Saiga 308 - Chicagoland Sportbikes
post #1 of 8 (permalink) Old 02-17-2012, 01:36 PM Thread Starter
ClevisR6's Avatar
Sportbike: 04 Zuma, 06 Crf50
Years Riding: sho' nuff!
How you found us: Nesba
Saiga 308
Saiga 308
How about this one?
It's less than a third the cost of a SIG 716. Surefire 25 rd mags are ~$40; a bit more than the 308 p-mags.
Can you attach a flash suppressor or brake w/o much hassle?
How much would a solid scope mount run?
ClevisR6 is offline
post #2 of 8 (permalink) Old 02-17-2012, 01:45 PM
Jewrassic Park Runaway
samal's Avatar
you would need to remove the sight post and either thread you muzzle for the flash hider or install sight post with 24x1.5 RH threads - thats what I did for my saiga. dinzagarms.com has them
solid side scope mount is about $50 at kalinka optics
samal is offline
post #3 of 8 (permalink) Old 02-17-2012, 01:49 PM
Originally Posted by ClevisR6 View Post
Saiga 308
How about this one?
It's an Izzy so I'm sure it's great but what are you going to do with it? SHTF purpose?
No way to mount a brake without a HUGE headache.
Scope mount will cost $100 for a nice ADM that'll lock into side mount and hold/return to zero.
This is the one your want, VASTLY superior to the old Soviet crap-
http://www.midwestindustriesinc.com/...ategory_id=433
post #4 of 8 (permalink) Old 02-17-2012, 01:54 PM
samal's Avatar
if you are looking for US made mounts - they are expensive, but Russian PK-02 work fine holding zero after many many times I took it off and put it on. they are made to withstand 7.62x54r recoil on SVD rifles
http://kalinkaoptics.com/mounts/ak-v...aver-rail.html
http://www.dinzagarms.com/saiga_308/308fsb.html
samal is offline
post #5 of 8 (permalink) Old 02-17-2012, 02:11 PM
The difference in price between the Kalinka and the MI is negligible when you consider the advantages of the MI. The mount doesn't bend metal to stay in place, it uses an ADM lock that will 100% RTZ and not flex/bend/move over time like the Kalinka. It's a solid 1 piece mount unlike the Kalinka which uses screws to attach the rail to the rest of the mount which eventually back themselves out over time. It's made in the USA, carries a lifetime warranty, weighs less and is coated in melonite to resist corrosion. All in all, for the price difference, it's a no brainer- you eliminate 6+ points of failure for $50.
post #6 of 8 (permalink) Old 02-17-2012, 02:22 PM
samal's Avatar
I am not saying that Kalinka is as good as MI, all I am saying that Kalinka was good for me and worked fine for many many other hunters and shooters in Russia and here. it's all about bang for a buck, what will do the job for less.
I am not suggesting UTG mounts because they are crap, Kalinka does the job, MI is superior to both for sure
samal is offline
post #7 of 8 (permalink) Old 02-17-2012, 06:11 PM Thread Starter
ClevisR6's Avatar
link? couldn't find it. Is it similar to an AR FSB removal and install?
for the replacement threaded sight post.
ClevisR6 is offline
post #8 of 8 (permalink) Old 02-18-2012, 06:32 PM Thread Starter
ClevisR6's Avatar
pretty much. for when a little extra oomph is needed. i have a bunch of the "fragmenting" early 90's german dag/men 7.62 that i would like to find decent platform for.
that ammo is hard to find these days
ClevisR6 is offline
