Core Strength - Chicagoland Sportbikes
post #1 of 43 (permalink) Old 06-20-2010, 01:11 PM Thread Starter
AgentofDarkness's Avatar
Sportbike: 05 CBR600RR
How you found us: CBR Forum
Core Strength
I think I need to strengthen my core. I tried to look for some info online and I didn't really find anything. Any ideas on good core exercises?
AgentofDarkness is offline
post #2 of 43 (permalink) Old 06-20-2010, 01:15 PM
Don't argue, you'll lose
Sportbike: NA
Years Riding: NA
How you found us: Na
just take some roids and you'll be good!
all joking aside, p90x
Kerosene is offline
post #3 of 43 (permalink) Old 06-20-2010, 01:24 PM
Can't go wrong with squats and deadlifts.
post #4 of 43 (permalink) Old 06-20-2010, 01:37 PM
Mogwai
Stephiroth's Avatar
Sportbike: The one I ride.
Years Riding: enough.
How you found us: insomnia.
http://www.mayoclinic.com/health/core-strength/sm00047
You lie, the internet totally has information.
09 Ninja 250r- track
Resident Lube Expert.
Stephiroth is offline
post #5 of 43 (permalink) Old 06-20-2010, 03:23 PM
post #6 of 43 (permalink) Old 06-20-2010, 05:29 PM
PolishPete's Avatar
Sportbike: 600rr
Hanging Leg Raise - One of the best overall core exercises. Works everything it needs to.
Put two arm straps hanging from a high pole, shoulder with apart. Hang from them using upper body strength...pull your knees to your chest. After you get decent at that, you can add a twist. Man does that just beat-up your core!!
PolishPete is offline
post #7 of 43 (permalink) Old 06-20-2010, 05:31 PM
PolishPete's Avatar
Sportbike: 600rr
Those are great exercises, but not specifically for a good core work-out IMO. They inadvertently work the core, while working other muscles more predominately. Additionally, to avoid injury, you should have a decent core to do those exercises effectively and with appropriate weight. So for some new to lifting type guys, these exercises are basic, yet maybe what should be out of there initial regimen.
post #8 of 43 (permalink) Old 06-20-2010, 06:33 PM
BH
BH's Avatar
Sportbike: KTM
How you found us: find who?
core is more than just abs
BH is offline
post #9 of 43 (permalink) Old 06-20-2010, 06:36 PM
PolishPete's Avatar
Sportbike: 600rr
Yup...and thats why I recommended the hanging leg raises...works your core. Not just abs.
Proof: http://www.mrfatloss.com/hanging-leg...r-core-workout
Hanging Leg Raises: A Superior Core Workout and MORE!
When you are ready to start training, one of the best things you can do for your body is make sure to include compound movements.
Compound movements, which will hit a variety of muscle groups at the same time, allow you to work out much more efficiently. By working several muscle groups at one time, you will burn more calories and build muscle tissue much more quickly than simply specializing on one at a time.
One favorite for many ab gurus is a compound movement called the hanging leg raise. This as a compound movement comes as a surprise to some because most people simply think of this as a simple ab exercise…An ab workout that usually hurts and is difficult that is, leading to many staying away from this extremely effective exercise.
post #10 of 43 (permalink) Old 06-20-2010, 06:40 PM
Registered F'n User
PWRMAD's Avatar
Sportbike: 2012 ZX-14R, 2012 R1, 2008 Stratoliner
How you found us: Saw the ad in 'D-Cups' magazine
DO THE PLANK!
And add back hyperextensions. http://images.bizrate.com/resize?sq=500&uid=854640027
PWRMAD is offline
post #11 of 43 (permalink) Old 06-20-2010, 06:47 PM
BH
BH's Avatar
Sportbike: KTM
mostly just abs and obliques.
and would be much better if you ditch the sissy arm straps and do it hanging from a chinup bar and keep your legs straight.
still would also need to do something like planks to work your back, hips, etc
BH is offline
post #12 of 43 (permalink) Old 06-20-2010, 07:40 PM
PolishPete's Avatar
Sportbike: 600rr
I know it's to each his own...but I feel it's a great exercise.
And I'm not referring to easy straps...rather the arm straps? They look like padded loops, and you stick your arms into them, holding your elbow at a 95 degree angle and they rest on the bottom of your arm. Thus you're using a lot of your core and lats to hold yourself in that position/stabilize during the exercise. Much more difficult than using the bar alone or the easy straps.
Referring to these: http://www.evitaminstore.com/Deluxe-...aps-71200.html
Lastly, I'd like to add that your abs are a major component of your core. Any exercise that you do to build your core will be building your abs. However, an exercise that goes beyond that is what you need for building the whole core, and I'll second my choice again for the hanging let raise using these straps. They go far beyond the simple ab workout.
post #13 of 43 (permalink) Old 06-20-2010, 08:26 PM
jimzx9r's Avatar
Sportbike: .
That exercise only works the hip flexors, and the mr. fat loss site looks retarded.
Lower Abdominal Myth
It is widely believed the lower abs are exercised during the leg raise or other hip flexor exercises. However, it can be misleading to judge the mechanics of an exercise based on localized muscular fatigue. The primary muscle used in hip flexion is actually the Iliopsoas one of many hip flexors. The Iliopsoas, particularly the Psoas portion, happens to lie deep below the lower portion of the Rectus Abdominous. During the leg raise, the entire abdominal musculature isometrically contracts (contracts with no significant movement) to:
o Posture the spine and pelvis
+ Supports the weight of the lower body so the lumbar spine does not hyperextend excessively
+ Maintains optimal biomechanics of the Iliopsoas
# Hips are kept from prematurely flexing if the lumbar spine and pelvis does not hyperextend excessively
# Iliopsoas can contract more forcefully in a relatively slight stretched position
* Bent knee (and hip) sit-ups actually place Iliopsoas at a mechanical disadvantage
o Counteracts Iliopsoas's pull on spine
+ Many people with weak abdominal muscles are not able to perform hip flexor exercises without acute lower back pain or discomfort
The combination of the local muscular fatigue, or a burning sensation from the isometrically contracted abdominal muscles, and from the working hip flexors produces fatigue in the pelvis area which we mistakenly interpret as the lower portion of the Rectus Abdominous being exercised. In movements where the Rectus Abdominous does Isotonically contract (contracts with movement), it flexes the spine by contracting the entire muscle from origin to insertion. The spine is not significantly flexed during the leg raise. Incidentally, both the spine and hip flexes during the full range op motion Sit Up and Leg Hip Raise. See Spot Reduction Myth above.
http://www.exrx.net/WeightTraining/Myths.html
jimzx9r is offline
post #14 of 43 (permalink) Old 06-20-2010, 08:32 PM
What is the "core"?
post #15 of 43 (permalink) Old 06-20-2010, 08:34 PM Thread Starter
This is actually my main motivation for strengthening my core. I know I can squat/deadlift more than I currently can but I think my core is holding me back. In exercises where I use a machine (i.e. leg press) I can lift much more weight.
post #16 of 43 (permalink) Old 06-20-2010, 08:39 PM Thread Starter
Originally Posted by auditech View Post
What is the "core"?
Abs, lower back, and obliques
post #17 of 43 (permalink) Old 06-20-2010, 08:42 PM Thread Starter
I didn't click on that link.
post #18 of 43 (permalink) Old 06-20-2010, 09:08 PM
Nope. I'll wait for some other people to chime in and see what they say.
post #19 of 43 (permalink) Old 06-20-2010, 10:16 PM
PolishPete's Avatar
Sportbike: 600rr
[QUOTE=jimzx9r;1751310]That exercise only works the hip flexors, and the mr. fat loss site looks retarded.
Haha, yeah, the site may be what it is, not using it for anything other than a quick reference.
Also, the exercise works more that your hip flexors. Try it. Correctly. You'll feel it. Again, to each his own as each body is different and some workout do better with some people than others. I can only say I know a little bit of what I'm talking about, and very experienced...and I know what works what from application. I'm not trainer though.
post #20 of 43 (permalink) Old 06-20-2010, 11:04 PM
The best thing that works for me, is to concentrate on everything else and not core exercises. That doesn't mean don't do them, you should do something twice a week specifically for the midsection, and break it up by doing something different every week. Over the winter I took a core class once a week, and it was hard, doing something different each time so I never had a chance to get good at the specific exercise, but each time no matter what it was they got easier. Without a good program of general weights though, the rest won't matter as much. Do a simple program of weights 3 times a week with low weight, and add an ab or core exercise the other 2 days, and you will be golden.
post #21 of 43 (permalink) Old 06-21-2010, 02:52 AM
Sooo, can anyone that has posted in this thread actually define the "core"?
post #22 of 43 (permalink) Old 06-21-2010, 05:52 AM
stripper pole, that is all.
post #23 of 43 (permalink) Old 06-21-2010, 09:19 AM
why the sudden focus on your "core"?
post #24 of 43 (permalink) Old 06-21-2010, 09:26 AM
Some of the core exercises I've been doing...
-Hip Ups
-V-Ups
-Toe Touches
-Seated Medecine Ball Twists
-Bicycle
-Side Planks
-Sprinter Sit-Ups
...most of these are in varying series, supersets. BRUTAL!
post #25 of 43 (permalink) Old 06-21-2010, 01:43 PM Thread Starter
See Post 15
This is basically what I do now, minus the core exercises. MWF I lift (different exercises). TRSat I do cardio (3 mi run). I guess I'll add the core exercises to my cardio days.
post #26 of 43 (permalink) Old 06-21-2010, 01:47 PM
haha, you're comparing your leg press to your squat and think it's your core holding you back from those numbers matching? We used to load up the leg press with every fucking plate in the house, then maybe put a guy on top too. These same people wouldn't max out over 500 on squat and assure you their core was up to the task. You're comparing apples and oranges, leg press is stupid just avoid it.
post #27 of 43 (permalink) Old 06-21-2010, 01:51 PM
Hey it's good for knee rehab!
post #28 of 43 (permalink) Old 06-21-2010, 01:57 PM
BH
BH's Avatar
Sportbike: KTM
anyone remember who it was that was bragging about their leg press on this forum a year or two back?
found it: https://www.chicagolandsportbikes.com...ight=leg+press
BH is offline
post #29 of 43 (permalink) Old 06-21-2010, 02:14 PM
Chunk's Avatar
Sportbike: I don't ride
buttfuck cattle for superior core strength. I have mad core strength.
<---- Useless Mufugga
Chunk is offline
post #30 of 43 (permalink) Old 06-21-2010, 02:34 PM Thread Starter
I figured that both exercises worked out the same muscle group so I should be able to do a similar weight. Guess I misunderstood.
