Blazer ammo - Chicagoland Sportbikes
post #1 of 27 (permalink) Old 11-12-2008, 12:30 PM Thread Starter
Blazer ammo
Has anyone else had bad experience with Blazer? I donít know if itís the aluminum or what. Their price was pretty good on their .45 rounds and I picked some up. Monday I had a combat shoot and in one of my runs I loaded a mag and the round did not feed into the chamber after my reload. That could have been my fault by not slamming it in there hard enough. After that when I was reloading my mags I came across 3 rounds that were shorterÖbasically packed in too much, so I tossed those aside. And on my final run on one of the courses, everything is going fine and then my chamber gets caught half way open with the round half way in and half still in the mag. Fortunately I caught it right away, gave a quick tug on the slide, and it went in for my last 2 shots and only cost me about a second. But overall Iíve never had these problems before until I used the Blazer ammo. One guy told me that it heís seen this happen before with aluminum casings because they might not be as slick as brass, so my slide getting caught up he thought was due to the ammo. Anyone else ever have this problem? Iíve always used Winchester or UMC and theyíve been flawless.
post #2 of 27 (permalink) Old 11-12-2008, 12:34 PM
Sportbike: R6, SV1000s, rm250
I've had issues with Remington UMC ammo twice not loading and once not ejecting the shell, but I'm hoping it's just from still being broken in and only having 75 rounds thru the gun.
post #3 of 27 (permalink) Old 11-12-2008, 01:00 PM
I typically used Winchester white box.
Where do you shoot? NITac?
post #4 of 27 (permalink) Old 11-12-2008, 01:05 PM Thread Starter
Maxons. 2nd Monday of every month. 2 courses set up (one on each range), $15 to go through both courses once or $20 to go through twice. Results are posted the following month.
post #5 of 27 (permalink) Old 11-12-2008, 01:07 PM
I've shot tens of thousands of rounds of 9mm and .45 Blazer over the years, and for cheap range ammo, it's reliable enough.
I did a bit of digging after Monday night, regarding the bullet seating inside the casing, and apparently this is a minor issue with Blazer, due to the aluminium casing.
*shrug* Your mileage may vary I guess.
post #6 of 27 (permalink) Old 11-12-2008, 01:08 PM
Sounds like what I used to do at Bells with NITac! Awesome! At least I think it was bells...it's been about 8 years since I've done it.
Do they have coaches there? I'd probably have to start all over again since it's been so long.
post #7 of 27 (permalink) Old 11-12-2008, 01:10 PM
It's only a minor issue if the added backpressure doesn't cause problems with your gun! A minor issue would be the round not ramping/feeding correctly because of the inset exposing the leading edge of the "brass".
post #8 of 27 (permalink) Old 11-12-2008, 01:14 PM Thread Starter
Bek can be your coach. There's no coaching but everything is explained since the courses change each month. You watch a couple people and get the hang of it. So long as you're not rushing faster than you can possibly shoot you should be ok. Just need a holster, a few mags, and you're golden.
post #9 of 27 (permalink) Old 11-12-2008, 01:35 PM
I can teach you everything you need to know about IPSC matches. I've been shooting 'em for years here. As Biggy said elsewhere, take your time. These specific events at Maxon's are very casual & friendly "matches," if you can even really call them competitions. We welcome new shooters all the time.
post #10 of 27 (permalink) Old 11-12-2008, 03:02 PM
http://theboxotruth.com/docs/edu18.htm
I don't know much but this might give some insight
Ninja 13 is offline
post #11 of 27 (permalink) Old 11-12-2008, 04:36 PM
I use Blazer in the Wheel Guns OK..... in the SA's not so well.
Something about the material ( silver ) that they use for cases seems to
be less-slippery than brass and it tends to drag a bit when the weapon
cycles. As a consequence I have experienced jams and/or stovepipes.
You can usually get USA for about the same price as blazer,
It's brass and I have had no issues with it.
post #12 of 27 (permalink) Old 11-12-2008, 04:42 PM
blazer ammo= dirty shit burning ammo in a box.
crappy tolerances "so have a loose gun"
post #13 of 27 (permalink) Old 11-12-2008, 04:55 PM
It's cheap... you get what you pay for. Suits me fine for range ammo.
post #14 of 27 (permalink) Old 11-12-2008, 05:09 PM
fo shizzle.
post #15 of 27 (permalink) Old 11-13-2008, 09:29 PM
Unregister User
smurph's Avatar
How you found us: Dumb luck!
I shot some Blazer 45 through the Springfield tonight no problems (dirty) but it didn't want to feed through my Dan Wesson. Though to be fair I have had a few ftf and stove pipes with WWB and UMC as the gun is still breaking in.
Nesba #74 I
smurph is offline
post #16 of 27 (permalink) Old 11-14-2008, 07:38 AM
I'm lazy CCI makes Blazer, I think...when Makarovs hit the market back in 95, I bought two russian made ones (many copies available, almost like the AKs) and the only ammo available at the time was CCI stuff in the white box, with aluminum cases, I bought a case of the stuff, ball 95g bullet, stuff worked like a freaking charm, didn't foul the guns either. Since then I bought the dies and reload my own stuff. God I love Unique, the do it all powder....load everything from shot gun to rifle with it....hint small rifle primers in pistol load FTW
post #17 of 27 (permalink) Old 11-14-2008, 07:43 AM
I love loose guns, function under ALL conditions, and who cares what your spread looks like at 150 yards, may be all over the paper dinner plate, but I'm still hitting the thing. I hate Bench Rest shooters, talk about holy anal retentive types
post #18 of 27 (permalink) Old 11-14-2008, 10:11 AM
if you can hit all over a paper plate at 150 yards out of a pistol thats good ammo and shooter. "very good shooter"
each persons has there own opinions and preferences.
you dont like mine? then suck me off or shut your mouth.
post #19 of 27 (permalink) Old 11-14-2008, 11:42 AM
Im more NW suburbs
anyone know good places to go shooting?
Also Bek, I see you are an aficianado
I too, try hard to be an aficianado
the magazine is awesome
and they rec some real good cigars
favorites?
Gixxer600Ghost is offline
post #20 of 27 (permalink) Old 11-14-2008, 11:57 AM
Yards ? Or Feet ? Indoor or outdoor ?
post #21 of 27 (permalink) Old 11-14-2008, 12:43 PM
Ooooooooohhh!!!!
blackrose613's Avatar
Sportbike: Katana 750
Years Riding: 30 years
How you found us: google search
Send a message via Yahoo to blackrose613
I have used blazer in my 92fs. I cant really complain about them for the price of them. I have experienced a few captures and binds but then again I was not shooting them competition.
they are reliable enough for everyday shooting and target/plinking but I would not run them comp.
_________
Chrys
____________________
2000 Suzuki Katana 750
Lol I am no pimp. I am married and have no game.
blackrose613 is offline
post #22 of 27 (permalink) Old 11-15-2008, 12:18 AM
Blazer sucks, but not as bad as Wolf. Range fodder.
Remi FTW.
Blade Runner is offline
post #23 of 27 (permalink) Old 11-15-2008, 05:38 AM
Remi FTW.
The first 75 rounds I put thru my 1911 were remi umi 230gr fmj ammo, had 1FTE and 3 failures to load. Then I put 50 reloads thru w/o one problem. Just bought 100 WWB rds and a box of blazer brass to try out. I hope either of them turn out decent with my gun b/c they're dirt cheap at the local walmart.
post #24 of 27 (permalink) Old 11-15-2008, 12:48 PM
Wow, Remi has been rock solid in all my weapons. Strange.
post #25 of 27 (permalink) Old 11-15-2008, 02:01 PM
Opphs me bad should read 50 feet
Right opinions are like assholes....everyone has one mines usually bigger and always right
post #26 of 27 (permalink) Old 11-15-2008, 02:04 PM
Remi FTW.
I haven't tried Wolf, stuff is dirty cheap by the case, at least the 9 x 18 Mak, I was going to try it for just keeping proficient with the mak, and re-loading I want to reload at least 1000 rounds at a time.
post #27 of 27 (permalink) Old 11-15-2008, 04:44 PM
more like gaped
