No power - Chicagoland Sportbikes
post #1 of 9 (permalink) Old 09-30-2013, 03:37 PM Thread Starter
Fly-by-you's Avatar
Sportbike: 2001 Suzuki GSX-R 600
Years Riding: Not Enough
No power
My brother was jumping his 2001 Kwai zx6r and hooked up the jumpers wrong. The bike has no power and I checked his fuses with no luck. Any ideas on where I should start? I can't seem to find the main fuse.
Fly-by-you is offline
post #2 of 9 (permalink) Old 09-30-2013, 03:40 PM
main fuse is normally located only a couple inches from the battery positive terminal, look for a black box with 2 heavy leads coming from it, one going to the bike and the other coming right from the battery, the fuse/fuses should be on there
post #3 of 9 (permalink) Old 09-30-2013, 03:46 PM
How high were the jumps? Yeah what Pilot said.
post #4 of 9 (permalink) Old 09-30-2013, 03:47 PM Thread Starter
Fly-by-you's Avatar
I think I know what your talking about there is a small black box attached to the pos side of the cable but no way to open it. I can't seem to find the part online as well .
post #5 of 9 (permalink) Old 09-30-2013, 03:49 PM Thread Starter
Fly-by-you's Avatar
He said the car was not started and as soon as he touched the clamps he knew he f$&@ up.
post #6 of 9 (permalink) Old 09-30-2013, 04:13 PM
did he take it off any sweet jumps?
http://www.dgy.com/OEMpartfinder.htm...C19C1936E18401
look in the starter motor subsection its PN 27010-1380 called a switch
it has a fuse on it
post #7 of 9 (permalink) Old 09-30-2013, 04:38 PM
how about the obvious and check to see if the battery is still good
disconnect the battery test volt meter and then connect it again
post #8 of 9 (permalink) Old 09-30-2013, 10:17 PM
ramenboy...'s Avatar
Sportbike: triumph speed four
visor down
nesba #608
ramenboy... is offline
post #9 of 9 (permalink) Old 10-01-2013, 12:46 AM
Was there any magic smoke???
