RECALL PSA: Remington 22 Hornet 45 GR PSP Ammunition - Chicagoland Sportbikes
post #1 of 1 (permalink) Old 11-12-2010, 03:59 PM Thread Starter
http://www.remington.com/pages/news-...n22Hornet.aspx
Safety Warning And Recall Notice
Product Safety Recall Notice
Warning
DO NOT USE REMINGTON 22 HORNET 45 GR PSP AMMUNITION WITH
LOT NOS. J29EAI, J29EBI, J30EAI, J30EBI OR K01JDI
Remington has determined that five Lots of its 22 Hornet 45 Gr PSP ammunition may have improper powder charge weights. The five Lot Numbers are identified above. Improper powder charge weights may result in a malfunction of the cartridge when the firearm is fired. This malfunction may result in a bullet being lodged in the barrel creating an obstruction. If another round is fired with an obstruction in the barrel, a barrel burst may occur. A barrel burst could result in property damage, serious personal injury or death.
Do Not Use
Remington 22 Hornet 45 Gr PSP Ammunition
Lot Numbers J29EAI, J29EBI, J30EAI, J30EBI OR K01JDI
To identify if you have one of these Lots of ammunition:
If you have a case of 22 Hornet 45 Gr PSP ammunition the Lot Number is stenciled on the outside of the case; and,
If you have a box of 22 Hornet 45 Gr PSP ammunition the Lot Number is stamped on the inside flap of the box.
If you have any of this Remington 22 Hornet 45 Gr PSP ammunition, as identified above, immediately discontinue use of this ammunition and contact Remington at the below telephone number. Remington will arrange for the return shipment of your ammunition and upon receipt will send you replacement ammunition at no cost to you. If you are unsure whether or not you have one or more of these Lots of ammunition or if you have mixed boxes of ammunition; please immediately discontinue the use of the ammunition and contact Remington at the below telephone number we will replace this ammunition for you.
For any consumer questions or instructions on how to return of your Remington 22 Hornet 45 Gr PSP ammunition with one of the following Lot Numbers J29EAI, J29EBI, J30EAI, J30EBI OR K01JDI, please contact the Remington Consumer Service Department at 1-800-243-9700, Prompt #4.
The only Remington 22 Hornet 45 Gr PSP ammunition affected by this recall has one of the following Lot Numbers J29EAI, J29EBI, J30EAI, J30EBI OR K01JDI. No other Lots or ammunition is affected.
We apologize for any inconvenience this may cause.
