buddys harley problem...who can help? - Chicagoland Sportbikes
post #1 of 18 (permalink) Old 10-16-2005, 03:27 PM Thread Starter
Thee original azzhole!
Thunderstruck's Avatar
How you found us: i see all
well easy way to explain this is where the oil filter gets screwed on...and then the oil sensor below it...well he overtightened the oil sensor and it cracked the alum block with a hair line crack....POOR enginering in my eyes by harley...but here is the pickle...its leaking oil from both the filter cause of the crack and also from the sensor location casue the crack goes all the way from the sensor hole to the filter location....
any 1 know if this can be fixed or is 1 side or the motor cassing gonna have to be replaced?
its alum so it can be welded more then likely...but its in a sensitive area...
mmmm pussy
Thunderstruck is offline
post #2 of 18 (permalink) Old 10-16-2005, 04:20 PM
Yamahaulin !!
Jobee's Avatar
Sportbike: 2003 R6 Liquid Silver
Years Riding: 4 yrs
How you found us: on line
duct tape...
Ok I'm sorry, I have nothing of value to add.
“Speed has never killed anyone, suddenly becoming stationary . . . that’s what gets you” Jeremy Clarkson
Jobee is offline
post #3 of 18 (permalink) Old 10-16-2005, 04:28 PM
WOW!!! thats not a good situation. buy the extened warenty and then take it in and tell them you dont knwo what happened.
It may be time to replace that half of the engine case. while your in there and since you have to split the cases he should just go ahead and put in a 103 kit.
post #4 of 18 (permalink) Old 10-16-2005, 05:13 PM
This show is 'Rated NC17'
tWisTEd's Avatar
Sportbike: Honda's & Yamaha's
Years Riding: Late 80's
Huh. . . don't know how to fix that. Never happened on my Honda.
tWisTEd is offline
post #5 of 18 (permalink) Old 10-16-2005, 06:17 PM
you can try jbweld for a quick fix.
But can you blame harley for someone overtorquing a bolt? Majority of engines today are coming out aluminum. If you overtorque the plugs, or head bolts then you just messed your engine up.
oldschoolninja is offline
post #6 of 18 (permalink) Old 10-16-2005, 07:06 PM
I'm always learning......
SloRoll's Avatar
How you found us: GPS
How can you say "Poor engineering"??? That's rediculous. He muscled in the sensor and spread the case till it cracked. It's aluminiun!!! Duh......
Cases can be rewelded, but only by a professional that knows how to weld a MC case. Not just any welder will do. If this is a newer bike I'd go with a new case. If it's an old bike and to want to keep the original numbers, weld.
JB weld will temporarily plug a leak but is has little to no structural integrity.
SloRoll is offline
post #7 of 18 (permalink) Old 10-16-2005, 08:51 PM Thread Starter
well...he was not smart to pay attention to the part that was alum....and i think you guys are right and just buy a new right side case...its a newer bike...he's not gonna be happy about it...but i dont think there will be an easy fix to this...
mmmm pussy
post #8 of 18 (permalink) Old 10-16-2005, 08:54 PM
Make my day!!!!!
wingit's Avatar
Years Riding: 20+ yrs.
trade it in gor a new one!
Joe
FACEBOOK
wingit is offline
post #9 of 18 (permalink) Old 10-16-2005, 09:38 PM
Torque wrenches can be had for $20.00 at harborfreighttools.com a service manual, maybe at the most $30. If a hack like me can wrench, and not F things up, anyone should be able too. I have used JB Weld to repair a number of things, with good sucess. The last time was repairing an oil leak, lasted until I sold the vehicle.
post #10 of 18 (permalink) Old 10-16-2005, 09:43 PM
If you clean the area properly the JB weld will be all you need and will last for a long time. I had a Honda throw the chain and blow out the side of the engine case - a few hours later I was up and running again and last I heard it is still running strong 10k later. The key to it all is good surface prep - lots of acetone or denatured alcohol and making sure everything is completely oil free.
Jschaffer is offline
post #11 of 18 (permalink) Old 10-16-2005, 10:01 PM
Cougar8000's Avatar
Sportbike: 2006 FZ1
Years Riding: I only take walks
Send a message via Yahoo to Cougar8000
What I want to know is how did he managed to crack aluminum. Last time I checked if you are screwing a bolt into an aluminum and you over tighten it, all you are going to do is break a thread. It is either I am way outdated on my engeniring background, it has been more then 15 year, or something does not add up here.
Last year body of mine over tighten his oil pan in the Katana, alluminum pan, all he did was striped the thread. It was holding the bolt, but slowly dripping oil. I wonder if the crack you see is not the type of the crack that you thing it is and it is just siping oil from th thread itself?
Alex - Certifiable MSF Instructor
2006 Yamaca FZ1
The truly happy person enjoys the scenery on a detour
A man should choose a friend who is better than himself. There are plenty of acquaintances in the world; but very few real friends.
RIDE for Kids Donations
https://www.mishacycles.com
MishaCycles on facebook
Misha Tactical Arms, Inc
Cougar8000 is offline
post #12 of 18 (permalink) Old 10-16-2005, 10:27 PM
Bop your way home...
Dr. D's Avatar
Sportbike: Hypermotard
Years Riding: since 99'
There is this stuff called alumirod (sp?), it allows you to weld with a propane torch. It should be able to fix the problem. You would just heat the cases and the alumirod would get sucked into the crack. Cheap fix but I can't be certain it will work as I don't have a lot of experience with this type of thing, I have a torque wrench,
-Alan-
Balancing the Paradox
of Art and Profit
Dr. D is offline
post #13 of 18 (permalink) Old 10-17-2005, 12:02 AM
Oil sensor is, I believe, a 1/8-27 tapered pipe thread. Normal threads will pull out most often, but the taper acts as a wedge and can cause cracks fairly easily.
Alumaloy might work. The problem is that it requires you to get the surrounding area to a very high temperature. It's tough to use the stuff when working with thicker aluminum sections because it wicks away the heat so fast it's hard to ever get it up to temperatures at which the alumaloy will bond with the base metal. Worth a try, though.
post #14 of 18 (permalink) Old 10-17-2005, 12:20 AM
Dr. D's Avatar
What if the bike was to be run at idle for a while to get the cases nice and saturated with heat, would that help any?
-Alan-
of Art and Profit
Dr. D is offline
post #15 of 18 (permalink) Old 10-17-2005, 06:49 AM Thread Starter
^---that would work....but then its still has to be cleaned cause the oil is leaking through 2 spots...so by the time you got that cleaned up....its back to a cold temp again...best bet for him is just to replace the case in my book...i didnt bring my camera with when i went to go look at it...but im sure this is a known issue with harleys...he just didnt know cause its was his 1st harley...
mmmm pussy
post #16 of 18 (permalink) Old 10-17-2005, 06:56 AM
I use that all the time, love the stuff, I think Sloroll has used it also. Problem with that method, is the casing acts as one huge assed heat sink, so you'll go thru at least 20 lbs of propane heating the repair area to the proper temparture. You'll need to use an oxy/acly torches to heat the area, and if you don't know what your doing, you'll cause even more problems. Second the entire area will have to be super clean, and the only way I see that happening is removal of the casing involved.
post #17 of 18 (permalink) Old 10-17-2005, 09:08 AM
BandM's Avatar
Sportbike: X-1, XR-1000
How you found us: Badweb
Remove all traces of oil from the crack with brake cleaner and compressed air, and seal with loctite wick and lock (290). It is made for this application and I have used it to seal cracks in steel and aluminum castings. As long as there is no stress trying to spread the crack, it will work.
http://www.loctite.com/int_henkel/lo...icking%20Grade
BandM is offline
post #18 of 18 (permalink) Old 10-17-2005, 10:08 AM
Just go on ebay and buy a new right side case. Its not that hard to rebuild a harley motor. its air cooled which is 100% easier already.
If you try and repair it its gonna look like ass. and good luck selling it with a weld line running down the motor casing.
