Off Season Bike Maintenance - Chicagoland Sportbikes
post #1 of 3 (permalink) Old 11-28-2009, 01:41 PM Thread Starter
Joe put together a list of things that we keep in mind with our bikes going into the off season and I thought I would share it with everyone.
CHASSIS - the most neglected part of our machines but don't underestimate how good a properly lubed and torqued chassis can feel.
Steering head - clean/inspect/ repack
-inspect bearing cage for cracks and wear
-inspect races for wear and damage, dimples from ball bearings
Swingarm pivot - clean/inspect/ repack
-measure side play, should be less than 1mm if any
-look for loose needles and broken cages
-inspect inner races for wear
Lower linkage - clean/inspect/ repack
-inspect all inner race shafts for wear
-inspect seals for tearing
-inspect needles and cages
-inspect dogbones for stretching
Wheel bearings and axles - clean/inspect
-bearings should rotate smoothly with even resistance
-a loose bearing is on it's way out
-clean repair axle threads
Chain and sprockets - clean/inspect
-look for torn or missing o-rings
-no binding plates
-shark finned sprocket teeth
-proper alignment
Brakes
-clean and inspect calipers
-look for worn or damaged lines
SUSPENSION - we all spend a lot of time and money on good components and keeping them at optimum performance takes maintainance.
Forks
-refresh/upgrade
Shock
-refresh /upgrade
Steering damper
-clean inspect for damage
-clean lube pivot points
ENGINE/TUNE UP - the endless pursuit of speed
Refresh
-A big investment but worth it to insure a trouble free season or to stay competitive. Also a good time to upgrade
Valve adjustment
-slightly more complicated procedure only proceed if your comfortable with cam timing
Oil and filter
-use factory filters and new crush washers
Spark plugs
-inspect/ replace
Air filter
-inspect/replace/upgrade
Fuel mixture
-custom map from a reputable tuner
Coolant
-replace with appropriate coolant for storage conditions
RACE PREP - turn that glorified street bike into a proper race machine
Wiring
-remove unnecessary components. AI solenoid, brake sw, lighting relays, side stand sw etc.
-wrap, insulate harness
-tie up all unused connectors
Air injection
-install block off plates if applicable
-remove hoses and solenoids
-wire out solenoid
Routing
-cables
-harnesses
-clear of steering and crash damage
Hand controls
-clean lube all cables and levers
-remove left handle bar sw
-clean/replace grips
TurnOneRacing is offline
post #2 of 3 (permalink) Old 12-01-2009, 02:54 PM
Nuke and Pave
jimmeigs's Avatar
Sportbike: Yamaha R6, BMW RT
Years Riding: R6 2 years, bikes - longer than you!
How you found us: Wink
Bump to the top for a great list! Thanks TurnOne!
NESBA #327, Advanced Class
06 Yamaha R6, 04 BMW RT, 72 Honda CB500
"All dogs go to Heaven."
"Being middle of the road started to bore me, so I headed for the ditch."
jimmeigs is offline
post #3 of 3 (permalink) Old 12-01-2009, 03:42 PM
As he listed. Don't forget the steering damper! Very important.
But seriously. Loose or worn swingarm, stem and other bearings can give problems in ways you've never imagined. Small crashes transmit a lot of energy through the chassis. Have your bike torn down, maintained, inpsected and ready for a fun full track season.
