push button shifting - Chicagoland Sportbikes
post #1 of 6 (permalink) Old 09-12-2012, 10:04 AM Thread Starter
#40 expert
design-engine's Avatar
Sportbike: gsxr600
Years Riding: 40+ years started at four (My dad still rides Motocross at 80)
How you found us: nesba.com
was at the manufacturing show at McCormic yesterday and all the cool CNC gear I want. Anyways one of the exhibits had a mx bike with electronic shifting. Check this out.
http://sphotos-b.xx.fbcdn.net/hphoto...54104020_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...08734309_n.jpg
So green means shfit up and red means shfit down? what what do you guys make of that cylinder. looks to be some sort of electronic linear Actuator?
DESIGN-ENGINE|EDUCATION
Pro/ENGINEER training ZX6R CCS Expert #40 #1 plate holder
http://design-engine.com/category/racing/ RACE BLOG
design-engine is offline
post #2 of 6 (permalink) Old 09-12-2012, 10:31 AM
Ryan's Avatar
Years Riding: Since 2001
With that boot holder thing mounted above the peg it looks like that bike may have been built for someone with no or limited use of their legs.
They've had air and electronic shifters for drag race bikes for a long time but I'm pretty sure they can only upshift. They kill the ignition for a split second during the shift for smooth clutchless upshifts. That dirtbike probably has an auto-clutch in it.
Ryan is offline
post #3 of 6 (permalink) Old 09-12-2012, 10:47 AM
Probably a solenoid that "fires" rather than an actuator that moves.
post #4 of 6 (permalink) Old 09-12-2012, 11:15 AM
http://pingelonline.com/eshifter.htm
They've been around for a while now.
post #5 of 6 (permalink) Old 09-12-2012, 11:52 AM
There is also the Dale Walker's Holeshot Performance electric shifter. It has an electric selenoid that operates a cable that will actuate the shift lever. From some of the research I've done users (all dragracers) say it's easier to set up than the Pingle. As I understand it it can be set up for street, dirt and ATV's. Expensive though...depending on how elaborate you want to get it could run close to $800.
OldTimeBiker is offline
post #6 of 6 (permalink) Old 09-12-2012, 11:55 AM
push/pull solenoid imho
