Oil leaks - Chicagoland Sportbikes
post #1 of 2 (permalink) Old 06-28-2012, 11:56 PM Thread Starter
behappy's Avatar
Sportbike: None
Oil leaks
Hello,
I have been working on trying to get my old bike to stop leaking oil, its selective on leaking oil. I have looked into replacing the head gasket and generator gasket, I have got the head gasket to stop leaking now I am down to the oil leaking coming from one of the exhuast manifold seals. So I have been searching and searching and well I have come across your piston rings are shot, PVC valve need to be replace(maybe plugged), and I have also been reading that the valve stem seals could be shot. When the bike starts it slow to get the rpm going, There is no smoke when starting/running the bike, I have replace the spark plugs and air filter, Oil was in the air box and covered the plug that the exhuast manifold is leaking.
Whats your thoughts???
behappy is offline
post #2 of 2 (permalink) Old 06-29-2012, 12:00 AM
sorry.
Top end rebuild.From your description it has moire than a leaking gasket.
