01 gsxr 600 no start - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 06-21-2013, 08:51 PM Thread Starter
Sportbike: looking
I recently lifted my tank and moved the air box on my gsxr. After putting in back down the bike would no longer start. It started up just fine minutes prior to lifting tank and air box. The reason I lifted the tank is because my idle was low when I purchased that bike. The seller thought it was the battery be he was only able to charge it halfway from dead. I did put my brother battery in and it seem to idle much better but my fast idle lever wasn't working so we decided to lift tank and box to find problem. We didn't touch anything but it wont start. Thinking may have pulled something loose but didn't see anything at the time. Is it possible that the fuel filter or pump got clogged from lifting tank upright? Any help would be appreciated or if there's a mechanic available I'm on northside
pure octane is offline
post #2 of 8 (permalink) Old 06-21-2013, 09:18 PM
Check the connectors on the fuel pump, bottom of tank.
post #3 of 8 (permalink) Old 06-21-2013, 09:26 PM Thread Starter
Sportbike: looking
Thanks will do
post #4 of 8 (permalink) Old 06-22-2013, 10:08 AM
are the battery connections tight as well, the bike powers up but doesnt start? does it crank?
post #5 of 8 (permalink) Old 06-22-2013, 10:30 AM
Check the wires that connect everything together.
post #6 of 8 (permalink) Old 06-22-2013, 11:01 AM
See new guy rant ....
post #7 of 8 (permalink) Old 06-22-2013, 11:29 AM
It must be my Tapatalk settings.
post #8 of 8 (permalink) Old 06-23-2013, 11:15 PM
Sportbike: 04 r1
Years Riding: 20
did you figure out the problem?
busa4 is offline
