Powerslides - Chicagoland Sportbikes
post #1 of 6 (permalink) Old 05-03-2005, 07:45 PM Thread Starter
Joe
Joe's Avatar
Sportbike: 2007 GSX-R600, 2007 KX250F, 2004 YZ450F, 2006 CRF50
Years Riding: As long as I been ridin your mama
How you found us: Joemama
Send a message via MSN to Joe Send a message via Yahoo to Joe
Powerslides
I'm not sure where to put this so here goes...
I see some racers on TV doing powerslides in corners. My question is, how is this different from the same motion of a high side? It looks very possible to high side while doing a powerslide, however, I haven't seen any racers highside from doing powerslides. Can someone explain this? Maybe I just don't understand.
Joe is offline
post #2 of 6 (permalink) Old 05-03-2005, 08:15 PM
Yes, That is a scar...
JayHRC51's Avatar
Sportbike: '00 Honda RC 51 (sold)
Years Riding: 2 years
How you found us: worked with HD Tony's wife
If I understand your question right...
When a racer is "backing it in" to a corner, they are under braking. The back tire is sliding and fish-tailing like that because they are using engine and the breaks to slow the bike down. When the back tire is spinning slower than the speed the bike is traveling, it slides until the bike slows to the same speed that the engine is spinning at. You almost never see a high-side under these conditions.
Typically, a highside takes place under hard acceleration exiting a corner, as the back tire is spinning, not entering it. If it regains traction suddenly (or the rider scares the shit out of himself and whacks the throttle shut) and stops the bikes rotation to the side. When that happens, the bike stands up really quickly, throwing the rider over the top of the bike. "Highside"
If the rider gives it too much juice while in the corner, the bikes rear end naturally wants to rotate away from the corner. If it rotates too far, he just falls onto his ass. "Lowside"
"I just want to say good luck, we're all counting on you"
JayHRC51 is offline
post #3 of 6 (permalink) Old 05-03-2005, 08:32 PM
or they stay on the gas countersteer the other why "then normal countersteering, dirt bike method" and ride it out. like what was said chopping it or allowing it to regain will put your but in a highside or dam near close to it, "which is called saving it"
post #4 of 6 (permalink) Old 05-21-2005, 10:54 PM
Please pass the trackpipe
TheGrouch's Avatar
Sportbike: That one^^
Years Riding: ..
If you're talking about someone like Rossi or Yates smoking the rear on corner exit, they are closer to the center of the tire when this happens. If they lit it up like that while cranked over, they'd be highsiding all over the place.
NESBA CR #51
TheGrouch is offline
post #5 of 6 (permalink) Old 05-22-2005, 10:07 AM
By all stretches this is not a "stunt" as your chosen forum might give away. If anything it is a technique. Now, if we want to talk about sliding the bike, perpendicular to your travel direction, when coming to a stop, then I am all ears, and that IS a stunt.
Brian is offline
post #6 of 6 (permalink) Old 05-22-2005, 11:13 AM
Guest
Posts: n/a
It called alot of practice and having control over your bike. It is a common for them to do that as it is for you downshifting.
