electrical - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 04-29-2013, 06:28 PM Thread Starter
R6 couple's Avatar
Sportbike: 2000 R6
electrical
Help! I have a 2000 R6 and it died,starting w the tail lights,display then shuts down.I've replaced the battery and was wondering if it could b the rectifier.it starts again and runs for a while when same thing
R6 couple is offline
post #2 of 9 (permalink) Old 04-29-2013, 09:36 PM
how long did it run on the new battery? did you charge the new one before starting the bike?
if youve got a volt meter measure the voltage at the battery as the bike sits off, youll want around 12.8+
start the bike and measure the voltage, it should be above 13.4 if its in the 12s or less you have a charging issue which could be caused by the rectifier, the stator or both.
post #3 of 9 (permalink) Old 04-30-2013, 09:48 AM Thread Starter
R6 couple's Avatar
Sportbike: 2000 R6
New battery.the volts do not increase when running.no burnt connectors.thanx for the advice.know of any good mechanics in the area? I don't wanna rely on the overpriced big dealers.
post #4 of 9 (permalink) Old 04-30-2013, 10:40 AM
ok now you know its not charging
so youve narrowed the issue to the stator or the rectifier
easiest thing to test is the stator
find the plug for the 3 wires (often all yellow) that go into the rectifier
imagine them as being labeled A B C
with the volt meter set to resistance measure each of the pairs of wires and note the readings
AB
AC
BC
I dont know off hand what the values should be but consistency is what were looking for , if one is vastly different that the other pairs then theres a problem with the stator
second step in testing is to start the bike and rev it to about 3k
set the volt meter to AC voltage and measure the 3 pairs of wires again and note the voltages for each, youre looking for around 42v AC
post #5 of 9 (permalink) Old 04-30-2013, 11:07 AM
What he said.
42v minimum.
post #6 of 9 (permalink) Old 04-30-2013, 12:12 PM
Results? do you own a volt meter?
post #7 of 9 (permalink) Old 04-30-2013, 12:45 PM
he did say that there was no voltage rise when the bike was running
hes only had 3 hours to test the stator...
wheres our results
post #8 of 9 (permalink) Old 04-30-2013, 02:49 PM
wheres our results
He needs to get after that shit. We're on the clock here dammit!
post #9 of 9 (permalink) Old 04-30-2013, 02:59 PM
