help! my launch sucks - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 04-19-2004, 11:25 PM Thread Starter
Sportbike: 00 r1
Years Riding: 1k miles
i've only put about 800 miles on my r1. and i can't keep that front wheel down. i can't get out of first fast enough without my wheel coming up. i have a little trouble in 2nd gear but if i can keep my weight far enough forward i should be able to keep that down. but as far as first, it owns me. any suggestions?
cosmo kramer is offline
post #2 of 8 (permalink) Old 04-19-2004, 11:28 PM
use less throttle.
post #3 of 8 (permalink) Old 04-19-2004, 11:30 PM
CRAZe Inc's Avatar
Sportbike: Big Wheel
Years Riding: Since 3
feather the clutch more
CRAZe Inc is offline
post #4 of 8 (permalink) Old 04-19-2004, 11:46 PM
vrrooooooom!
trey's Avatar
Sportbike: 01 honda 929rr
How you found us: from a member of fireblades.org
Send a message via AIM to trey
extended swing arm? wheelie bar? buy a 600? don't dump the clutch? pick your poison.
<------ Jason
trey is offline
post #5 of 8 (permalink) Old 04-20-2004, 01:13 AM
Hell in first a newer 600 jumps up like a rabbit and doesn't go down to easy under power.
The swing arm will work a 3 inch would do for a 1k. Or slip the clutch more, lay on the tank and hang on!
stilettoR6 is offline
post #6 of 8 (permalink) Old 04-20-2004, 09:03 AM
First, make sure you have a steering damper. I used to drag race a lot. Since I got the R1 I don't anymore. The bike is just not set up for it. It's darn near impossible to launch without the front end coming up. The only thing you can do is practice a little self contron and use less throttle. Believe me it's hard to get used it. My GSXR 750 had a 2" stretch and launched a lot harder than my R1 can. It feels funny with a more powerful bike that can't get off the line as fast, however I don't wanna end up on my back either.
post #7 of 8 (permalink) Old 04-20-2004, 09:10 AM
Ya the R1 is not a drag bike. that bike was setup for turning not launching. If you wanna launch it lower it, strap the front and extend the arm.
post #8 of 8 (permalink) Old 04-20-2004, 09:15 AM
Strap the front and bump the rear tire pressure 2 lbs at a time. I can use tire pressure/traction to control wheelies. Higher pressure will mean more top end also.
YTRAP is offline
