offline
post #4 of 26 (permalink) Old 05-15-2012, 10:38 AM
Derick's Avatar
Sportbike: R6
sorry mang, keep looking, good luck, worst case just go pick up some car jack stands from the local parts place and use those. put bike on rear stand, put jack stands under pegs, remove tire, remove rear stand, pull shock
Derick is offline
post #5 of 26 (permalink) Old 05-15-2012, 10:42 AM
hang it from the grab rail
post #6 of 26 (permalink) Old 05-15-2012, 10:46 AM Thread Starter
Thinking about that possibility,but then I need to reinstall the grab rail. And go buy ratchet straps.
I've read I can swap it without pulling the rear tire, though.
nicotine is offline
post #7 of 26 (permalink) Old 05-15-2012, 10:56 AM
Derick's Avatar
Sportbike: R6
you can swap without removing the tire, it just makes it easier with the tire out of the way
Derick is offline
post #8 of 26 (permalink) Old 05-15-2012, 11:32 AM
Must... brake... later...
mikdivad's Avatar
I'm in Irving Park if you need a hand. Got everything you need.
mikdivad is offline
post #9 of 26 (permalink) Old 05-15-2012, 12:03 PM
how are you going to a track day and have no rachetstraps?
be careful when youre doing this the bike MUST be supported securely very securely, if it comes down with fingers in there it can easily crush or if in the right sopt sever a finger
post #10 of 26 (permalink) Old 05-15-2012, 12:14 PM
Sportbike: 05 SV
Years Riding: ...
How you found us: ...
If you have the stock pegs, flip them upside down, lift up with the rearstand, and then lower it onto jackstands under the pegs.
I've done this on an SV, you don't need to pull the wheel off, its basically 2-3 bolts, although some of them are in there pretty well. I'm not too far from you, your track day is next Saturday right? as in the 26th
Also, what kind of shock?
pothiawala786 is offline
post #11 of 26 (permalink) Old 05-15-2012, 12:27 PM Thread Starter
Yeah, ACC on the 26th. Hoping to get this done before then so I can get a suspension setup done. Know about the stock pegs trick -- do I need a c-clip tool to reverse the pegs?
I've got the rear stand, just no jackstands to unweight the swingarm.
Edit: Shock is a Penske 8975DB.
Thanks for the offers, I'll try and figure out my plan later today.
nicotine is offline
post #12 of 26 (permalink) Old 05-15-2012, 12:33 PM
Sportbike: 05 SV
Years Riding: ...
To reverse the pegs you just need small pliers. Pull out the clip, lightly tap out the pin, reverse peg, put the pin in there to hold it in place.
I would just go out and buy some jackstands for $20. I would offer you to bring it to my place but my garage floor isn't exactly level for the drains so last time it was a PITA. It really isn't that hard though, couple bolts at the bottom for the dogbones are kinda tight/rusty, otherwise the one up top is pretty easy.
I would spray the bolts you need to remove with PB blaster, etc to make the job a little easier.
Also, not sure if I'll have time this Thursday, I should during the day, but you are welcome to borrow my jackstands if you want. I would prefer a small deposit that I'll fully return just because I don't know you. It literally is 3 bolts, but the bottom 2 dogbone bolts can be hard to get out just because where they are.
post #13 of 26 (permalink) Old 05-15-2012, 12:44 PM Thread Starter
Can I get them out with just extensions, or should I look for a u-joint for my ratchet?
Got a torque wrench and breaker bar, so hopefully between that and PB I can work them loose. I remember getting the frame sliders installed was tough for the same reason.
I'll probably just end up hitting Home Depot and grabbing the parts needed after this thread -- thanks for all the input.
nicotine is offline
post #14 of 26 (permalink) Old 05-15-2012, 01:06 PM
if you had trouble installing frame sliders .........
post #15 of 26 (permalink) Old 05-15-2012, 01:20 PM
as all the needle bearings fell to the ground.
post #16 of 26 (permalink) Old 05-15-2012, 01:22 PM
Be careful supporting a 400 pound motorcycle on small cast aluminum foot pegs.
post #17 of 26 (permalink) Old 05-15-2012, 01:35 PM
Sportbike: 05 SV
Years Riding: ...
Don't remember which tools I used, don't think I used any u-joints or swivel sockets, but its been a couple years probably.
I didn't have a problem breaking the bolts loose, it was getting them to slide out with one hand while manipulating the rear stand with the other to ease the load off the bolt. The hardest bolt was the one that goes from the dogbones to the swingarm/frame, the 2 bolts for the shock were pretty easy.
Like I said though, I did this on an uneven floor so it made the job tougher. Took me a few hours taking my time.
Frame sliders on the other hand took me 15-20 mins, so be prepared to have time set aside incase this shock install takes longer than planned.
post #18 of 26 (permalink) Old 05-15-2012, 01:37 PM
Sportbike: 05 SV
Years Riding: ...
Very true, I've done it but you have to be extremely cautious. You can also put jackstands under the frame sliders if you're more comfortable doing that, even then, its a 400lb+ bike in the air so you have be very careful, and obvioulsy do this at your own risk.
post #19 of 26 (permalink) Old 05-15-2012, 01:48 PM
I used a scissors jack to hold up the rear of the bike and installed my shock easily. I was able to crank the jack up and down to help me align the linkages. It was super simple.
post #20 of 26 (permalink) Old 05-15-2012, 01:56 PM
LR has the simplest solution I've seen.
post #21 of 26 (permalink) Old 05-15-2012, 06:56 PM
Ryan's Avatar
Years Riding: Since 2001
That's pretty clever Eric.
I like your "BJ" license plate too.
Ryan is offline
post #22 of 26 (permalink) Old 05-15-2012, 08:01 PM
Yeah, I paid extra for that.
post #23 of 26 (permalink) Old 05-15-2012, 08:40 PM
and i bet it still left a salty taste in your mouth
post #24 of 26 (permalink) Old 05-15-2012, 08:50 PM
plotts's Avatar
Sportbike: KTM 690 SM
Years Riding: A little bit.
That scissor jack is Freaking brilliant.
plotts is offline
post #25 of 26 (permalink) Old 05-15-2012, 09:06 PM
BJ has the solution, WAY COOL!
post #26 of 26 (permalink) Old 05-15-2012, 10:11 PM
BFLY's Avatar
Sportbike: CBR1000/GSXR1000
How you found us: Buddy
That is good backwoods engineering I love it. Just be sure your not going to pop through the plastic undertail.
過労死
Nesba #98
CBR1000
BFLY is offline
