Advice for exhaust bolts - Chicagoland Sportbikes
post #1 of 5 (permalink) Old 09-05-2004, 10:33 PM Thread Starter
Went for a cruise with the wife on the VTX today..was a nice ride, but during the 2nd half of our ride there was a metal rattle that wasn't there before and some really nasty exhaust backfire. I thought maybe a wire pulled lose from the power commander so I stopped at a parking lot. Turns out one of the bolts for the exhaust came out and the other was half out. Was too hot to touch so I just got it back home and tightened the loose bolt and replaced the missing one.
Question is, obviously the vibration shook the bolts out. Should I use locktite (and which application type) on something like exhaust bolts? I'm always worried about later removal of the bolts, so I'm hesitant about using it.
Any advice?
Jynxx is offline
post #2 of 5 (permalink) Old 09-06-2004, 03:51 AM
DO NOT use RED, use blue.....if you're gonna use it. Me, I'd go lock washers first and see if it helps out, if not THEN use loc-tite.
taziscool is offline
post #3 of 5 (permalink) Old 09-06-2004, 05:32 AM
I use LokTite Blu on just about every fasterner on the bike. I Never did like lock washers.
post #4 of 5 (permalink) Old 09-06-2004, 06:23 AM
what he said.
post #5 of 5 (permalink) Old 09-09-2004, 10:19 AM
grndskpr's Avatar
Lock tight will melt out, and not last, especially on the exaust, the solution for the HD(used to loose bolts all the time) is to pick up metal lock bolts, the nylocks will melt, but they make a metal one that works just as well, and will not fall out, i found mine at auto zone, the other solution that has been used is to double but the exaust, with two nuts, its almost imposibale for only one to fall off
later
R
grndskpr is offline
