Ok heres the deal I went out 2 days ago trying to start my 2003 honda 600rr and battery is dead. I get it charged than try starting it again it pops off but only for 10 secs and dies and then wont start. I have a professonal at a local dealer charge it and make sure the battery is good. So I try again and nothing. Whats the problem I put stable in it before I parked it? please help me out.thanks.gabe
:2cents:
Is it a choking kind of dead or does it just cut off? Did you run the bike for a few after puting in the stabil? Not quite sure if not running the bike after putting in the stabil would matter but it might...
The gas is probally november ish I put the required amount in and I drove it since then. You think it will start up if I try push starting it? It dosent even try to fire off it just turns and turns I tried messing with the gas but nothing happens besides me smelling gas. I dont think anything nested in my muffler but ill check.thanks gabe
so you got it started but for only 10 seconds? push the bike forward or backward a foot then try again. sometimes the starter wheel doesnt like certain spots.
OR you got a bit of clogging going on.
once you get it started just rev it here and there and blow the shit out of it.
He smells fuel so I think its still a spark issue, as long as it cranks over, make sure that the spark plug wire is properly connected and not broken or otherwise damaged.
Alot of Honda Sportbikes are known to foul out the plugs if they only run for a minute and then are shut off. Crazy Japs didnt put a 20*F map in the ECU. :lmao:
Try putting it in nuetral and holding the throttle wide open when you start the bike. My bike had similar symptoms a year ago when I let it sit in the garage for a month in below freezing temps. If it starts, make sure the bike doesn't cut off after the fast idle sequence by keeping the throttle slightly open; Then let the bike sit there and run for 10 minutes. If this works, it should start and run smoothly from now on unless you sit the bike in the garage for a long time again.
The problem with that is on the Honda's when you hold the throttle wide open while cranking the engine the ign. doesn't fire. One nice thing Honda did to help clear out the cylinders if the bike is flooded.
The battery has juice lights work and what not the starter tries to turn the engine over but it wont fire off. So I think im gonna try to push start it I have done this several times before over the winter to get her to start. If that dont work than im gonna check the plugs I hear there a bitch to take off on the rr somthing about removing the radiater or somthing.
Echo what Chief said. open throttle 3/4, hold it, push start button, 2nd time it should start up. Trust me, it'll start, unless your flux capacitor is outta whack.
When you cycle the key, do you hear the fuel pump.
Try to open the air box and remove the air cleaner, it may be dirty.
Do you have a power commander? You might try to bypass it.
Push start it in 2nd gear with the key on. I sometimes have someone push me while I drop the clutch. Then keep pushing for 5 or 10 ft. to keep the engine turning.
Check all your fuses as well. Be sure that the fuel line isn't kinked or pinched if you've had the tank or tank cover off.
Try a new battery. Sometimes a battery will have enough juice to turn the pump on and turn on the gauge cluster, but still not start.
It's in the thread above my brother from another mother. Andrew's detailed Electrical Engineer explanation is also there. And if you search the MythBuster's forum, they addressed my question as well.
It's almost never too cold, this is coming from a guy who rode his bike in 12 degree/negative five degree wind chills. When you try to start the bike, do you hear the fuel pump, and some churping from the starter like the bike is attempting to start, or is there just a dead clicking noise when you press the start button?
The pump turns on and the starter cranks and cranks but it dose not fire off.thanks gabe
Related Threads
Chicagoland Sportbike Forums
2M posts
11.3K members
Since 2002
