Cam chain tensioners... - Chicagoland Sportbikes
post #1 of 3 (permalink) Old 05-08-2013, 10:31 PM Thread Starter
The first Tico here!
javio1's Avatar
Sportbike: 2000 Suzuki SV650
Can you tell by sound if they are needed? I was told I need them, what do you think?
https://www.youtube.com/watch?v=rBYc...e_gdata_player
javio1 is offline
post #2 of 3 (permalink) Old 05-08-2013, 10:34 PM Thread Starter
javio1's Avatar
Sorry, I guess I can't properly add my YouTube video.
javio1 is offline
post #3 of 3 (permalink) Old 05-08-2013, 10:47 PM
Wisconsin FIB
TripleZ's Avatar
Years Riding: Since June 2002
How you found us: Pilotx1
Short answer, no, you can't tell solely by ear if the chain tensioner needs to be replaced. It can give you a good indication where to look, but the sound associated with chain mesh / slap is often amplified by other dynamics in the system such as idle / run quality (which drives crankshaft dynamics......which drives chain dynamics).
Easy way to check is to pull the tensioner, verify it doesn't have visible heavy wear between the plunger and body, no broken spring, no plugged oil holes, etc. If the ratcheting type, be sure to check the mechanism for proper engagement (and the "teeth" for wear). I don't know how the SV tensioner is built.....but Grasshopper is the man when it comes to that bike. What he says goes.
And I can't tell anything from a Youtube video. Sorry, I'd have to listen to it in person, then typically even at work, I rely on the fancy LMS sound equipment we have to identify source.
TripleZ is offline
