Hmm? - Chicagoland Sportbikes
post #1 of 49 (permalink) Old 11-12-2013, 07:18 PM Thread Starter
Hmm?
Ok fellas tell me why .
You should check you valve clearance?
tell me why ?
your Whole front end clanks when you apply the front brakes?
tell me why?
Your bike seems to rev faster than it used to?
post #2 of 49 (permalink) Old 11-12-2013, 07:24 PM
Sportbike: 08 gsx six fiddy F
How you found us: forum link
Valves control fuel coming into the combustion chamber and exhaust leaving the combustion chamber. By not having valves seated properly you could be allowing unburnt fuel to go directly out your exhaust instead of being combusted and generating power. So that means your losing power and your losing fuel economy. Another thing is they are designed to only be open for a certain duration so if they are out of sync and staying open or closed outside of there window then you could have an untunable engine, low power output, or just a heavy paperweight if its bad enough.
2008 Suzuki gsx 650f.
Thomas Jefferson
michowski is offline
post #3 of 49 (permalink) Old 11-12-2013, 07:33 PM
tell me why ?
tell me why?
In the words of my man Forrest ......
post #4 of 49 (permalink) Old 11-12-2013, 11:08 PM Thread Starter
Shit I could have not said it better.(that's for sure).
The biggest thing you left out (and its a big thing )Is that when a valve does not close completely I allows carbon to build up on the valve seat leading to the $1K head rebuild.
post #5 of 49 (permalink) Old 11-13-2013, 12:39 AM Thread Starter
Come on lets talk motorcycles.
post #6 of 49 (permalink) Old 11-13-2013, 06:35 AM
Are you kidding me? I can see why someone like you would just pick Ventura as president and a radio jockey.
"valves seated properly"
what does that have to do with valve clearances?
post #7 of 49 (permalink) Old 11-13-2013, 10:28 AM
tell me why ? Because valves tighten over time. Never chase a cunt hair
tell me why? Lose brake caliper, no oil in the fork tubes, something broken in the forks
Your bike seems to rev faster than it used to?Hmmmm... Rev faster or idles faster? Why?
post #8 of 49 (permalink) Old 11-13-2013, 10:46 AM
Doing some wrenching myself. I did some upgrades to thr A superbike and probably was able to take several pounds off of it. I'm also building a street bike to clown around on which will have some cool parts on it to.
post #9 of 49 (permalink) Old 11-13-2013, 11:48 AM
BH
BH's Avatar
Sportbike: KTM
How you found us: find who?
cause valves stretch over time
cause steering stem bearing get sloppy over time
cause piston rings wear and valve springs weaken over time
BH is offline
post #10 of 49 (permalink) Old 11-13-2013, 12:29 PM
Dirtbiker's Avatar
Are you in town this weekend Nick?
Dirtbiker is offline
post #11 of 49 (permalink) Old 11-13-2013, 02:07 PM
Some other lighweight upgrades.
Shaved down and lightened axle adjusters
Aluminum vs Steel front counter shaft nut and spacer
Plastic Vs Metal access plugs to get at flywheel
Titanium and aluminum motor mount bolts and spacers that push motor into place.
post #12 of 49 (permalink) Old 11-13-2013, 02:09 PM
I think that should take off some weight. I'm trying to get the SV down to around 300 pounds with, 1 gallon of fuel, oil and coolant in it. We will see once we put it on the scales.
post #13 of 49 (permalink) Old 11-13-2013, 05:36 PM
let's find some twisty's
mxvet57's Avatar
How you found us: search
Done many of them.
Photo & Video Sharing by SmugMug
mxvet57 is offline
post #14 of 49 (permalink) Old 11-13-2013, 06:22 PM
If its not clearanced properly then how will they be seated properly? It all affects each other. Now run away troll, your not wanted here. Big people are talking now.
Thomas Jefferson
post #15 of 49 (permalink) Old 11-13-2013, 06:52 PM Thread Starter
With the valves I was thinking about how the carbon will build up on the valve face.( I always like to set my to the loose side)
With the front end. I was thinking about bad neck bearings. It's a strange feeling once you've felt it, you'll never forget.
A slipping clutch will make a motor seem to rev faster.Another strange effect on the bike you'll never forget.
post #16 of 49 (permalink) Old 11-13-2013, 07:05 PM
"seated properly"
you make sure you do that when you rebuild the head by lapping the valves into the valve seats. Wow, basic engine building class.
Now what does valve clearance have to do with your answer?
"Now run away troll"
I'm talking about engines, so where did I talk about something that isn't on topic of said discussion?
post #17 of 49 (permalink) Old 11-13-2013, 07:21 PM
How many pounds before?
post #18 of 49 (permalink) Old 11-13-2013, 07:39 PM
"seated properly"
What time is it in Paris right now?
Thomas Jefferson
post #19 of 49 (permalink) Old 11-13-2013, 07:48 PM
nice example of a troll response.
post #20 of 49 (permalink) Old 11-13-2013, 11:10 PM Thread Starter
Will any of that bickering make your bike faster?
Gus's fast garage bikes 101 can.
post #21 of 49 (permalink) Old 11-14-2013, 01:24 PM
BH
BH's Avatar
Sportbike: KTM
theoretically, carbon on the valve face will make the clearance bigger though right? wouldn't you set them on the tight side to counter that?
do you see much carbon buildup on the faces? With the valves I've looked at the faces are typically pretty clean, most of the buildup was on the head and base of the stem.
good call on the cutch, I didn't think of that one.
BH is offline
post #22 of 49 (permalink) Old 11-14-2013, 01:55 PM
Why don't you just use Ti hardware and save yourself time and get it below 300 a whole lot easier?
post #23 of 49 (permalink) Old 11-14-2013, 02:11 PM
Have you ever priced Ti hardware? This kit is a g note. LOL!
post #24 of 49 (permalink) Old 11-14-2013, 03:25 PM
Sell the wife and get the bolts. LOL
post #25 of 49 (permalink) Old 11-14-2013, 03:43 PM Thread Starter
With the valve properly closing it helps to cool the valve while preventing build up on the face.
The valve seat does not show carbon as on the stem.It will appear as little black spots on the seat.After many cycles it will dent the valve face and seat.
Another important factor with valve clearance will be a smooth closing of the valve .To much clearance will allow the valve to slam shut.
post #26 of 49 (permalink) Old 11-14-2013, 04:59 PM
Shut your pie hole. I will ask her to buy me the bolts. She might
post #27 of 49 (permalink) Old 11-14-2013, 05:01 PM
Gus, how thick is a cunt hair?
post #28 of 49 (permalink) Old 11-14-2013, 05:03 PM
Dirtbiker's Avatar
Twice as thick as the regular ones.
post #29 of 49 (permalink) Old 11-14-2013, 05:21 PM Thread Starter
About .003-4
post #30 of 49 (permalink) Old 11-14-2013, 06:07 PM
Wisconsin FIB
TripleZ's Avatar
Years Riding: Since June 2002
How you found us: Pilotx1
About .003-4
Unless you're talking the standard RCH which is a bit thinner at 0.0025
TripleZ is offline
